20th August 2017, 02:41 | #44881 | Link | ||
Is there any advantage in quality to do that with a GT60 and would it benefit madVR? Panasonic says it has "24576 steps of gradation", which from the way they calculate that number supposedly equals 13 bit, but I have a hard time believing that. Quote:
Yes, it's always best to use the latest version whatever the hardware as long as it meets the minimum requirements (= GPU with D3D9, which your GT730 does). Luma is more important than chroma, so always use a better upscaling method for luma. Try successively better ones until you see that your GPU is dropping frames and then back down one level.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 Last edited by el Filou; 20th August 2017 at 03:12. |
20th August 2017, 05:57 | #44882 | Link | |
20th August 2017, 06:25 | #44883 | Link |
Before madVR i've used CRU to create custom display modes, but mode switching in madVR didn't work properly. After 0.92 release i've realised that my WQHD display EDID data is somehow corrupted and madVR shows that it's native resolution is 1920x1080. I did reset display modes back to default with CRU "reset-all" tool and now madVR can create and switch custom display modes!
I'm infected with poor sources. |
20th August 2017, 07:50 | #44884 | Link | |
nvidia drivers 385.28 MPC-HC (x64) 1.7.13 madvr 0.92.1 lav 0.70.2 I am on windows 10 Pro 1703 (x64) with the latest aug update. Please note that only 3D files work when I enable stereoscopic 3D in nvidia. I get a crash for any 2D file. Its not really a problem as I use a batch file to enable 3D, play the 3d file and then disable 3D. |
20th August 2017, 08:24 | #44885 | Link | |
Soul Seeker
20th August 2017, 08:31 | #44886 | Link |
So far I've only been testing 23p custom resolutions.
My setup is: sony 1080p tv nvidia 1070, 385.28 driver mpc-hc 1.7.13.89 madvr 0.92.1 lav 0.70.2 windows 10 pro I've found that my custom resolution works only if I have FSE enabled. FSE On, DX11 Off -> fullscreen ok, -> windowed ok FSE On, DX11 On, -> fullscreen ok -> windowed defaults to nvidia profile FSE Off, DX11 Off -> fullscreen defaults to nvidia -> windowed defaults to nvidia profile |
20th August 2017, 09:04 | #44887 | Link | |
Thanks Madshi. K Update - after testing further, I have to say, with the patch and the latest release, this is the most rock solid stable and best release so far! well done (I always use FSE Exclusive) Last edited by oldpainlesskodi; 20th August 2017 at 09:34. |
20th August 2017, 09:08 | #44888 | Link | |||||||||||
http://madshi.net/madVR0921b.rar |
20th August 2017, 09:14 | #44889 | Link | |
Also If I switch to full screen exclusive it doesn't crash. That way it switches from 60hz to 24hz without a problem. DXVA2CB, fullscreen windowed 10-bit, going full screen from 60hz to 24hz = no crash DXVA2CB, fullscreen exclusive 10-bit, going full screen from 60hz to 24hz = no crash DXVA11, fullscreen exclusive 10-bit, going full screen from 60hz to 24hz = no crash DXVA11, fullscreen windowed 10-bit, going full screen from 60hz to 24hz = crash DXVA11, fullscreen windowed 10-bit, going full screen from 60hz to 60hz = no crash DXVA11, fullscreen windowed 10-bit, going full screen from 24hz to 24hz = no crash Tested with Windows 10 and MPC-BE x64 all latest nightlies. Last edited by FDisk80; 20th August 2017 at 09:27. |
20th August 2017, 10:26 | #44894 | Link |
Colored steps in RGB? 24576 is suspiciously 3x 8192.
20th August 2017, 11:11 | #44896 | Link |
No. SLI does not benefit madVR at all.
20th August 2017, 11:45 | #44897 | Link | |
I did use "reset all" and made a fresh driver install after I stopped using CRU and reverted back to Reclock. But I think somehow something got screwed up OS wise: as cork_OS mentionned, I think it did something to the way the EDID of my TV setup is read, only "reset all" didn't work for me. After using CRU, the native resolution for my AVR / TV was 1080p whereas beforehand it was 2160p. I frankly don't want to make you lose time over this until I do a fresh Windows install to be sure.
OS: Win10 1703 GPU: GTX 1070 (latest stable drivers) Monitor: LG OLED55B6V TV / Yamaha RX-A860 AVR Media setup: MPC-BE x64, madvr, lav filters (nightly) |
20th August 2017, 13:14 | #44899 | Link | ||
The Nvidia control panel shows the original 23Hz mode and a custom 24Hz mode. But both result in switching to the optimized 23.976 Hz mode. No way to get 24Hz from nvidia control panel. This is what it looks like: http://imgur.com/a/b5mI8 Quote:
20th August 2017, 13:45 | #44900 | Link |
Another bug I've found is if I skip to different part of the file I'm playing either with chapters or the timeline and pause it immediately before the queues fill it, and attempt to play it, it'll stop responding and I have to close the media player with Task Manager. Sometimes I'll be playing a file and accidentally pause it after skipping to a chapter and then it will no longer play.
Let me know if you need more info. |
