Old 11th November 2016, 19:43   #21221  |  Link
you should select the subtitle filter of your choice under mpc-be-> options -> subtitles.
1. there is no need to disable anything if you set the external filter as preferred.
3. should be fine.
Old 11th November 2016, 20:08   #21222  |  Link
steakhutzeee
steakhutzeee's Avatar
Thanks
So i've to delete xysubfilter from external filters? I've it setted in subtitle options yet.
1. yes, i set them as preferred. I have to turn back selected internal filters or i can leave them deselected? asking just to be sure :P
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 11th November 2016, 20:19   #21223  |  Link
you can you don't have to. i personally would remove the external filter so it is easier to change the subtitle filter if needed.
doesn't matter i recommend to change as least options as possible.
Old 11th November 2016, 20:44   #21224  |  Link
steakhutzeee
Ok, thanks.
Removed it from ex. filters. So i'll leave internal disabled.
What about difference between lav splitter and lav splitter source? But it automatically download subs too?
Old 12th November 2016, 00:17   #21225  |  Link
strumf666
What is the difference between splitter/source?
strumf666 is offline   Reply With Quote
Old 12th November 2016, 09:49   #21226  |  Link
Magik Mark
Hi nevcairiel!
I just need to be clarified if lav supports hardware acceleration on a video that is is 4:2:2 10bit x265?
Experimented on one today. It seems the "GPU" icon doesn't show in MPC-BE which is an indicator that GPU is being utilized. Lav icons are no where to be found as well in the task bar. Is it a bug?
Asus X99 Sabertooth - Xeon E5 2695 - Asus Strix GTX 960 4G - DDR4 16GB Predator - Pioneer KRP 600M (isf calibrated) - Yamaha A3030 - Windows 10 x64 - Kodi with DSplayer - Lav - MadVR - XYsubtitle
Magik Mark is offline   Reply With Quote
Old 12th November 2016, 09:50   #21227  |  Link
nevcairiel
4:2:2 is generally not hardware accelerated. Only 4:2:0.
Old 12th November 2016, 11:53   #21228  |  Link
Magik Mark
May I ask why? Is this a lav limitation or GPU?
Old 12th November 2016, 11:57   #21229  |  Link
nevcairiel
Its a hardware limitation.
Old 12th November 2016, 16:19   #21230  |  Link
uneedme
pretty strange......
I have got a second-hand display card
when i use this one to play movies it is causing tearing of the screen......
when i chose filters other than lavfilter everything went well......
it never happened on my old card......
My card is amd hd 6700 series (asus 6750)
drivers are all the latest......
only when use "lavfilter" filter could have this issue so i could be sure it is lavfilter's problems.......
wish it could be fixed in the later version......
Thx for all your greatwork
uneedme is offline   Reply With Quote
Old 12th November 2016, 16:33   #21231  |  Link
LigH
LigH's Avatar
I can't see your images inline, because PhotoBucket wraps them in an ad-bloated website... so here as links:
^ These artefacts are not what people would usually mean by the term "tearing" (which is instead an asynchronity between frame rate and screen refresh rate, and you won't be able to capture that in a screenshot).
In your case, it seems to be either a decoding error or a rendering error. Regarding the amount of issues and their pattern in the 4th image, probably the latter.
New German Gleitz board
Old 12th November 2016, 19:48   #21232  |  Link
uneedme
I dont know how to describe it...... so i say tearing......
did some test on it after the post...
potplayer:
lavfilter decoder:
vmr9 -rare occasions
EVR(CP) -always
d3d9 -always
madshi randerer -never
opengl randerer -never
ffmpeg decoder:
vmr9 -rare occasions and less effect
EVR(CP) -rare occasions and less effect
d3d9 -rare occasions and less effect
Old 13th November 2016, 18:11   #21233  |  Link
steakhutzeee
I've to enable and prefer "File Source (Async)" using lav splitter?
In this page i read that lav splitter source is an old version of lav splitter, so which i've to use?
https://bypureland.wordpress.com/201...D%89%E8%BC%89/
Old 13th November 2016, 18:37   #21234  |  Link
don't think to much about just add all 4 and you are fine the rest is automatic.
Old 13th November 2016, 20:29   #21235  |  Link
steakhutzeee
All right, thanks
Old 13th November 2016, 22:21   #21236  |  Link
clsid
LAV Splitter Source = LAV Splitter combined with its own file source filter
Adding both is fine.
Old 14th November 2016, 02:15   #21237  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
No, thats not possible. Which hardware can handle 720p but not 1080p? and if you decode 1080p in software, why not lower resolutions as well?
That doesn't answer why you wouldn't just decode everything in software then, your CPU is clearly fast enough.
I'm not a fan of adding more options for rare/exotic use-cases.
Sorry for the delayed response; I had email notification set to "weekly".
My reason is simple - as I am on a laptop, I don't want to unnecessarily produce more heat/spin up the fans/consume more power than necessary when on battery.
In other words, I don't want to completely disable DXVA2 and deal with the according reduction in battery life (especially with 60fps 720p videos) just because I want to be able to watch 1080p videos when plugged in to the wall.
Nintendo Maniac 64 is offline   Reply With Quote
Old 14th November 2016, 10:59   #21238  |  Link
VictorLS
Do your laptop not support 1080p hardware acceleration? Can you provide hardware (model of laptop, CPU, GPU if present) and software (OS and player with renderer you use or tried) configuration? Although in any case you have to manually switch from None to DXVA2 in settings of LAV Video Decoder depending on resolution of played video and on battery/on electrical line.
PS. You are lucky - you have this possibility - many people of the world who see artifacts with DXVA can not switch it of in LAV Video Decoder and they don't know about LAV CUVID Decoder. They have to switch off hardware acceleration because they have no choice (but sometimes with weak CPU it is impossible to decode smooth 1080p without hardware acceleration). I hope for them that nevcairiel will add possibility to switch off DXVA Processing in LAV Video Decoder.
VictorLS is offline   Reply With Quote
Old 15th November 2016, 13:01   #21239  |  Link
TheShadowRunner
TheShadowRunner's Avatar
Hi nev, I have a strange subtitle bug when using LAV splitter 0.68.1.
It's certainly related to the fact my htpc is still running XP 32bit, but I hope a fix is possible ^^;
In effect, when using LAV Splitter Source, some subtitles signs are missing:
http://videoff7.free.fr/samplecbbp_LAV.png
http://videoff7.free.fr/samplecbbp_haali.png
sample: http://videoff7.free.fr/samplecbbp.mkv
when using Haali, it displays just fine.
Absolutely everything else in the decoding chain is unchanged, I only alter the splitter source.
Can you make sense of it? I looked/tried everything and couldn't ^^;
XP SP3 / Geforce 8500 / Zoom Player
TheShadowRunner is offline   Reply With Quote
Old 15th November 2016, 14:23   #21240  |  Link
LigH
LigH's Avatar
Interesting issue. Apart from the exclamation mark and double quotes being handled like "non-printable characters" and being substituted by empty placeholders (just a kind of space char, with a wider width than the excl.), all other alphanumeric characters appear to be quite identically rendered.
