12th August 2014, 02:55 | #822 | Link | |
12th August 2014, 04:32 | #823 | Link |
Most programs I've tried (Virtualdub, etc.) just crash out without giving me much info.
But AvsPmod generates the following error messages using johnmeyer's altered script on a video: Traceback (most recent call last): File "avsp.pyo", line 9379, in OnMenuVideoToggle File "avsp.pyo", line 14234, in ShowVideoFrame File "avisynth.pyo", line 464, in GetFrame WindowsError: exception: access violation reading 0xFFFFFFFF This happens no matter which version of Avisynth I have installed, it seems. Could the problem be that I'm on Windows 8.1 x64? Maybe Avisynth doesn't work with this OS? |
12th August 2014, 19:01 | #825 | Link |
Yes, I even double checked to be sure. I'm using the provided plugins & dll's.
I'm wondering if it is K-Lite Codec pack or that damn LAV Decoder/Splitter/Virus I've tried enabling and disabling all sorts of codecs/splitters, etc. using the codec tweak tool from K-Lite. The video I'm trying to use with Avisynth is compressed with Lagarith, no audio. In Windows 7 x64 it worked just fine with Avisynth (same video) but since upgrading to Windows 8.1 x64 (clean install) I can't get these cleaning scripts to work... also having trouble with QTGMC and AnimeIVTC as well. Ugh... I want to pull all my hair out. I *need* these to work. Last edited by Ultimist; 12th August 2014 at 19:44. |
12th August 2014, 22:25 | #826 | Link |
ангел смерти
Using what source? FFVideoSource, LWLibavVideoSource, and Avisource (with Lagarith VFW installed) would be preferred for that; DirectShowSource is generally the option of last resort. (That's the only way K-Lite or Lav filters would be used.)
15th October 2014, 17:23 | #827 | Link |
If I wanted to use Fred's or John's modified version of the script and my video won't load properly using AVISource and needs DirectShowSource can the script be modded to work? I know using AVISource and just passing .killaudio() works, but there must be something in the script stopping it from working. Have seen in the past with DV content that DirectShowSource usually loads better for me. If I try loading the avs file in Windows Media Player it just crashes.
Note the computer I'm working on has no working soundcard so have seen it cause issues in the past but not sure if that's the case here when as mentioned AVISource works fine with the killaudio flag, just not here. Another note, loads in VirtualDub but the minute I try to move thru the video it crashes with "An out-of-bounds memory access (access violation) occurred in module 'ntdll'... ... reading address DDDDDDDD." If I open it in VirtualDubMOD I get: "Couldn't locate decompressor for format 'YV12' (unknown)". Then also get a memory error. JR Last edited by jriker1; 15th October 2014 at 17:51. |
16th October 2014, 11:02 | #828 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Hint: Helix Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
17th October 2014, 17:10 | #829 | Link |
visible Halo's around moving objects
I have processed several 8mm movies with the scripts of Videofred and JohnMeyer. I am really astonished about the good results I get with my 8mm films and these script-processing. I was able to restore, decoloured, grainy, shakey, jittery films with great success. Thanks to VideoFred and JohnMeyer.
But one thing bothers me often: I always get a certain halo of not removed grain around all moving objects (faces, hands, cars etc.) . This can be very ugly. Especially if I recompress the uncompressed AVI source to and MPEG2 DVD file. Then these sequences are not anymore usable. The grainy halo is strongly visible, which is very nasty. I tried to lower the degrain but the good Overall Impression gets worse, which is a pitty. Has anyone a remedy against this "halo - thing"? Thank You for Your estimated help.
Lenovo Intel i7Quad/WIN8 - Virtual Dub 1.10.4/Avisinth 2.6MT- MacMini I7 QuadCore Last edited by papcom; 17th October 2014 at 17:12. |
17th October 2014, 17:37 | #830 | Link |
It's the sharpening. VideoFred processes film that is very pristine and new, and the initial sharpening settings in his script are designed for that source material. For many other types of film, you need to reduce the sharpening settings, sometimes by quite a lot. The degrain and dirt removal are different than the sharpening, so you may not need to reduce those. Try setting all the sharpening settings to zero, or near-zero and see if you like the results better. I think in VideoFred's latest scripts the sharpening parameters are in the section of the script labeled "Four step sharpening parameters."
Less is more. |
17th October 2014, 19:08 | #831 | Link |
17th October 2014, 19:59 | #832 | Link |
i noticed the difference with the sharpening when I used JohnMeyer's Script instead of VideoFred's.. The halo effect was almost gone, but of course the sharpness too.
