Old 19th May 2009, 00:24   #1  |  Link
Ma-Xell
Somewhere Back in Time
Ma-Xell's Avatar
swscaler
In ffdshow there is a sharpening filter called swscaler, which produces nice results.
Is this filter available for avisynth or vdub?
What sharpening filter do you people recommend?
Ma-Xell is offline   Reply With Quote
Old 19th May 2009, 01:22   #2  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
After looking at the source code for it, all it appears to be capable of doing is to apply a typical gaussian blur or the normal [-1 2 -1] sharpening kernel blended with the original image. Try sharpen(), I think it works about the same really. I am now officially disappointed after looking at the code.
I was going to add it to my FFMS2 package but now it seems completely redundant...
Myrsloik is offline   Reply With Quote
Old 19th May 2009, 11:50   #3  |  Link
martino
masktools2 (ab)user
martino's Avatar
# SWScalerSharpen() v1.00 (28/08/08)
# - a function that provides easy access to ffdshow's swscaler sharpener
# Requierments:
# ffavisynth and YV12/YUY2/RGB colorspace
# Parameters:
# lsharp (integer)  - swscaler luma sharpnening strength (32)
# csharp (integer)  - swscaler chroma sharpnening strength (32)
# ssw (integer)     - supersample factor horizontally (1)
# ssh (integer)     - supersample factor vertically (1)
function SWScalerSharpen(clip c, int "lsharp", int "csharp", int "ssw", int "ssh") {
    lsharp  = Default(lsharp,32)
    csharp  = Default(csharp,32)
    ssw     = Default(ssw,1)
    ssh     = Default(ssh,1)
    Assert(ssh>=1 && ssw>=1, "SWScalerSharpen(): ssw and ssh cannot be less than one")
    main    = (ssw==1 && ssh==1) ? c.ffdshow(options="xsharpen=1,sharpenMethod=5,mplayerSharpLuma="+String(lsharp)+",mplayerSharpChroma="+String(csharp)) : \
            c.LanczosResize(c.width*ssw,c.height*ssh). \
            ffdshow(options="xsharpen=1,sharpenMethod=5,mplayerSharpLuma="+String(lsharp)+",mplayerSharpChroma="+String(csharp)). \
            LanczosResize(c.width,c.height)
    return main
# Changelog:
#   28/08/2008  v1.00
#       - initial version
Make sure to load ffdshow's AviSynth plugin in your script, also I can't guarantee for the correctness of the above code. I haven't looked at it, or used it, ever since I decided to waste my time to play with it. Also, the sharpening isn't that great; read Myrsloik's post.
My x264 builds (win32 only up to rev965) and useless AviSynth functions -- use at your own risk
martino is offline   Reply With Quote
Old 19th May 2009, 14:59   #4  |  Link
rfmmars
Yes there's a Vdub plugin, when you install ffdshow, a plugin call "ffvdub.vdf" is unpacked in the ffdshow folder. Copy it to the Vdub plugin folder.
Richard
photorecall.net
rfmmars is offline   Reply With Quote
Old 19th May 2009, 17:31   #5  |  Link
Ma-Xell
Ma-Xell's Avatar
thanks
ffdshow, sharpening, swscaler
