Old 17th December 2008, 18:31   #1  |  Link
juhok
juhok's Avatar
Finding and fixing green fields from capture
I have some videos with a lot of green fields caused by errors in the capture (bad tape), some are consecutive but most just 1 field at a time. Sample (Huffyuv, YV12)
I've ordered external TBC long time ago but still haven't got it and I have to cap these before xmas (even if TBC would help).
Only thing that bothers me is the green color. I wouldn't mind if it was black or previous field repeated. Flashing green just isn't nice.
I've found some old scripts that might help. But I'm not 100% there yet. So if someone has/had similar problems, could you please share your solution(s).
juhok is offline   Reply With Quote
Old 18th December 2008, 06:52   #2  |  Link
MadRat
MadRat's Avatar
I suppose you could use FreezeFrame. It works like this FreezeFrame(firstframenumber, lastframenumber, sourceframenumber). So like you could do
AVISource("green_field.avi")
#freezeframe(2,3,1)
#freezeframe(4,4,5)
There would be a little twitch in the video as it paused for a 30th of a second, but it would look better than a couple of badly messed up green frames and finding and replacing all those frames might be a lot of work.
MadRat is offline   Reply With Quote
Old 18th December 2008, 06:53   #3  |  Link
MadRat
MadRat's Avatar
uh... sorry take the # off of the freezeframe, that's a comment command
Old 18th December 2008, 07:06   #4  |  Link
thetoof
Sleepy overworked fellow
For some reason your clip crashes vdub (I guess it's a problem on my side), but until I fix it, could you upload the same sample in Lagarith?
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 18th December 2008, 07:09   #5  |  Link
juhok
juhok's Avatar
@MadRat; Yeah, but there's slight problem.. I'd need to do this in an automated fashion.
So far I've used Fudoh's script
# dropout.avs
# settings
global dir = "d:\temp\"
global infile = dir + "Capture_20060605-134049.avi"
global logfile = dir + "test.log"
# code
clip = AviSource(infile).ConvertToYV12
WriteFileIf(clip, logfile, "(UDifferenceFromPrevious>20)", "current_frame", """ ":" """, "UDifferenceFromPrevious")
WriteFileStart(logfile, """ "Start" """, append = false)
WriteFileEnd(logfile, """ "End" """)
+ trimmaker. But this aproach still requires a lot of human interaction.
Old 18th December 2008, 07:16   #6  |  Link
juhok
juhok's Avatar
Are you using old Huffyuv standalone? Mine is "ffdshow one" and they don't always work together well. Here's lagarith version.
Old 19th December 2008, 00:41   #7  |  Link
juhok
juhok's Avatar
Well, I managed to do this after a lot of trial and error (yeah I suck at scripting, this is almost identical to the example in the manual).
AssumeTFF()
SeparateFields()
Crop(12,0,-12,-10)
ConditionalFilter(last, last.Levels(0,1,255,0,0), last, "AverageChromaU()", "==", "7", false) # Chroma U / V are constant 7
AddBorders(12,4,12,6)
Weave()
I'd like to replace that Levels(0,1,255,0,0) with FreezeFrame(current, current, current-1) .. but haven't figured out how, yet.
Old 19th December 2008, 16:57   #8  |  Link
Gavino
Avisynth language lover
Replace it by Loop(2, 0, 0) to get the effect you want (ie to repeat previous frame).
Old 19th December 2008, 17:48   #9  |  Link
juhok
juhok's Avatar
Works like a charm. Thanks!
analog, capture, error, field, green