It would be very helpfull if You could provide certain values regarding the sharpening. Actually I use the following (see below), which is fairly near to my the original captured film. Although I would prefer a bit more sharpness, how can I achive it without the halo's? Generally spoken I sometimes prefer using Videofred's Script because it does not Crash so often! Sorry John Meyer, dont get me wrong... on the other side Your script has more explanations and produces very nice results... Also when I use 2.6 Multithreading it it kills the process on my WIN7 machine too often. Code:
#FOUR STEP SHARPENING PARAMETERS #-------------------------------------------------------------------------------------------------------------------------------- PRE_sharp_ness= 120 PRE_radi_us= 3 #presharpening (UnsharpMask) just after first denoising #PRE_sharp_ness= 85 PRE_radi_us= 3 #presharpening (UnsharpMask) just after first denoising LSF_sharp_ness=160 LSF_radi_us=2 LSF_sub=1.5 #second sharpening parameters (LimitedSharpenFaster) sub=subsampling #Sharp_Strength = 0.4 Sharp_Strength = 0.1
Lenovo Intel i7Quad/WIN8 - Virtual Dub 1.10.4/Avisinth 2.6MT- MacMini I7 QuadCore Last edited by papcom; 17th October 2014 at 20:30. |
17th October 2014, 20:29 | #833 | Link | ||
Sharpening without creating halos is the holy grail of sharpening, and so far such a creature does not exist. However, you might try removing the sharpening used by the existing script and use instead a more sophisticated sharpener, like the LimitedSharpenFaster.avs script created by Didée. Quote:
The part of your statement that is puzzling, however, is your claim that my script is slower. The whole reason I created my version of the script, and added the multi-threading was to improve performance, and in that effort, I succeeded. I did extensive tests several years ago, and my version should be about 2-3 times faster, i.e., a very big difference. The fact that you are getting slower performance with my version of the script leads me to believe that you don't have your system set up correctly to use multi-threading. Only certain versions of AVISynth work with the SetMTMode() architecture. VideoFred's version has a lot more settings for color correction and sharpening which I didn't take forward into my version. You pays your money and you takes your choice. |
18th October 2014, 00:13 | #834 | Link |
@John Meyer - thank You for Your reply.
If You check my posting before, You see that i did not write anything about speed. (message edited!) Actually I completely refrain from using any script in a MT - environnement (AVISynth 2.6). I had too much difficulties, and I could not find out why. So I use Your script and VideoFred's script both in the normal manner. When I load Your script in Vdub 1.9.x it does the Job if I do not scrub on the timeline, but it crashes immediately when I click reopen video (e.g. after editing the script in AVSedit.)... also it crashes when I quit VDub. Unfortunately I do not understand Your Phrase: "You pays your money and you takes your choice. " It would be really helpful if there would be some kind of manual for these scripts, how to use all the Parameters and how they correspond. The inline help is good, and in Your script even more informative, so I learned a lot. On this base I have worked for many dozens of hours with the scripts, but I always have my difficulties with the sharpening and the denoising Parameters, as I have written in my posting before.
Lenovo Intel i7Quad/WIN8 - Virtual Dub 1.10.4/Avisinth 2.6MT- MacMini I7 QuadCore Last edited by papcom; 18th October 2014 at 00:23. |
18th October 2014, 01:49 | #835 | Link | ||||
It was a lame attempt at being light-hearted. Quote:
Speaking of sharpening, which is your main problem, I just searched VideoFred's entire script using the search term "sharp" and in addition to three "USM_sharp_ness" parameters (all of which I'd recommend you set to 1, until you get sharpening you like) there is what looks like a "hard-wired" sharpening step in this line: stab5= Lanczos4Resize(stab2,W,H).sharpen(0.5) I'd delete everything to the right of the period, i.e., remove: .sharpen(0.5) |
18th October 2014, 10:12 | #836 | Link |
Thank You JMH for Your hints.
I'll go on trying different parameters on the sharpening etc. Anyway I am feeling a little bit in the mist, because I do not understand it. Why use 16 in blocksize and 8 in blockover ...and not 11 and 7 ?. What is the explanation behind this figures. These dependencies I am interested in. The similar Problem I do have with the Auto Level Parameters: What is X and X2 ... I tried extreme values like 50 and 100 but I did not see any difference. Another Thing ist the Output videoformat. Which one is the recommended Output Format? I do not understand the relation to YV12 in the script? I thought YV12 is 8bit Yuv Format but finally it is e.g. Vdub which determines the Output ...isn't it? So what is the reason and/or the function of YV12 in the script? Until today I choose the Output Format in the Video Compression of Vdub and I save the AVI with the choosen compression or lossless uncompressed. As I often work on a Mac I need to import the Output file from Vdub Win PC to Mac which can be very tricky because the Mac does not accept any Format. E.g. I was not able to Import an uncompressed AVI and use it in the Mac. It worked with BMD-422-10bit codec, because I have BMD devices in both Computers and this codec is on the machine. But of course I would prefer uncompressed . Does anyone have any suggestions?
Lenovo Intel i7Quad/WIN8 - Virtual Dub 1.10.4/Avisinth 2.6MT- MacMini I7 QuadCore Last edited by papcom; 18th October 2014 at 15:33. |
18th October 2014, 17:26 | #837 | Link |
You have a lot of different questions, and I don't think I can answer them all, but I'll try to answer a few of them.
