9th November 2007, 01:40 | #101 | Link | |
Encoder in Training
b = Trim(0,b.frameCount-2) frameCount is a clip property. |
9th November 2007, 01:46 | #102 | Link | |
Banned
So, my .d2v file is a , my .avi file is b Code:
a=MPEG2Source("C:\Original.d2v").crop(16,70,-8,-70).bicubicResize(512,224,0,0.5) b=AVISource("C:\encoded.avi").trim(1,0) .... return ssim(a,b,"results.csv","averageSSIM.txt",lumimask=true) Last edited by avdw; 9th November 2007 at 02:52. |
9th November 2007, 03:17 | #103 | Link | |
Encoder in Training
a = Trim(0,a.frameCount-2) I said 'Assuming your clip is b', meaning if it isn't b, substitute all instances of b for your clip's name, which in this case is 'a'. |
9th November 2007, 03:38 | #104 | Link |
Banned
Well, I have :
a = MPEG2Source("N:\My DVDs\Le Gendarme de Saint Tropez\VTS_02_1.d2v").crop(16,70,-8,-70).bicubicResize(512,224,0,0.5) b = AVISource("N:\My DVDs\Le Gendarme de Saint Tropez\testertje.avi").trim(1,0) a = Trim(0,a.frameCount-2) return ssim(a,b,"results.csv","averageSSIM.txt",lumimask=true) |
9th November 2007, 03:45 | #105 | Link | |
Encoder in Training
a = a.Trim(0,a.frameCount-2) |
9th November 2007, 09:04 | #106 | Link |
Doom9ing since 2001
You can use this function to always make sure your source and encoded clips are the same length:
fc = (a.Framecount > b.Framecount) ? b.Framecount : a.Framecount a = a.Trim(0,-fc) b = b.Trim(0,-fc) |
9th November 2007, 10:14 | #108 | Link | |
Doom9ing since 2001
I've used SSIM A LOT in my days testing WMV9/VC-1 encoders. |
27th March 2008, 23:50 | #109 | Link |
i'm doing som tests...for example:
- source 1920,1080 - x264 2pass (Qmedium=22) 1280,720 compression is better without any doubts of x264 QB=11 640,352 compression. (it is an obviousness). Why do i obtain SSIM result almost completely close? (97.83 for 1280x and 97.90 for 640x...off course i would expected 640x lower...)...i'm (almost, beacuse the source is VC-1 and seeking it correctly is a big problem..) sure to compare exactly the same frames... maybe the result is normal since both are good encoding and in particular SSIM of 640x is about encoding QB=11 (..."saturated") and SSIM is more affected, in this case, by the 'quality' of quantizers, without evaluates the resolution effect that are very better at a reasonable quantizers value than a "saturated" encode at very lower resolution.... ciao!
P6T| 12Gb DDR3| i7-920 D0@3.8Ghz@1.168v+NOCTUA NH-U12P| Liberty 620| Stacker|2xRAID0 (4x500gb) Seag.72k.11| Seag. 500gb 72k.12| Seag. 1.5Tb 72k.11| GTX470@668/1843| U2410 24"| Se7en x64 on VRapt 300gb Last edited by Gannjunior; 28th March 2008 at 02:06. |
10th July 2011, 21:59 | #110 | Link |
Does anyone have a link to a paper or other source where the idea for the luminance masking in SSIM.dll comes from? If I am reading the source right, it gives all blocks with mean luminance <= 40 0 weight, any blocks with mean luminance >= 50 1.0 weight, and linearly interpolates between 0 and 1 for mean luminance between 40 and 50. To me it seems a little extreme to give 0 weight to any block below 40, and to ramp so quickly to 1. Just wondering where the 40 and 50 values came from.
11th July 2011, 04:06 | #111 | Link |
^The people at MSU made their own SSIM app. They may be able to give you an idea.
http://compression.ru/video/quality_...t_tool_en.html
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
11th July 2011, 07:36 | #112 | Link |
The MSU implementation does not seem to use any luminance weighting. The main SSIM paper doesn't mention it AFAICT, and the author's MATLAB implementation does not use it. I'm only asking because I'm writing a filter to compute MAD, MSE, SSIM, PSNR-HVS, and PSNR-HVS-M, and was comparing my SSIM implementation to SSIM.dll. The luminance masking just seems strange to me... not the concept necessarily, but how it is implemented (40/50 cut points, etc...). It would be interesting to know where it comes from.
21st November 2011, 17:12 | #113 | Link | |
2nd January 2012, 21:22 | #114 | Link |
Could anyone explain why does the ssim average formula not match with the value in the .txt
I'm comparing only 2 frames. Getting higher than 0.90 SSIM on both and somehow the average in .txt is 71 I understand this is a scaled value but what does it mean? That the encode looks 71% as source? Or, does it look more than 90% as source? Last edited by Pix; 2nd January 2012 at 21:25. |
16th April 2012, 07:18 | #116 | Link | |
scaled = 100*(unscaled)^8 This has the effect of exagerating the values in the index (and also, incidentally, would have to do away with any of the negative SSIM index unscaled values, since it's an even power). For example, a 0.925 is a 53.59 scaled, while a 0.935 is 58.41, 0.955 is a 69.19. Conversely, a 0.255 is 0.17 scaled. This scaling makes the higher end values a "useful number". You can disable this scaling by supplying the parameter "scaled=false" to the SSIM call, to get the true unscaled weighted average. This value should relatively agree with the values you'd get from --ssim in x264, or MSU's tool (ssim_fast specifically). So far in my experience they're usually within 0.01 of each other (unscaled). Comments from tritical on the luminance weighting are likely in play here in terms of explaining the discrepancies. SSIM isn't a linear index, at least I don't think so, so definitely wouldn't view it as a percentage (though I also often have the strong impulse to view it as such). This all does beg a question for me for the developer which is why the scaling formula it was decided to use a power of 8? Was this purely arbitrary? Why not 10? Or 6? Is there a compelling video reason to choose that power? Very curious... Edit: Or why not an odd power to preserve negative SSIM indices for that matter? Last edited by m3sh; 16th April 2012 at 07:27. |
31st January 2013, 22:03 | #118 | Link | |
I'm not sure what the difference between the two versions are, or if the fixes in 0.24a are included in 0.25. |
15th December 2015, 21:25 | #119 | Link |
I'm new to AVS scripting. I'm using this plugin right now, but it's slow! Running the script with AVSMeter showed me my CPU is used at only 12%. Each time. How can I make AviSynth use more CPU? Thanks. Also, the scaled option doesn't seem to work for me. If I write "scaled=false", it says wrong type. If I write "scaled=0", it works but the value doesn't change. Last edited by Solon8; 15th December 2015 at 22:02. |
