10th January 2007, 09:01 | #521 | Link |
Just a thought...
If BackupHDDVD is able to take an encrypted video and a key, and from that write an unencrypted video, can it be modded to take an unencrypted video with key and produce encrypted video? There seem to be quite a few posts around claiming that BackupHDDVD is very simple Java code that pulls together standard encryption packages and writes the output. I'm assuming that if packages exist to decode AACS encryption, then they also exist to encode. If this is the case, then it would be possible to produce encrypted content for which the key is known. Cheers, Beastie. |
10th January 2007, 10:57 | #523 | Link | |
Posts: n/a
If looking for the the FAQ.txt key snippet doesn't work, maybe the easiest would be playing the movie "Van Helsing" and only look for memory locations starting with 19 to find the title key. Maybe try to first play Van Helsing and then play for example Tomb Raider 1 and then look for memory locations changing from 19 to 6 (is it 06 ??). Code:
CE6339246F34087AB355681DEB656D23DCD5BD86=Full Metal Jacket | 1-00000000000000000000000000000000 486198E3855B57CD40F6DC0C60645BDE8E1E9AC5=Van Helsing |19-00000000000000000000000000000000 B5A8E784B83E793AB246D0C5F7C148A39D7F4856=Tomb Raider 1 | 6-00000000000000000000000000000000 4ACABE525F5CBF77DAA43EA2B83E04918D5FA6D4=Apollo 13 | 1-00000000000000000000000000000000 3D357B0653A66176583C5218FD0149EAF8832FB0=The Last Samurai | 1-00000000000000000000000000000000 610CF1EB362D40050123E92F063D51AC05676F37=The Fugitive | 1-00000000000000000000000000000000 Last edited by He-Man; 10th January 2007 at 12:55. |
10th January 2007, 16:32 | #524 | Link |
Perhaps a "side channel" attack could be implemented, similar to the one described in Adi Shamir's Cache Timing Attack? Just throwing it out there
10th January 2007, 19:21 | #526 | Link |
RPC-1 to people
Looks like to be decimals.
19-A8249382FD7237CA etc, would looks odd ! Anyway it should to be HEX ! (doh!)
Gradius Living in Mars is nice! Last edited by Gradius; 10th January 2007 at 19:25. |
10th January 2007, 19:56 | #527 | Link |
Just so you know, the XX- is not a part of the key (it's the key #) and the textual representation of the keys that you see is not what would be in memory. You would have to convert that Hex string to actual hex values which would be half the length of the string, ie 16 bytes.
10th January 2007, 23:56 | #529 | Link |
To see Muslix64's java code, I noticed that Muslix64 did not do a very complex task. But now, so many people start dump PowerDVD's memory and trace PowerDVD's code, but we still cannot do the same thing as Muslix64. why ?
In the FAQ, Muslix64 said he has two players and he found the key in the memory. So I give up trace PowerDVD's code and try to dump WinDVD's memory. Wa, I can found the title key in the WinDVD's memory and use this key to rip the movie. You should be curious about why I know this is a title key. ^Q^ I just put the value into backupHDDVD. Now, I realize the whole Muslix64's story. Why did Muslix64 play the video with PowerDVD? ^Q^ That is because WinDVD cannot play .evo file. We waste too much time is just we chosen a wrong player. |
11th January 2007, 00:10 | #531 | Link | |
11th January 2007, 01:56 | #533 | Link | |
This is also the purpose of AACS, it knows it is impossible to do a un-crackable device or software, so it designs a way to revoke the device key. Finally, we will give up to crack it. Because it is too tired and too bored. |
11th January 2007, 01:59 | #534 | Link |
Sorry, I do not trace the WinDVD code by Ollydbg or Idapro. I just search the memory and call backupHDDVD. If the value can rip a short segment of video header, I think I find it. It mays take a long time but it works.
11th January 2007, 02:06 | #535 | Link |
Hi Frank,
Sounds like you found the key. Send it in a private message to blutach Quick Links > Private Messages > Send New Message If you can, send him the complete line out of the BACKUPHDDVD TKDB.cfg file. Regards, Feizex. Last edited by feizex; 11th January 2007 at 02:15. |
11th January 2007, 03:07 | #538 | Link |
@Frank:
The latest version of WinDVD i.e. ver 8 does not play HD-DVD or bluray discs yet (says so on Intervideo's website also). So Im wondering what version of WinDVD did you use to play while you dumped the memory... |
11th January 2007, 03:16 | #539 | Link |
Muslix64 had stated that the reason he got to write BackupHDDVD is because (from his Saga.txt):
"But when I realized the 2 software players on windows don't allowed me to play the movie at all, because my video card is not HDCP compliant and because I have a HD monitor plugged with DVI interface, I started to get mad..." Notice that he said he had 2 software players. He also repeatedly stated that "as long as there are weak players, key extraction will be possible" He used PowerDVD in the video and Cyberlink stated many times that PowerDVD is secure.... leads me to think that the other player that Muslix64 had was the weak one from which key extraction from memory was possible. Perhaps the reason why he chose not to mention the name of the player or show it in the video is because once the player is known, the device key would be revoked.... Could people who know please post all the makes and versions of software players out there that are currently capable of HD-DVD playback.... |
11th January 2007, 03:18 | #540 | Link |
Only Windvd-8 Japanese version can play HD-DVD
The $26 upgrade HD pack is very close to be released. If you could get a free trail download of this pack to go with the free trial of WinDVD 8 Platinum you could tinker around for awhile. But no news when the HD pack is coming out. |
