10th July 2009, 13:27 | #21 | Link | |
Software Developer
Reading "raw" data from the HDD may actually become a bottleneck, especially for HD content...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th July 2009 at 13:34. |
10th July 2009, 13:35 | #22 | Link |
as the others already said a lot here is flawed settings wise comparing main vs high then the subme is totally off 0 for x264 is laughable keyint 250 vs 15 is also a good joke also would have been nice if you could add Elemental Technologies Badaboom to the test (Main Profile)
@Lord_Mulder not entirely true especially when you decode more complex streams +higher resolution (Full HD) on Nvidias Hardware Decoder (VP2/VP3) it can be more beneficial speed wise in a encoding chain (especially if you add other GPU effects additionaly as denoising or deinterlacing to it) it heavily depends on your usage scenario Badaboom for example does this quiet good by decoding all the inputs it supports on the VP2 same scenario can be simulated for x264 with Donald Graft his Nvidia API Decoder And it depends on a lot more for example you have a older CPU and want to encode faster now buying a complete new system maybe means to make a complete architecture change (you calculate the costs your budget explodes) now you have a old GFX card inside and decide to buy say a 8800 GT you only need to change the GFX card get future OS gimick support , 3D Games support, Video Encoding and Enhancing including a very powerful Hardware HD Decoder all in one (that is a pretty good deal) not to say all the other CUDA/OpenCL able applications that are still to come you can say what you want but the ION platform shows here what is possible in a very small form factor with this combination putting a i7 quadcore in that case would melt it and every efficiency be wasted And the extremest case what energy usage is worth you which encoding quality ? (though this one mostly doesn't apply for end consumers as most of the times they don't care about this question)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 13:57. |
10th July 2009, 13:56 | #23 | Link |
Software Developer
If I get you right, you are saying that we can speed-up the decoding part even more by using GPU-accelerated decoders.
So this supports my point that using "raw" (uncompressed) input may not be the best idea. I'd rather use a fast lossless compressor, such as HuffYUV, for the source instead of uncompressed YUV/RGB data...
10th July 2009, 14:00 | #24 | Link |
ah sorry misunderstood you meant decoder in general not CPU Decoding here yep you right then of course raw is problematic in terms of IO and the test should be done on separate harddrives (in/out) and best with separate hardware controllers (to lower CPU utilization on a consumer system) or directly from RAM
Elemental Technologies developed based on all these requirements their own GPU powered Encoder rack http://www.elementaltechnologies.com/products/server combining all the features of the GPU with the Power of the CPU in a Energy Efficient way (sure not yielding the best quality but for the bitrate target of it a very efficient quality HVS wise with a very good energy output).
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 14:06. |
10th July 2009, 14:48 | #25 | Link |
Hardware Aspirin
Thank you for you suggestion guys.
As I said in my OP, that there is more to come with different sources at different resolutions. I'm not trying to advertise anyone here. Just feeding my curiosity to see what kind of encoding does the free CUDA encoder do and probably helping others feeling the same way in the process. The settings in this encode were used to test the pure speed of x264, to see if it could be as fast as GPU encode at similar or better quality. Since that didn't happen, I will try to match the quality and see what is the difference in performance. As to the hardware used, this is the best thing I have access to right now. Also as others said GTS 250 is a last generation GPU based on the G92 chip used in 8800GTS 512 MB, 9800GTX, 9800 GTX+. Also I may use Badaboom and MediaShow Espresso in future if time permits. Also I plan on using this video 1080p VBR Video Quality Test Streams Sony HDW-F900 footage, 1080p@25, 18 Mbps average, 30 Mbps peak in a 35 Mbps Transport Stream (259,534,064 bytes) on this page http://www.w6rz.net/ as one of the sources. Please let me know if there is another uncompressed source you would like me to try. I'm not too sure about the questions regarding the decoder, I only have ffdshow+haali media splitter installed on my system. I would really appreciate if you let me know If i need to change something with the decoders. @ ajp_anton - thanks for pointing that out. I'll put the x264 CPU Usage in the next encode. The image that I put up and 95% on all 4 cores is actually the CPU Usage during the GPU encode. And the image shows the usage of all 4 cores. If you look closely, each one of them is color coded and all of them are in there. It just so happens that they are hidden behind the last one as the usage is about the same on all.
Stream video on web in your quality Last edited by St Devious; 10th July 2009 at 15:07. |
10th July 2009, 15:04 | #26 | Link |
you can leave MediaShow Espresso away it will only let Nvidias Encoder look worse as they don't have any idea of what they doing with Nvidias API in their GUI over there @ Cyberlink i have the feeling
Stans Cli Encoder Interface to cuvidenc.dll is currently the most purest way to make usage of Nvidias Encoder API via cuvidenc.dll the other do to much insane stuff in their input Logic (most of them are optimized for Mobile Encoding and buggy as hell) for advanced usage You only need to use GPU Decoding in a x264 chain if you compare vs Badaboom and only if the input is VP2 Decodable in your case Stans encoder is only a interface to Nvidias API so no Decoding going on there Just to make it clear there are only 2 Nvidia Capable Cuda Encoder Cores currently (Nvidia,Elemental Technologies) Nvidia = cuvidenc.dll coming with Nvidias driver (used by almost all 3rd party Cuda advertised products Mediashow Espresso, Nero MoveIt, Loiloscape, PowerDirector 7, Vreveal HD, Stans Cli Encoder (Mediacoder)) Elemental Technologies = Badaboom (Consumer Main Profile only),Elemental Accelerator (Professional High Profile),Elemental Server (Professional High Profile)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 15:18. |
10th July 2009, 15:08 | #27 | Link | |
Hardware Aspirin
So If I use the video I suggested in my previous post, do i need to worry about decoding holding back the encoding ? Do I need to change anything around with the decoders ?
