9th September 2008, 20:10 | #1821 | Link |
hi man i dont know its right place to ask questions as a newbie but i have started MEGUI a week ago but i cldnt get my results as my source every thing works fine . can u just guide me what can be the best video profile to get the result like source ..
my system spec CPU: AMD Turion 64x2 Mobile technology TL-60 RAM : 2 GB Adapter Type GeForce 8400M G, NVIDIA compatible MEGUI version 3.0.2005 (All updates installed) Video Profile: x264:HQ-Slower Audio Profile: Nero AAC: NDAAC-LC-64kbps i m using this but result is not like source even its lil blury .. can u help me out what i m doing wrong . i calculate AR maually and use BitrAte 500 may be u have seen movies in 300MB basically i m try to rip a movie of 2GB that is HDRip.x264 in to 300MB .. if some one can help me . specially SHARKTOOTH. i have just waited really 5 days for this to post my question so i hope i will get somehelp.. ------------------------------------------------------------------------------------------------------------------------------------------------- Last edited by saza0500; 9th September 2008 at 20:14. |
9th September 2008, 23:11 | #1822 | Link |
i am transcoding with hardsubs and i noticed that in the 1st pass (x264) the ffdshow is started with subtitles forced to OFF...on the 2nd pass the subtitles are ON...i think this behavior is corupting the 1st pass quality (or not?)...as a quick fix i rightclick on the ffdshow icon and turn subtitles ON as soon as 1st pass starts...best regards
_ |
10th September 2008, 00:54 | #1823 | Link | |
Mr. Sandman
also you have an old version of megui and HQ-Slower doesnt exist anymore so you havent all the updates...
10th September 2008, 00:56 | #1824 | Link | |
Mr. Sandman
10th September 2008, 04:13 | #1825 | Link | |
x264: DXVA-HD-HQ and also some others . but i yet get my result blurry and abt bit rate if i increase it will increast its size also . so i want to make its size up to 300 if its 1.30 minutes movie .Basically i m trying to encode a movie that has already been encoded HDRip.x264 into more smaller size with more smaller resoultion but want to maintain its Aspect ratio and its Quality but i cldnt i can maintain its Aspect ratio but cnat maintain its Quality it becomes blurry Source.. HDRip.x264 Resoultion.. 832*416 (Anamorph) ... AR: 2.423 Ecoded: Resolution 660*272 AR:2.426 i m using filters in avi synt is progressive and video pRofile is . x264XVA-HD-HQ but what i get u can see, some pics after encoding Code:
http://rapidshare.com/files/143950284/DXVA-HQ-HD.mkv Last edited by saza0500; 10th September 2008 at 12:06. |
10th September 2008, 11:38 | #1826 | Link | |
If you ecuate the quality factor Qf (bits per pixel) from two movies you have: Qf = Bitrate1 / (fps1 x height1 x width1) = Bitrate2 / (fps2 x height2 x width2) With fps1 = fps2 and height2 = AR x width2 Bitrate1 / (height1 x width1) = Bitrate2 / (AR x width2 x width2) width2 = SQR ( (Bitrate2/Bitrate1) x (height1 x width1) / AR) If Audio bitrate is reduced also, we can replace Bitrate2/Bitrate1 by Size2/Size1 (more or less) width2 = SQR ( (300/2000) x (832 x 416) / 2.423) = 146 height2 = 146 x 2.423 = 354 Or maybe better 352 x 144 If you use more high resolution you have less quality |
10th September 2008, 12:18 | #1827 | Link | |
http://rapidshare.com/files/140306860/_400MB___HDRip__The.Matrix._1999_-Sample-Adz-Salman.mkv |
10th September 2008, 14:56 | #1828 | Link |
Hey all,
I'm still working on getting my first encode to work. I'm working from an mkv container with a 1080p bluray movie in it created via eac3to. Test encodes of various parts of the movie of up to 12k frames long have worked fine. However every time I try to encode the entire movie - The result won't play. Megui finishes with no error messages after 14hrs of working away. The final file looks about right; in terms of size and properties. However when I try to open it in MPC or MPC_HC, it won't play? The smaller tests play fine, but with the final 11Gb version - MPC sits there saying 'opening' but nothing further happens. Has anyone got any ideas? 'cheers S. |
10th September 2008, 15:22 | #1829 | Link | |
Matroska find' ich toll
i hope thats can help you |
10th September 2008, 18:32 | #1830 | Link | |
Maybe the source (2GB) have already some artifacts.
Use always original sources when you make your backup copy. Try with SD profiles, I can't understand for what you use HD for 660x272 at 434 Kb/s. Quote:
Each movie is different. |
10th September 2008, 20:25 | #1832 | Link |
Bruce Wayne
11th September 2008, 01:40 | #1833 | Link | |
Interestingly, just before powering down last night, I tried the full length encode in WMP11, and it played! So I am starting to think it is a problem with the splitter or something similar. 'cheers S. |
11th September 2008, 13:09 | #1834 | Link |
Mr. Sandman
@saza0500: re-encode from the original source, not the already encoded material and RISE the bitrate.
if you havent the original then you're violating one of the forum rules (no. 6)...
11th September 2008, 15:32 | #1836 | Link |
Mr. Sandman
postprocessing options will alter the source in the decoding stage
11th September 2008, 18:07 | #1840 | Link | |
As a general rule, you should leave everything off, otherwise you get incompatibilities and compounding effects. Do a search and experiment with settings. Test encode small representative samples so you don't waste time. What works well for 1 particular encode might not work for another movie... |
