Old 5th October 2017, 23:18   #46221  |  Link
Asmodian
Originally Posted by dvd1 View Post
why jnc does not need overthink?
Jinc is the the highest quality non-doubling scaler. It is a simple very high quality choice if you do not notice the difference from NGU.
madVR options explained
Old 6th October 2017, 00:36   #46222  |  Link
el Filou
el Filou's Avatar
Originally Posted by Siso View Post
I was wondering which decoder to use, CPU decoding, or GPU decoding (DXVA copy-back). CPU is XEON X5650, GPU is GTX 1050 Ti.
The video block in the 1050 decodes pretty much everything and hardly consumes any power, and it's dedicated so you're not using other processing resources. The only case I'd see in your situation for not using it would be if copy-back mode has problems (usually with UHD content).
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 6th October 2017, 06:39   #46223  |  Link
el Filou
el Filou's Avatar
Originally Posted by steakhutzeee View Post
Btw, i'm trying and trying and now i barely see a difference :P Maybe you can see it. I'm thinking, i tried to reset madvr settings after i edited the name file... maybe the problem was really there? :O
I'm not using any processing/enhancement/refinement, and yet on my system the picture looks more similar to your madVR screenshot than to your VLC one (albeit with more banding artefacts).
I noticed that madVR produces a 1920x800 image and your VLC screenshot is 1920x804, the aspect ratio is different. I don't know much about VLC, but what renderer and decoder does it use? If it's DXVA and/or EVR, are you sure your graphics card video 'enhancements' are not processing the image? And how does it produce screenshots? Or did you use print screen?
I also tried basic EVR, and the resulting image is 1920x804 like your VLC screenshot, but with the same brightness levels as madVR. I think the VLC image is the bad one here.
Edit: this scene is a very good showcase of how much better at rendering madVR is than GPU drivers & EVR, btw!
Old 6th October 2017, 09:21   #46224  |  Link
Siso
Siso's Avatar
I watch only 1080p content So copy-back is the right choice?
Old 6th October 2017, 11:11   #46225  |  Link
Tobiwan
Tobiwan's Avatar
Can someone give me tips for faster skipping/jumping inside low quality formats like porn? It needs 2-4sec to rebuild after jumping with my high settings on NGU AA, but maybe I did something wrong. HD 1080p movies work without delay.
I have tried to lower the setting and deactivate the NGU, but it doesn't really help, so it seams something else is wrong.
Tobiwan is offline   Reply With Quote
Old 6th October 2017, 12:00   #46226  |  Link
dvd1
Originally Posted by strumf666 View Post
Jync is a decent enough scaler so you can set it and forget it, if you can't be bothered to do some testing of your own.
I'm testing them but I do not see any difference between the various scalers, maybe I can not figure out what the differences are and with what images i have to do the tests?
dvd1 is offline   Reply With Quote
Old 6th October 2017, 13:03   #46227  |  Link
mzso
I've installed ProgDVB and tested with the same setup you would like to use: software decoding in LAV but with GPU deinterlacing and madVR.
Here's a screenshot
GPU deinterlacing is definitely working, no combing whatsoever as in your screenshot.
I left madVR at its default settings.
I may be wrong, but could madVR + GPU deinterlacing be too much for your graphics card? Have you tried with EVR just to see if deinterlacing works without madVR? Have you tried lowering madVR processing quality?
EDIT: I see your average processing time is ~23 ms. 50i video deinterlaces to 50 fps, not 25, so it means 20 ms per frame. I think it's likely your GPU has no processing resources left to deinterlace in addition to madVR processing. I know Radeons at some point had a 'feature' that disabled some video processing options if the GPU was maxxed out, I don't know much about NVIDIA GPUs yet but could it be that's what happening?
I just realize that when you were testing this I didn't know yet that it only breaks when I change channels.
Could you try it that way? (If you're still around)
Old 6th October 2017, 13:23   #46228  |  Link
jkauff
Maybe you should edit out the boring stuff before playing the video.
Old 6th October 2017, 13:48   #46229  |  Link
Tobiwan
Tobiwan's Avatar
Haha
When I skip/jump the decoder queue goes up over the set limit from 16 to 19/21 for a few sec, in this time the video stops.
