19th April 2005, 18:38 | #102 | Link |
Wewkiee
00014 alpha out. see top post for info.
Just to clarify how the .vif process is done when material is ntsc/film pulldown is always needed.. the .mpv.m2v is written and the vif is created with the data collected during pulldown for pal/ntsc@29.97fps - with the create vif option on.. pulldown is run but no .mpv.m2v created. only is the data collected to create the .vif file. this saves lots of time during script import for scenarist. the vif file doesnt contain fps info.. just pointers to where the pictures/gops start within the video and other stuff. vifs are the same for 2.6->3.0 ( i assume also 3.1 )
...yeah...but...why on earth would I compare apples with apples? Last edited by Trahald; 19th April 2005 at 18:41. |
22nd April 2005, 16:03 | #104 | Link |
Sorry for posting this but I'm clueless as the the CCEFront.ini file that we're supposed to have? Anyone have an example of it? I tried using that with BatchEncodeM2V but it gives an error saying it can't open up the ecl.
10th May 2005, 22:43 | #106 | Link |
I installed BathEncode and can't even run it. I just get the application failed to initialize properly (0xc0000135) error upon launch. I browsed the program folder and configured cceroba, with no change in results.
Also uninstalled and reinstalled. XP Pro - patched & virus/spyware free, running on very decent hardware and specs. I do have a host of DVD type utilities installed.. Is your tool based on any outside libraries I need to install? Thanks |
16th May 2005, 23:00 | #108 | Link |
Thanks - just went to M$ site and got dot net framework from the download center. Works like a champ, now..
Question for Trahald - Have you had a chance to work on the "vob must be even number of frames" error in Scenarist? I wanna make sure I've got the latest version before running the re-encode again. Thanks |
16th May 2005, 23:44 | #109 | Link | |
ScenAid
That's been in there for a long time... and infact, it's in the new BatchCCEWS too |
22nd May 2005, 08:49 | #110 | Link |
Thanks Ds37 - I will run my project through again, and this time, maybe it will compile..
Does BatchEncodeM2V require a specific version of CCE? I'm using CCE SP 2.5, and all it wants to do is launch, but no encoding is happening. |
22nd May 2005, 13:26 | #112 | Link |
DVDR Freak!
im not sure how to encode PAL Interlaced with batchencode,there is no "altenate scan" on Batchcce i enable "top field first" and "alternate scan" and everything work nice,what settings for batchencode?
Drugs,Sex & Encoding |
27th May 2005, 23:07 | #116 | Link |
I don't know what to suggest, as I'm still having the same issue.
I have installed the latest EclCCE file and pointed BEM to it, still same issue. I have pointed EclCCE to different CCE version, same problem. I had wondered if it was maybe a version thing with EclCCE, I've tried whatever version is included with NuMenu4U, and the latest that can be downloaded from the EclCCE website. Maybe someone else will have better results with these troubleshooting steps than I have? I don't know, but figured I'd post them as a starting point. |
28th May 2005, 06:35 | #117 | Link |
plebian
batchencode won't run anymore. I click on the icon and nothing happens. I checked the task manager to see if it was somehow running but I can't see it.
I uninstalled and reinstalled it to no avail. I rebooted the PC and run it again and still nothing. thanks for the help. |
28th May 2005, 21:04 | #119 | Link | |
Wewkiee
...yeah...but...why on earth would I compare apples with apples? |
29th May 2005, 07:56 | #120 | Link |
thanks, now I get CCE to fire up and start the encode - but suddenly I'm getting this error when trying to encode. I've never had any trouble with CCE before..
Should I try a different version of CCE? I am only using 2.50 as it is rumored to be faster on an Athlon system. Is this an urban legend? Thanks for your help - I was so excited when CCE actually started encoding! Last edited by foxmid; 29th May 2005 at 08:30. |
