Old 30th August 2016, 19:30   #21  |  Link
candela
Originally Posted by dizzier View Post
That's a pity ;( Try this one
| HC | HOST_PRIV_KEY 0x5F291AE7CF68D67F58689A4CBFE2953064539FAA \
     | HOST_CERT 0x0203005CFFFF8000018900003E7C4B0931C0045D \
                 0xFB017F24B1557F5BD0AF5B961FBC1B43519F9023 \
                 0xA1E84A3E8C06967B76469CC86527AA3807258C58 \
                 0xE00F73971F9BC8353165476454911E3A9D07D742 \
                 0x980598BFF9B3DF5EA18E0C7F
Thanks it works with VLC (it generated VUK for MKBv4 disc) but with aacskeys-0.4.0e I get an error
Problem with verifying the host signature.
ERROR: AACSVERYIFHOST, errnr: -1
Any idea why that is? It always worked with your previous certificates. Copied like this in HostKeyCertificate.txt
0203005CFFFF8000018900003E7C4B0931C0045DFB017F24B1557F5BD0AF5B961FBC1B43519F9023A1E84A3E8C06967B76469CC86527AA3807258C58E00F73971F9BC8353165476454911E3A9D07D742980598BFF9B3DF5EA18E0C7F
candela is offline   Reply With Quote
Old 31st August 2016, 08:30   #22  |  Link
dizzier
Because there is additional bit set in the certificate. This has nothing to do with disc playback (the additional bit is related to disc writing), but aacskeys stubbornly refuses to load such certificate. You must modify the condition in aacs_set_cert() function in aacs_ecdsa.cpp to get it working.
dizzier is offline   Reply With Quote
bluray, bus encryption, mkbv47, vuk
