22nd September 2008, 22:37 | #6342 | Link |
Second pass:
Audio gap description file detected, can't be used for TrueHD/MLP, though. Audio gap description file detected, will be used for processing... [v01] Extracting video track number 1... [a02] Extracting audio track number 2... [a03] Extracting audio track number 3... [a03] Realizing DTS gaps... [v01] Creating file "E:\output\video.h264"... [a03] Creating file "E:\output\audiodts.dtshd"... [a02] Creating file "E:\output\audiothd.thd+ac3"... [a02] Audio overlaps for 5ms at playtime 0:46:24. [a02] Audio overlaps for 5ms at playtime 1:28:23. [a02] Audio overlaps for 5ms at playtime 2:33:42. [a02] The audio gaps/overlaps technically can't be removed from the TrueHD bitstream. [a02] In order to remove them you'll have to transcode the audio to another format. Video track 1 contains 230070 frames. eac3to processing took 31 minutes, 57 seconds. Done. Shall i re-encode to another format after or before merging? _ _ _ _ _ |
23rd September 2008, 16:47 | #6343 | Link |
@Madshi
The TrueHD to DTS isn't working in the 2.64 version. 2.60 that I have works fine. The new version names the surround channels as BR/BL and Surcode gets confused cause it doesn't find SR/SL named channels and closes. |
24th September 2008, 16:50 | #6346 | Link |
eac3to reports insane audio delay. DGIndex demuxes audio without problems.
eac3to v2.64 command line: "C:\temp\Ripbot264\Tools\eac3to\eac3to.exe" "C:\VTS_02_1.VOB" 2: "D:\temp\RipBot264temp\job1\audio.1.ac3" -progressnumbers ------------------------------------------------------------------------------ VOB, 1 video track, 5 audio tracks, 9 subtitle tracks, 0:02:16 1: MPEG2, 576i50 (16:9) 2: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -24dB, 60525ms 3: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -28dB, 60525ms 4: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -29dB, 60525ms 5: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -25dB, 60525ms 6: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -28dB, 60525ms 7: Subtitle 8: Subtitle 9: Subtitle 10: Subtitle 11: Subtitle 12: Subtitle 13: Subtitle 14: Subtitle 15: Subtitle [a02] Extracting audio track number 2... [a02] Removing AC3 dialog normalization... [a02] Applying (E-)AC3 delay... [a02] Creating file "D:\temp\RipBot264temp\job1\audio.1.ac3"... [a02] The last (E-)AC3 frame is incomplete and thus gets skipped. Video track 1 contains 1919 frames. eac3to processing took 1 second. Done. http://www.mediafire.com/?zdymif14jyg
24th September 2008, 16:55 | #6347 | Link |
too much lurking
That was me. I have spent several months working on that and I think it's impossible. I have so far gone through the thread three times and compiled lists of what posts I think should go where, and they are different each time. The development posts and usage questions are inextricably linked. Really I think that we as eac3to users should just focus on making the eac3to wiki comprehensive to alleviate the enormous amount of usage questions that pop up in this thread. Or we could just start a new eac3to usage thread.
25th September 2008, 00:33 | #6349 | Link | |
I think you have a collected FAQs on eac3to as well? So i think you are the one who should start this thread. I suppose nautilus7 will contribute as well. Last edited by rica; 25th September 2008 at 00:54. |
25th September 2008, 04:40 | #6350 | Link |
too much lurking
Then I propose a new thread for usage with an opening post linking to the WIKI and to several posts in this thread that address frequently asked questions. Unfortunately my lists of posts from this thread that I made are all about development so I'm not currently in a position to supply the list of FAQ posts. I suppose I could whip something up though.
25th September 2008, 06:47 | #6351 | Link |
i did a quick search of the thread and didn't find anything related to this, sorry if its a dupe suggestion.
When eac3to finds gaps while doing a DTS (and i believe AAC, FLAC) it outputs as PCM and puts up the message about gaps being found before running the external program. I was wondering if you could add an option (maybe something like "-killOnGaps") that will not start that second part. I have some automation that will run a 2nd pass if a .gaps file exists, except when I walk away my computer still has to spend 30 or so minutes making a DTS file from the first step that was filled with tiny gaps. I'm not sure exactly how you designed the program, but if you could this would make things a lot easier for me. Still loving the program madshi! Last edited by killa_kid; 25th September 2008 at 08:03. |
25th September 2008, 19:40 | #6352 | Link |
Dear Madshi,
thanks for the wonderful program eac3to which you keep improving over and over! I have a question: can this program create a FLAC file from six WAV files? And what would be the command line to do this? Regards, va1aY |
25th September 2008, 22:54 | #6353 | Link | |
But automating the second pass is possible, i think. Last edited by rica; 25th September 2008 at 22:57. |
26th September 2008, 06:13 | #6354 | Link |
madshi
I have an lpcm track (Crank blu-ray) where eac3to "sees" 7.1 channels, but only 5.1 of them seem to contain audio data. For me it is no problem, I assume I could specify the number of channels manually. I just thought maybe it could be fixed in eac3to. Tell me if you need a sample. deathlord |
26th September 2008, 09:15 | #6355 | Link |
How do I get 6th channel doubled? (Creating a 8 channel FLAC from 6.1 DTS-HD Master Audio)
I searched the thread but can't find this one. I remember reading that this feature was disabled by default since a while back. |
27th September 2008, 02:02 | #6358 | Link | |||
Hi! I wanna report an error decoding DTS-HD MA:
Here are track specs: DTS Master Audio, 1.0 channels, 16 bits, 48khz (From "For A Few Dollars More") Quote:
eac3to |