I'm using a i7 7700k, should I set the decoder queue higher then the default to fix the problem?
LG 27MU67-B, i7-7700K, MSI GTX 1080Ti Gaming X, MPC-HC / MPV
Old 6th October 2017, 13:52   #46230  |  Link
ryrynz
ryrynz's Avatar
Been noticing a few instances recently with seeking where the picture freezes but audio continues. Seeking sometimes fixes it. Was using NGU Sharp and d3d11. Haven't done any testing. Anyone else had this recently?
Only appear to have this happening when I pause.
Old 6th October 2017, 14:03   #46231  |  Link
Tobiwan
Tobiwan's Avatar
Audio continues and picture freezes yes, but I only have the problem on low quality videos. I test it with NGU AA, Sharp, xbr, and CIVID, D3D11 but there was no different.
I only found that decoder queue overflow at seeking.
Old 6th October 2017, 14:59   #46232  |  Link
mzso
Hi!
Can anyone tell me how do I use the madVR internal decoders? They don't appear as a system codec so I can't set them in media software to be used. So how?
The DXVA decoders are surely there because apparently they somehow got enabled in strange circumstances:
Even deinterlacing started working. So how do I the built in decoder normally?
Old 6th October 2017, 15:37   #46233  |  Link
nevcairiel
madVRs built-in decoders have been removed a long time ago, in v0.87.15 to be precise. If the OSD says DXVA, that means the decoder is delivering frames in DXVA2-Native mode, but not that madVR is doing the decoding.
nevcairiel is online now   Reply With Quote
Old 6th October 2017, 16:04   #46234  |  Link
strumf666
Official comparison by madshi available here:
http://www.madvr.com/
Unless you have a very bad eye sight (or something terribly wrong with your display), the difference in sharpness should be very apparent when watching a movie. You can also make a screenshot of the same frame using different scalers, for comparison, but if you do not see the difference during playback it's a waste of time.
strumf666 is offline   Reply With Quote
Old 6th October 2017, 16:05   #46235  |  Link
mrmarioman
mrmarioman's Avatar
Quick question.
So what's the better/right option here for HDR movies?
madVR: 0-255 nvidia: 0-255 TV: 0-255
madVR: 0-255 nvidia:16-235 TV: 16-235
in some movies with everything set to full-rgb the blacks look washed out.
mrmarioman is offline   Reply With Quote
Old 6th October 2017, 16:14   #46236  |  Link
mzso
Well, I saw that, but it only says "removed software decoders" and not DXVA decoders. So that's confusing.
Also, I tried removing the files and it works the same way. Which is even weirder. Maybe LAV wasn't working at all this way?
The icon certainly didn't appear and the settings certainly don't reflect using DXVA. (I don't see LAVVideo.ax in the threads either.)
Where are the settings for LAV Video normally stored?
Old 6th October 2017, 16:15   #46237  |  Link
nevcairiel
There never was anything but the software decoders in the first place.
Old 6th October 2017, 16:39   #46238  |  Link
el Filou
el Filou's Avatar
@mzso I reinstalled ProgDVB and tested again. With the default config you're indeed right that deinterlacing gets turned off after the first channel change and there is no way to get it enabled again without fully stopping and opening a channel again.
Fortunately I was able to fix it by changing this setting in the options: Main => Speed of channel changing = Fast
Note that this value probably requires that the same decoder filters be used for all formats because they are kept active upon channel change. It's not really a problem because you can use LAV for all formats.
Afterwards, deinterlacing stays on even after a channel change.
Please confirm it works on your side too so I can uninstall ProgDVB, I can't stand this software.
Old 6th October 2017, 16:42   #46239  |  Link
Asmodian
Originally Posted by mrmarioman View Post
Quick question.
Those are both correct, the first is preferred but they should look basically the same if the TV handles both limited and full range correctly.
HDR or not changes nothing. How are you displaying HDR? If you are using pixel shader math to convert to SDR try turning up "this display's peak nits:"
Old 6th October 2017, 17:00   #46240  |  Link
Tobiwan
Tobiwan's Avatar
Is D3D11 faster then CUVID or the same at the end? What's the benefit?