Block Size and Block Overlap are used by the MVTools (or MVTools2 for my script) motion estimation code. These functions analyze groups of pixels ("blocks") that are 4x4, 8x8, or 16x16 size. These are the only values allowed (4, 8, 16). Thus, you cannot use numbers like 7 or 11. The "overlap" parameter causes the estimation to create blocks of pixels which overlap each other so that you get smoother results (i.e., no discontinuity between blocks of pixels). The more overlap, the slower the script. It can be no larger than one half the block size. I either use no overlap, or the smallest overlap allowed. In my latest version of the script, I do a two-step version of motion estimation, using two different block sizes. This seems to operate slightly faster, and provide very slight improvement in results. X2 is a parameter that temporarily creates a small border around the video prior to applying the Autolevels filter. This border is then immediately removed after applying that filter. It provides a way to "fool" the Autolevels filter into creating the correct levels by creating a pure black reference around the frame. VideoFred later completely re-wrote his script to change how the automatic levels are created. So, his script no longer uses the Autolevels filter, and therefore no longer uses this variable. I have still never found any auto level filter that works consistently well, and therefore edit levels by hand in my editing program (Sony Vegas Pro) before exporting the video to the script, so I never use this function, and therefore never spent any time trying to improve on VideoFred's work. If you want to use the Autolevels function, then you should use his versions of the script, not mine. All that is needed is to create a border, so changing the values of X2 and X will not do anything useful. I am therefore not sure why VideoFred created these as a variables. The color space that you use depends, first of all, on the filters in the script. Most AVISynth filters require YV12. Many codecs work with this color space, so I usually don't need to make any further color conversions. I always avoid using uncompressed. There are so many good alternatives, that I see no reason to ever do this. For me, I always use frame serving to pass video from one process to another. That provides all the benefits of uncompressed, without the two major downsides: disk performance bottlenecks, and disk space. The simplest alternative to uncompressed is to use a lossless codec, like HuffYUV or its newer alternative, Lagarith. Better yet, there are some very high quality lossy codecs that are so good that they are called "intermediate codecs," meaning that they are designed to be visually "virtually lossless," meaning that it will be very difficult to see any visual difference between the original and the rendered result, even when the video is rendered several times. The GoPro company purchased the best-known of these intermediates, Cineform, and this can be downloaded for free from the GoPro site as part of their small GoPro Studio editing package. Since I don't use a Mac, I am not familiar with what codec types it accepts, and how easy it is to add additional codecs. However, I am pretty sure you can get Cineform codec if you download the Mac version of the GoPro Studio editing software. That should let you exchange video between your PC and Mac using video rendered using the Cineform codec. Once you install Studio, the Cineform codec will show up in VirtualDub as one of the compression codecs. |
18th October 2014, 17:40 | #838 | Link | |
Another option for Mac is to use the vdub external encoder feature with ffmpeg. This allows you to export a variety of formats, including MOV, prores, etc... If you still want uncompressed 8bit 4:2:2, Mac's are picky about which fourcc's and planar arrangements they will accept. "2vuy" or "uyvy" tend to be the most compatible
If you are using avs only, (nothing in vdub like deshaker or other filters), then you can use the avs directly with ffmpeg and skip vdub altogether to export various MOV formats Quote:
18th October 2014, 20:42 | #839 | Link | |
VirtualDub by default converts all video data to RGB because its filters can only operate in RGB color space. You need to set it to "fast recompress" ("direct stream copy" would just save the raw data to a file) so that it passes the input data without changes to the encoder (e.g. Lagarith in YV12 mode or x264vfw in lossless mode). The encoder is the one who determines the color space. (Personally I use VirtualDubMod because it lets me save the "fast recompress" option so that I don't have to select it every time.) Last edited by creaothceann; 18th October 2014 at 20:44. |
19th October 2014, 09:54 | #840 | Link |
@JMH - thank You for all the Details. I am constantly learning and Your hints help a lot.
My actual "problem zone" always is that grainy "halo" around faster moving objects (e.g waving Hands, or a fast moving head in front of a blue sky etc). I tried to reduce sharpness, or degrain or both, but at the end I could not yet get a satisfying solution for this. BTW ... how can I adjust the Blacks and the Whites for the autoloevels in Your script? I could not find it yet. (In Videofred's script there are the parameters: "autolev_low and _high) What denoising parameters do you use? I operated with values such between 90 and 600 (strenght) and 6 (denoising Frames). I adjusted it from a subjective point of view. @poisondeathry - thank You for the hint with the ffmpeg. I wonder whether it will be able to output a prores mov file from within a Win PC? Thanks to @creaothceann too. I will try fast recompress
Lenovo Intel i7Quad/WIN8 - Virtual Dub 1.10.4/Avisinth 2.6MT- MacMini I7 QuadCore Last edited by papcom; 19th October 2014 at 09:58. |
