28th April 2007, 14:03 | #241 | Link |
aka XaS
@Underground78: free.fr do nasty bandwidth shaping, so anyone that isn't a "Free" subscriber will get a b0rked download rate. I would have uploaded it to my own free.fr webspace if it weren't for that. (but it'll still be faster than ys168.com I guess ^^)
@snow_xmas : mirroring is just the fact of copying a file to another location than it's original location, just in case the original location goes down. Usually it's done via daily mirroring scripts, but sometimes (like here) users do it manually.
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS Last edited by DarkZell666; 29th April 2007 at 08:47. Reason: typos |
29th April 2007, 07:50 | #242 | Link |
aka XaS
Link updated (http://xeoteam.info/x264vfw) with the sources and an index page
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS |
30th April 2007, 11:44 | #244 | Link |
Although it is different from the CLI. But most people are use to the bigger qualty index number, the higher quality of the object file. In CLI, the quality index number 0 can make a highest quality. I feel that it is too different from most people's habit. So I change it. And the number must be "int", "float" can't be set. so I set the max to 640.
30th April 2007, 15:33 | #245 | Link | |
aka XaS
2nd May 2007, 04:18 | #246 | Link |
But in MeGUI the quality index number can be set from 0.1 to 64. not 100%.Convert it to 100% will make some loss.
I give you a formula. The quality index number in vfw is "vfw". The quality index number in CLI is "cli". vfw=(64.1-cli)*10 cli=(641-vfw)/10 So you can convert the number with the formula.And I will change it to that 0 make a highest quality. Last edited by snow_xmas; 2nd May 2007 at 04:27. |
2nd May 2007, 13:46 | #248 | Link |
I have fix the "quality index number" problem. And change the max number is 510.
Enter my space |
2nd May 2007, 15:38 | #249 | Link |
aka XaS
mirror updated
Edit: updated again, for some wierd reason the files weren't updated, I needed to delete the old ones and upload the new ones again. Sorry for those that downloaded them these 5 last minutes
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS Last edited by DarkZell666; 2nd May 2007 at 15:43. |
6th May 2007, 16:32 | #250 | Link |
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
I don't speak chinese language, snow_xmas, so I can't do anything on your site. Please provide direct download link to rev 655.
Live long and prosperLive long and prosperLive long and prosper |
6th May 2007, 18:14 | #251 | Link | |
aka XaS
Just in case, you need to open the address in IE, not in FF, otherwise you get a black page probably saying something like "You must use IE 5.0 or later". I admit it took me some minutes to figure that out ... Here you go, mirror updated with r655 : http://xeoteam.info/x264vfw/ Edit: 2nd mirror http://xss.xas.free.fr/x264vfw/
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS Last edited by DarkZell666; 6th May 2007 at 18:20. |
7th May 2007, 10:24 | #253 | Link |
Hi guys, I'm learning to encode AVI with X264vfw since I often record volleyball matches from TV with a DVD-Recorder. Could you guys give me some suggestions of the settings as to get better quallity for a match?
Thanks in advance! |
7th May 2007, 10:32 | #254 | Link | |
aka XaS
Second, have you noticed the thread title ? "The x264 guide". The first post even links to a guide related specifically to x264vfw (written by DeathTheSheep himself, the original poster). I think it should be enough to get your started =) Here, a direct link, just for you :http://gabextreme.googlepages.com/De...VfW_guide.html Good luck and have fun reading
7th May 2007, 14:29 | #256 | Link |
aka XaS
You won't be able to register with free.fr since they require you to enter a valid postal address to send you your login & password (in france of course ^^').
Try geocities over at yahoo : http://geocities.yahoo.com/ps/learn2...rks4_Free.html I'm not too sure if it's a good alternative or what, but it's free (with ads). Also, the ftp account I offered you is still open ... (that's where I'm mirroring your stuff right now ), but I'd understand if you wanted total control over your webspace
7th May 2007, 22:35 | #258 | Link |
aka XaS
Well, sports in general tend to be very shaky and action-packed, which is naturally hard to compress if you consider how codecs work. If you tried encoding your match at 800kbps hoping for a miracle, you most probably ended up disappointed.
The best you can do is do some extra filtering with avisynth, downsize a bit more if you didn't already, and not expect low bitrates to look good for such a high-motion source. Using "constant quality" mode (also known as CRF) is your friend if you can't get good-looking results. Use crf 18 (180 in snow_xmas's vfw build) to give yourself an idea of the bitrate needed to get a good picture quality. If you really need a smaller filesize, it's your job to decide wether you'll downsize, just turn the bitrate 10% lower and re-do a second pass, or live with the bigger filesize
