24th February 2004, 21:45 | #41 | Link |
retired developer
About audio, In the Files source, it might have 5.1 and 2.0 (AC3) and 5.1 and 2.0 (AVI). That's why I need 3 settings, or else I will have to guess what codec to use...
Detritus Software |
25th February 2004, 10:00 | #42 | Link |
You could have only one option set for audio and add some check boxes to select channel number.
Ps. Adding Vorbis audio encoding would be interesting.
A/V moderator @ hydrogenaudio.org My weird old sh*t: http://www.nic.fi/~lhahne/ http://last.fm/user/Latexxx/ |
25th February 2004, 13:06 | #43 | Link |
retired developer
won't work.
If I want HE-AAC for 2.0 and cook for 5.1?
Detritus Software |
28th February 2004, 23:14 | #45 | Link |
retired developer
might be related with XviD + DirectShow. Nothing I can do
Detritus Software |
29th February 2004, 04:29 | #46 | Link |
Almost Silent Member
XviD RC2 can be decoded by DivX's Support Generic MPEG4 decoding, which is selectable in the DivX Decoder Configuration Utility.
You could also try changing the fourcc code to DX50 if it's current fourcc is XVID.
Rethinking the "Why?" chromosome. |
29th February 2004, 05:13 | #47 | Link |
retired developer
but as far as I remember, this thread is not related to XviD problems.
Detritus Software |
29th February 2004, 17:18 | #49 | Link |
retired developer
Hum... don't use the preview. Seems it uses 100% of the CPU to do insane "waiting"
[edit] Good, in normal uses YS RealAnime uses onlu 0-2% CPU. The 100% thing was related to this bug.
Detritus Software Last edited by Sirber; 29th February 2004 at 17:37. |
29th February 2004, 17:54 | #51 | Link |
retired developer
I would have finished if I restarted it in vb6, but this is Delphi men! Encoding currently works but still need tweaking and validation. I'm working right now on batching, audio encoding and muxing. Sylvain will work on simple mode soon. Simple mode might be the first thing to work ok, since expert is kinda big.
Detritus Software |
1st March 2004, 14:07 | #53 | Link |
retired developer
yep, read first post.
Detritus Software |
6th March 2004, 04:13 | #55 | Link |
retired developer
I'm getting bored of my RealAnime 2.00 dev-test build with "lost core source". I will release tomorrow Preview 2 with working batch.
Detritus Software |
6th March 2004, 17:06 | #56 | Link |
retired developer
Hi mates!
I spoke with Shinobu some days ago and we got a nice idea: LAN encoding. Since YS RealAnime first goal is batching, why not sending files to encoders on a private LAN? All comments are welcome
Detritus Software |
6th March 2004, 17:19 | #57 | Link |
do you mean e.g. install YS realanime in computer A, and use it to directly encode files in computer B and directly save the resulting rmvb in computer B?
if yes that's awesome! I love this feature, I can use a faster pentium computer to encodes file downloaded in another slower athlon computer! ^^ |
6th March 2004, 17:25 | #58 | Link |
retired developer
Exemple:
Computer A: YS RealAnime Computer B: YS RealAnime Encoding Slave A has 3 jobs with 30 files each. A start Job1/File1 and send Job1/File2 to B. A and B start encoding. B finish Job1/File2 and send the resulted file back to A. A send Job1/File3 to B while finishing encoding Job1/File1. If B get some errors, the error is sent back to A for analisis. If B loose connection with A, A resend the file to another slave or encode it itself. All jobs are controled by A. B only recieve files, settings and return the encoded file. Imagine if you have... 10 2GHz computer in LAN?
Detritus Software |
6th March 2004, 19:25 | #59 | Link |
retired developer
*** Preview 2 released ***
http://www.webernic.com/sites/sirber...lAnime_001.exe (7MB) http://www.webernic.com/sites/sirber...me_001.exe.sig Note: * Only Expert mode works, so please be sure to choose it * Only input supported is AVI. * You have to add at least one job to be able to encode. * There is almost no validation in settings. Comments are as usual welcome
Detritus Software |
