8th November 2015, 04:59 | #34103 | Link |
Crispen edges (and the old FineSharp) suffer a lot in enhancing source aliasing.
Posterized (cel shading) images get dramatically changed by thin edges set at high values, but this is probably by design. So far so good. Enjoying the new algos. |
8th November 2015, 05:57 | #34104 | Link |
Is it possible to improve the performance of Sharpen Edges for fair testing? It is far too expensive on my system.
8th November 2015, 06:02 | #34106 | Link | |
Same here
Intel Core i7-4790 CPU @ 3.60GHz, RAM 32 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24), Panasonic TX-P42G20E, NVIDIA GeForce GTX 970, Win 10 Pro x64, PotPlayer 1.7.16291 64-bit, madVR v0.92.17 |
8th November 2015, 07:22 | #34108 | Link |
No, I use default settings for upscaling/downscaling, not DXVA ...
8th November 2015, 08:12 | #34110 | Link |
Madshi,
All features are running perfectly. Only draw back is it added addition 10ms on rendering time from my default of around 12ms. I'm now getting around 22 to 23ms
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
8th November 2015, 09:01 | #34112 | Link |
madshi,
Here is a new sample, the same original DVD sample I uploaded but has a re-cap of events in the first movie that plays before starting. I cut it to reduce the size of the original but is seems to be the cause of the problem. https://www.dropbox.com/s/6ifrmre5xl...tdisc.zip?dl=0 Zoom control settings used. move subtitles, to bottom of the screen / window. automatically detect hard coded black bars. notify media player about about cropped black bars, no more than once every 2 sec. keep black bars visible if they contain subtitles, forever. The black bars are being cropped, it seems to be working as intended in ver 0.89.9. I tried disabling the move subtitles option but it had no effect. Thanks. |
8th November 2015, 12:44 | #34114 | Link | |
Some times it switches when playing video first time but does not switch when playing the second. |
8th November 2015, 12:53 | #34115 | Link | |||||
When using a newer nightly LAV build, madVR should be able to move the subtitles either into the black bars or into the active video area. However, these are bitmap subtitles, which means that for optimal quality madVR has to draw them onto the decoded video image before doing any scaling, because only this way the subtitles will get the full quality benefit of the scaling algorithm you've selected. Having to draw the subs before scaling means that if you tell madVR to actually crop the black bars away, there's no black bars left for madVR to draw the subtitles into. So if you want the subs to be drawn into the black bars, you have to deactivate the option "crop black bars" in the zoom control settings. (Please note that this only applies to bitmap subtitles.) Quote:
Can you please try if anything changes if you use software decoding? Also, can I have a debug log from a failure situation (I don't need one from a success situation)? Thanks. |
8th November 2015, 13:00 | #34116 | Link |
madVR v0.89.15 released
http://madshi.net/madVR.zip Code:
* fixed: black screen with some decoders (introduced in v0.89.14) * fixed: black screen with DXVA processing in some situations * added "superResRadius" file name tag for testing purposes |
8th November 2015, 13:13 | #34117 | Link |
Bug report: AR video is broken in 0.89.14 and 0.89.15. Works ok with older versions. Tested this on 16:9 video with ass subs, which is for whatever reason displayed as 4:3 video (and the subs are offset badly). Sample here.
Last edited by KoD; 8th November 2015 at 13:23. Reason: it looks like AR video is broken, not ASS subs positioning |
8th November 2015, 13:27 | #34118 | Link | |
8th November 2015, 13:35 | #34119 | Link |
It happens with both latest two MPC-HC nightly builds (190 and 202). Having "keep aspect ratio" checked or not does not matter. The sample I provided is only 500Kb, so it's easy to download it and test.
Edit: looks like madVR ignores the container set AR (which is 16:9) and instead uses the video stream AR (which is 4:3). Last edited by KoD; 8th November 2015 at 13:47. Reason: for edit |
8th November 2015, 13:38 | #34120 | Link | |
Debug log: https://drive.google.com/file/d/0B7a...w?usp=sharing] |
