27th May 2005, 18:36 | #163 | Link | |
Life's clearer in 4K UHD
YAMB 1.3 Alpha1 v1
Just to let you know when I tried "version 1" earlier today I got this: - Currently I have NeroDigital DSdec filter, parsers etc and XviD's DSdec filter installed. The encode contained Mpeg4 SP video and 1No AAC-LC audio stream with no chapters, subs or MetaData. Cheers
27th May 2005, 22:30 | #165 | Link | |
There's no audio rendering at all... Bummer!
28th May 2005, 05:28 | #166 | Link |
Always trying
Yamb 1.3 alpha1
File - Nero Avc video (Haalis,ffdshow,videorenderer) File - x264 video (Haalis,ffdshow,videorenderer) File - Xvid video (Haalis,ffdshow,videorenderer) All files had Aac (Haalis,CoreAacDec) 1-4 streams . One file with x264/5.1Vorbis (Haali's,CoreVorbisDec) , some had ttxt's and chapters too and a few older Xvid were muxed with 3ivx. (about 20 mp4's total were opened sucessfully , viewing/seeking) Disabled ffdshow and used nero's decoder for avc, got "pins are not connected" error but a seperate active movie window appeared that I could seek in. under this configuration graphedit would render NeroAvc/x264 files with no errors [Haalis,nerodecoder,videorenderer) Did not try nero splitter. Switching input content (Avc - Xvid) while using nero's decoder, Yamb became unresponsive. (More) NDParser.ax with ffdshow = frozen Yamb NDParser.ax with nero decoder = buggy , opens 2nd active movie window but with pin connect errors , file will show and seek. Last edited by Koti; 28th May 2005 at 16:34. |
28th May 2005, 11:01 | #168 | Link | |
So the problem must be with Nero's video DSdec and/or parser! Cheers
28th May 2005, 16:28 | #169 | Link |
I tested a Nero AVC + AAC video and the Mediacontrol AniMatrix Sample from the Osmo4 page and got identical results, i.e. works perfectly if Haali Splitter and ffdshow are used but fails when either the Nero splitter or Nero Audio dshow filters are used.
@SeeMoreDigital: Haali->Nero Video Decoder->Video Renderer \----->ffdshow Audio decoder->Directsound Seems to work fine in Graphedit as well (though not with YAMB), trying to replace ffdshow with Nero Audio Decoder did not work at all. It looks like its the Nero file source/splitter that causes the problem, the audio decoder not working is fairly minor by comparison (still annoying though). Ooops, I forgot to say thanks to Kurtnoise13, YAMB is already quite handy and getting better by the day keep up the good work. Last edited by OddbOd77; 28th May 2005 at 16:34. |
28th May 2005, 17:10 | #170 | Link |
Swallowed in the Sea
Today I tested with different samples...and same conclusion. I don't know if it's good or bad (ie I don't want to force people to install some other filters). So, for the moment I stick around with import Settings and I'll see this trick after the next release. |
28th May 2005, 17:21 | #171 | Link | |
nero's filters have lots of limitations, i wouldnt be surprised at all when there is some mechanism that restricts their useage in an external tool, like yamb
4th June 2005, 12:15 | #172 | Link |
Hi Kurtnoise 13! It's a great GUI your Yamb! I was thinking, if is not possible to include an option to mux the subtitles in VobSubs, like it does Nero Recod? so it's possible to watch them on a Nero Digital certified player.
Tnx! |
4th June 2005, 15:41 | #176 | Link |
Yes, but I have to mux a DX50 MPEG-4 with an AAC audio stream and a subtitle stream (ssa that I've converted to srt) and I don't want to recode them, I've already recode the audio (all these files come from an mkv with ac3 audio).
Maybe I will convert it to avi, it's the better way..... |
4th June 2005, 16:11 | #177 | Link |
kurt meant that nero recode is the only tool that places vobsubs in .mp4, not that you have to reencode audio and video
4th June 2005, 21:10 | #179 | Link | |
simply convert the vobsubs to .srt for example and than place them in .mp4 with yamb/mp4box
4th June 2005, 21:13 | #180 | Link |
I agree with you Hyper Shinchan. I would post a request to jeanlf myself... but he frightens me
Cheers
