26th April 2008, 21:45 | #1242 | Link |
VC-1 and EVO access?
Is there a way to add the ability to open EVO files?
Or, at least, to open MKV files that contain VC-1 video? I'm trying to archive my Hd-DVDs (since they are now officially extinct ) and most seem to be VC-1. So ifVC-1 can be added, that would be the greatest thing since they invented sliced bread!! Thanks! |
26th April 2008, 22:18 | #1243 | Link |
Send me samples mkv and evo
26th April 2008, 22:46 | #1244 | Link |
This request pertains to all the conversion GUI's. I have read through most of the pages of this and the other GUI threads but not seen any terminology guides. For people used to only one click conerters like DVD shrink an explanation on each of the main settings and how they effect conversion and movie quality would be very useful . If someone has the time it would be much appreciated.
All codec settings, bitrates, buffer sizes etc Thanks for any help |
26th April 2008, 23:23 | #1245 | Link |
What went wrong???
I am trying to make a MP4 of Blade Runner Final Cut Bluray.
I picked the XBOX profile and selected single layer DVD for size. This will not play in my 360, can someone tell me what I did wrong? Here is the MediaInfo.......... General #0 Complete name : C:\Users\Geno\Desktop\BLADE_RUNNER_FINAL_CUT.mp4 Format : MPEG-4 Format/Info : ISO 14496-1 Base Media Format/Family : MPEG-4 File size : 4.38 GiB PlayTime : 1h 57mn Bit rate : 5327 Kbps StreamSize : 3.13 MiB Encoded date : UTC 2008-04-25 21:56:27 Tagged date : UTC 2008-04-25 21:56:27 Video #0 Codec : AVC Codec/Family : AVC Codec/Info : MPEG-4 AVC Codec profile : High@L4.1 Codec settings, CABAC : Yes PlayTime : 1h 57mn Bit rate mode : VBR Bit rate : 5195 Kbps Maximum bit rate : 23.4 Mbps Width : 1920 pixels Height : 1080 pixels Display Aspect ratio : 16/9 Frame rate mode : CFR Frame rate : 23.976 fps Chroma : 4:2:0 Interlacement : Progressive Bits/(Pixel*Frame) : 0.104 StreamSize : 4.27 GiB Encoded date : UTC 2008-04-25 21:56:27 Tagged date : UTC 2008-04-25 21:59:33 Audio #0 Codec : AAC LC Codec/Family : AAC Codec/Info : AAC Low Complexity PlayTime : 1h 57mn Bit rate mode : VBR Bit rate : 128 Kbps Maximum bit rate : 134 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Resolution : 16 bits StreamSize : 108 MiB Encoded date : UTC 2008-04-25 21:59:10 Tagged date : UTC 2008-04-25 21:59:33 Text #0 Codec : Timed Codec/Info : Timed text (3GPP) Codec/Url : http://www.apple.com/quicktime/download/standalone.html PlayTime : 1h 52mn Bit rate : 12 bps Bit rate mode : VBR StreamSize : 10.4 KiB Encoded date : UTC 2008-04-25 21:59:33 Tagged date : UTC 2008-04-25 21:59:33 |
27th April 2008, 00:04 | #1246 | Link |
MP4 must be <=4GB (4096 MB)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th April 2008 at 00:12. |
27th April 2008, 04:08 | #1248 | Link |
I have the same problem witha PS3 mp4 I made - size is 4.2gb - plays on PC but PS3 shows as corrupted data . Same reason I guess? If so is it because consoles not using NTFS file system?
Rather than re-encode the whole file (took 20 hours lol) - Is there a simple way to split the mp4 file into 2 parts without losing any quality? |
27th April 2008, 04:15 | #1249 | Link | |
I have heard this from a lot of people here. I wonder why it only takes 4 to 6 hours on my machine? I am going to re-encode from the original disk with only one pass keeping the original size. This should keep the re-encode time down greatly. Hopefully this will work for streaming to XBOX360. Last edited by duramaximus; 27th April 2008 at 04:25. |
27th April 2008, 05:30 | #1251 | Link | |
Quad Core Extreme 6850 4GB Ram 1TB Raid(stripping) I usually pick 2 pass and use about the same settings. |
27th April 2008, 06:46 | #1252 | Link |
Location: Between a clown and a mime, holding an uzi to each head.
wow, there's really that much of a difference between a duo and a quad? meanwhile I'm chugging along with an Athlon64 3200+, I really need a new system……
And as I walk through the Valley of the Shadow of Death, Lord, thy balls and shaft, they comfort me, you annoint my head with oil, some salt, a dash of pepper, a sprigg of parsley......Lord?............Lord??? What dost thou intend to do with that fork??? |
27th April 2008, 07:52 | #1253 | Link |
Here is the MKV sample. 1 minute, VC-1 1920X1080P 23.976fps. No audio
http://www.enlightenedmediagroup.com...e_test-001.mkv Mike |
27th April 2008, 13:40 | #1254 | Link | |||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th April 2008 at 13:45. |
27th April 2008, 14:42 | #1256 | Link |
I had DVD version
27th April 2008, 20:47 | #1257 | Link |
thanks muchly.
while I'm thinking of, drag-n-drop would be nice too: drop a file onto the main window to make a queue item, then hit edit. or maybe put a drop list for profile selection on the main page also.
27th April 2008, 21:47 | #1258 | Link |
Just had problem with BluRay Chicken Little . Program finishes at the end of Pass 1 - with "all jobs done"- video.264 is zero bytes and no movie is created. Tried twice with same result. I tried manually running job1_EncodeVideoPass2.cmd before closing the program and cmd message is x264 error - cannot find job1 stats. Job1.stats.temp is in the temp\job1 directory tho.Text in pass2.cmd is:
"C:\Program Files\RipBot264\tools\x264\x264.exe" "E:\Temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 6408 --stats "E:\Temp\RipBot264temp\job1\job1.stats" --level 4.1 --sar 1:1 --aud --nal-hrd --vbv-bufsize 14000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-rdo --bime --weightb --direct auto --subme 6 --trellis 1 --analyse p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --output "E:\Temp\RipBot264temp\video.264" Any suggestions to fix ?- I saved all the temp files before closing Ripbot. Also - soory to ask again but is there a simple way to split my 4.2gb mp4 files - I actually have 2 of them and would rather not re-encode the whole movies again. Thx for your help. |
27th April 2008, 22:10 | #1259 | Link |
show me log file
27th April 2008, 22:21 | #1260 | Link |
00000.log :-( found in same file as source not temp\job1)
Stream Type: Transport [192] Profile: High Level: 4.1 Frame Size: 1920x1080 SAR: 1:1 Display Size: 1920x1080 Frame Rate: 23.976024 fps Colorimetry: BT.709 [1] Frame Structure: Frame Frame Type: B Coded Number: 101 Playback Number: 101 Frame Repeats: 0 Field Repeats: 0 Bitrate: 26.275 Bitrate (Avg): 18.723 Bitrate (Max): 26.275 Audio Stream: 1100: PCM 48K 16bit 3/2lfe Audio Stream: 1101: AC3 3/2 640 Audio Stream: 1102: DTS C+L+R+SL+SR 48 1536 Audio Stream: 1103: AC3 3/2 640 Audio Stream: 1104: DTS C+L+R+SL+SR 48 1536 Audio Stream: 1105: AC3 3/2 640 Audio Stream: 1106: AC3 3/2 640 Elapsed: 0:00:00 Remain: 0:00:00 FPS: Info: Thx again |