Stream video on web in your quality |
10th July 2009, 15:20 | #28 | Link |
Only if you compare vs Badaboom as it will decode the Mpeg-2 on your GPU best to avoid any IO differences would be decoding from a Ramdisk and additionally as output for the speed estimation into NUL.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 15:26. |
10th July 2009, 15:26 | #29 | Link |
Hardware Aspirin
what about x264 vs stan's CUDA H.264 encoder with that mpeg-2 sample ? do i need to change anything ?
10th July 2009, 15:40 | #30 | Link |
CABAC on
Subme 3 partitions default scenecut 1 bframes 2 8x8dct 1 Stans Cli Encoder -idrp 250 not quiet sure about the partitioning though but none is definitely not reflecting Nvidias Encoder PS: I practically have the same card as you 8800 GT (G92) but another CPU also Dual Core Athlon XP 64 Toledo i would also add my results here your Core 2 Quad should be a lot more efficient at least in the CPU Encoding part
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 16:02. |
10th July 2009, 16:04 | #31 | Link |
Software Developer
Just to make this clear:
It's not Stan's H.264 encoder. It's just Stan's interface to NVIDIA's H.264 encoder. The very same encoder we have seen producing crap quality in other applications Also that "encoder" was removed from the MediaCoder package due to licensing issues. At least that was the case when I last checked...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th July 2009 at 16:14. |
10th July 2009, 16:08 | #32 | Link |
Yes and it's clear that Nvidia didn't like that especialy the 3rd parties hehe ;D
@Lord_Mulder anyway it was problematic with those 3rd party apps to get on the spot target results either they where crippled or buggy :P
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
10th July 2009, 16:15 | #33 | Link | ||
Hardware Aspirin
And it is back in the latest release. Quote:
@CruNcher - sure, I'll add your results too
10th July 2009, 16:18 | #34 | Link |
But Badaboom is bad to compare it's a unique core compared to the 3rd party apps and yes the consumer version has yet no High Profile support but there are sightings in the last version of High Profile and AQ support which could come soon
Oh its back so Stan payed his royalities
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 16:22. |
10th July 2009, 17:22 | #35 | Link |
First of all I have to say it's quite useless testing at your decoding/reading/(bitstream writing?) maximum (In your case, 114fps, in my case it was 118 fps). But I can't make nvidia's encoder go any slower too (as in.. give better quality) so it can't be helped.
Secondly, you're probably showing like one of the first frames for the output files, which is nice but doesn't really work for single pass --bitrate encodes. NVidia's encoder is apparantly better at that though. If you wanna have x264 encode at the max speed too (as was the case on my system here), you might wanna go for sth like --bframes 0 --subme 5 and remove the --no-cabac. That caused no slowdown for me whatsoever in comparison to ultrafast's defaults. Also, I looked at the output of the file encoded with mediacoder/cuda, and leaving aside that the colors are totally off, it looks a lot like abusing ttempsmooth(). Surfaces are moving nice and steady, but every couple frames almost the entire frame changes. Last edited by dj_tjerk; 10th July 2009 at 17:26. |
10th July 2009, 17:32 | #36 | Link | ||
MediaCoder author
BTW: I think you can use MediaCoder to do benchmark for both x264 and CUDA H.264 encoder. This will eliminate the difference in decoding.
When things work together, things work. MediaCoder makes audio and video things work. |
10th July 2009, 17:35 | #37 | Link |
MediaCoder author
The encoder is re-added (since 0.7.1.4470) now after we signed a formal license with nvidia. We are currently working on our own cuda-based video filtering features including down-scaling, de-interlacing, 3D-denoising and pull-up.
When things work together, things work. MediaCoder makes audio and video things work. Last edited by stanleyhuang; 10th July 2009 at 17:43. |
10th July 2009, 17:42 | #38 | Link |
Stanley does Nvidia provide the API for their Cuda Encoder for free in the CUda 2.2 SDK does the usage of it needs to be licensed (payed) i guess so i mean you virtualy a competitor now to all those 3rd party applications (Cyberlink,Nero,Loilo) that make money from selling this
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 17:46. |
10th July 2009, 17:46 | #39 | Link |
MediaCoder author
I am sorry I don't think I can disclose this due to the NDA we signed.
10th July 2009, 17:48 | #40 | Link |
Hehe Cyberlink and Co will be pissed if that goes around (though they have the nicer GUI) but anyway Nvidia sells their cards and is happy
How you 3rd parties fight against each other is not their thing Yeah sure understand that confidential stuff highly business critical lol
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th July 2009 at 17:54. |
