20th February 2017, 21:58 | #14722 | Link | |
guide for DVD boxset
Is there a RipBot guide or tutorial that can get me going in the right direction to accomplish this? I only have used it to batch .mkv's into .mp4s. At most the only advanced feature is changing it from 1080p to 720p.
21st February 2017, 14:11 | #14723 | Link |
By the way, in RipBot, is 22 CRF an acceptable setting for a DVD TV series rip? I'ts an older TV show, I Dream of Jeannie. So not a lot of fast motion scenes. I have been doing 2 pass 2048KBS on all my TV shows, regardless of BD or DVD, new or old. From what I am reading, I am overkilling the DVD with 2048 kbs on old DVD TV Shows.
21st February 2017, 14:26 | #14724 | Link | |
24th February 2017, 22:50 | #14725 | Link |
ByteShare
@Atak_Snajpera I know it would be a lot of work, and I'm not trying to pressure, but have you looked at using newer mvtools? https://github.com/pinterf/mvtools/r...s/tag/2.7.9.22
It includes some speedup improvements for MDegrain1-6. I tried using it with RipBot and it errored out so I think maybe it has something to do with another dependency? If it can't/won't ever happen no worries, I use the program a lot as is. HandBrake doesn't even have a denoise as good as mdegrain in RipBot Last edited by byteshare; 24th February 2017 at 22:53. |
26th February 2017, 16:11 | #14726 | Link |
Atak_Snajpera, would it be possible to add a some CLI support to ripbot? I'd like to be able to add encodes to the list.
Something like the follow command ripbot source dest x265 audio1 5.1 ac3 It would ideally use the default HEVC profile. I'm hoping to automate this with a powershell script I have been using. Thanks love Ripbot264!! |
26th February 2017, 18:44 | #14727 | Link | |
Just copy mvtools2.dll from x86 folder and it will work. @brumsky I will think about it.
28th February 2017, 04:38 | #14728 | Link |
ByteShare
Maybe I'm doing it wrong?
I downloaded: https://github.com/pinterf/mvtools/r.../tag/2.7.14.22 copied the mvtools2.dll from the x86 folder in the .7z to my C:\RiptBot\Tools\AviSynth plugins\mvtools\ folder (copied the one in their to somewhere else and then over write the one there. When I try to preview: Code:
LoadPlugin: unable to load "C:\RiptBot\Tools\AviSynth plugins\mvtools\mvtools2.dll", error=0xc1 (C:\Temp\RiptBot264temp\job384_preview.avs, line 33) Code:
Application error: Exception EFOpenError in module EncodingClient.exe at 0002411A. Cannot open file "C:\Temp\RiptBot264temp\job384\info.txt". The system cannot find the file specified. This is my Denoise code (default): Code:
#Denoise Loadplugin("C:\RipBot\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) fv1=MAnalyse(super,isb=false,delta=1,overlap=4) bv1=MAnalyse(super,isb=true,delta=1,overlap=4) fv2=MAnalyse(super,isb=false,delta=2,overlap=4) bv2=MAnalyse(super,isb=true,delta=2,overlap=4) video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=400) Last edited by byteshare; 28th February 2017 at 04:51. Reason: More info |
28th February 2017, 13:23 | #14729 | Link |
28th February 2017, 21:48 | #14730 | Link | |
ByteShare
Visual C++ Redistributable for Visual Studio 2015 x86 Visual C++ Redistributable for Visual Studio 2015 x64 Which I had done on my other computers but not the issue one...had been a while since I had to do that so I forgot |
1st March 2017, 18:16 | #14731 | Link |
@Atak
for a few days now, when I search for a cover, I get a list with names and covers, but the first column with the year is empty
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
1st March 2017, 18:51 | #14732 | Link |
They have once again changed something. I will take a look tomorrow.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 1st March 2017 at 19:00. |
5th March 2017, 10:29 | #14735 | Link |
Having an issue here with DE that I'm sure is particularly simple.
Got an encode going on the main PC. Two other pc's on the LAN- one is helping with the encode, but the other one just sits there flicking between "Idle" and "Encoding". Over and over and it's infuriating. It's a clean install. Any ideas as to the issue? |
5th March 2017, 13:37 | #14736 | Link |
Try to capture error message in EncodingServer app. (screenshot)
6th March 2017, 00:17 | #14737 | Link | |
Worked for me.... |
6th March 2017, 11:17 | #14738 | Link |
I had all my servers doing that yesterday, then I noticed it was trying to encode one that had already been done. Don't know if I'd inadvertently ticked the check box, but the servers were complaining the file was missing which it would be as I'd deleted it. But surely the main program should simply skip it if the files missing rather than trying to encode it?
I'm sure I've mentioned this before. |
6th March 2017, 18:29 | #14739 | Link | |
On another note, I've been getting errors with some videos when attempting to do the autocrop feature. I get this for avs2avi.exe. Code:
Problem signature: Problem Event Name: APPCRASH Application Name: avs2avi.exe Application Version: 0.0.0.0 Application Timestamp: 40eb0522 Fault Module Name: msvcrt.dll Fault Module Version: 7.0.9600.17415 Fault Module Timestamp: 54504b2e Exception Code: c0000005 Exception Offset: 0000c24e OS Version: 6.3.9600.2.0.0.400.8 Locale ID: 1033 Additional Information 1: 5861 Additional Information 2: 5861822e1919d7c014bbb064c64908b2 Additional Information 3: 6ee2 Additional Information 4: 6ee2432e64e99bdcea5e4be767a3b1a2 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=280262 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt Thanks again! |
6th March 2017, 20:21 | #14740 | Link | |
ByteShare
Do you have: Visual C++ Redistributable for Visual Studio 2015 x86 Visual C++ Redistributable for Visual Studio 2015 x64 Installed? (Some say just x86 is enough) If not try that. I've had issues like that before. |
