Old 24th December 2011, 14:26   #14461  |  Link
pandy
Hi Guys, quick question - ICL12 build is patched against bad dispatcher for AMD CPU's or not? (or should i use MSVC2010 version for AMD CPU's?).
btw
Is there any chance to restore MPEG encoder - 10 bit precision for DCT, interlace support, I frame - MJPEG is fine however there is lack for such small things (i believe that there is no standardization how to implement such features in MJPEG and MPEG-2 syntax seems to be tempting)
pandy is offline   Reply With Quote
Old 24th December 2011, 16:19   #14462  |  Link
Dstruct
I don't know what a bad dispatcher is. But here I need to use MSVC builds on my AMD CPU (no SSE2). ICL12 builds (xvidvideo.ru) don't let me open the config windows.
Also the "IntelQuickSyncDecoder.dll" is shown as "not found" in "Version details" with AMD CPU here (although the DLL is there)!
Dstruct is offline   Reply With Quote
Old 24th December 2011, 16:28   #14463  |  Link
gendouhydeist
Originally Posted by haruhiko_yamagata View Post
Thank you for finding the bug. Fixed at rev 4200.
This also fix the crash that I'm encountering on Y416 output thanks!!
gendouhydeist is offline   Reply With Quote
Old 24th December 2011, 23:56   #14464  |  Link
haruhiko_yamagata
Yes, it was fixed. Thanks for letting me know.
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 25th December 2011, 02:38   #14465  |  Link
pandy
http://www.agner.org/optimize/blog/read.php?i=49#49
Old 25th December 2011, 14:23   #14466  |  Link
egur
QuickSync Decoder author
It's not a bug it's a feature. It will only work on Intel CPUs + GPU.
Eric Gur,
Processor Application Engineer for Overclocking and CPU technologies
Intel QuickSync Decoder author
Intel Corp.
egur is offline   Reply With Quote
Old 25th December 2011, 14:43   #14467  |  Link
haruhiko_yamagata
Haruhiko, build 4142 and above cause a green line to appear on the right side of the screen when playing back a DVD with the MS DTV-DVD decoder and passing through ffdshow RAW.
I can reproduce this. I have fixed the problem in my working copy. I'll commit it to the SVN in a few days.
Old 26th December 2011, 03:50   #14468  |  Link
ryrynz
ryrynz's Avatar
Great work, thank you Haruhiko.
Old 27th December 2011, 15:35   #14469  |  Link
djchristian
Posts: n/a
Why aren't there a installguide for ffshow and media player classic HC???
Old 27th December 2011, 19:33   #14470  |  Link
pulbitz
I'm sorry. I don't speak English very well.
ffdshow video decoder configuration | Output | Stream settings
Check "Set interlaced flag in output media type"
- libavcodec
perfect smooth playback of 1080i content. (double framerate)
- Intel QuickSync
motion is steppier. (poor)
Is this a bug? Or QuickSync decoder limitation?
pulbitz is offline   Reply With Quote
Old 27th December 2011, 19:41   #14471  |  Link
clsid
@Haruhiko
There is a bug in ffdshow that causes a freeze with Haali video renderer.
4174 = ok
4183 = broken
MPC-HC 2.2.1
Old 27th December 2011, 22:47   #14472  |  Link
egur
- libavcodec
- Intel QuickSync
You need a SandyBridge (or newer) to enjoy the HW acceleration used in the QuickSync decoder.
Please specify which renderer was use as well other setup (driver version, OS version, 32/64 bit, player, display is connected to iGPU or dGPU, etc). If you can post a part of the clip (10-20 seconds) that would help development.
This thread is very busy so please report issues at the QuickSync decoder thread:
http://forum.doom9.org/showthread.php?t=162442
Eric Gur,
Intel Corp.
Old 28th December 2011, 05:17   #14473  |  Link
Midzuki
Unavailable
Midzuki's Avatar
r4206: raw video filter FAILS again
the annoying vertical green bar has disappeared, BUT the aspect ratio gets screwed -.-
Going back to r4052.
Midzuki is offline   Reply With Quote
Old 28th December 2011, 10:17   #14474  |  Link
haruhiko_yamagata
@Haruhiko
4174 = ok
4183 = broken
I have fixed at rev 4207. Please confirm.
Old 28th December 2011, 11:23   #14475  |  Link
haruhiko_yamagata
It works for me. How can I reproduce?
Old 28th December 2011, 12:15   #14476  |  Link
ryrynz
ryrynz's Avatar
4206 is working fine for me, cheers.
Old 28th December 2011, 12:19   #14477  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Try using a *real* MPEG-2 decoder (Mainconcept, Cyberlink, ArcSoft).
Old 28th December 2011, 14:02   #14478  |  Link
clsid
Fix confirmed. Thanks.
MPC-HC 2.2.1
Old 28th December 2011, 15:18   #14479  |  Link
haruhiko_yamagata
Mainconcept decoder crashes in MPC-HC, whatever the file is. I don't know what is real. ffdshow is not related.
It works in graphstudio and ffdshow raw filter is OK with it.
Cyberlink decoder (PDVD8 or 11) and ffdshow raw works fine.
I don't have ArcSoft.
Old 28th December 2011, 15:44   #14480  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Thanks for checking. I will try to find the actual source of the problem.
[ E D I T ]
ffdshow's MPEG decoder was not affected by the new raw video filter.
ArcSoft is not affected neither.
Downgraded from PDVD9 to PDVD7, the problem remains
Moving house to r4127.
