3rd January 2013, 00:00 | #11981 | Link |
Hello, madshi!
First of all, big THANK YOU for eac3to, especially for support and update this great program! And I'd like to ask you one question: why you didn't add azid.dll to eac3to? There is some troubles to decode DD, because you have to demux DD with eac3to and decode it with azid or nicaudio for correctly decoding DD. You know, nero don't ignore DRC and libav downturn of high frequencies after 17 kHz. You can see (E-)AC3 decoders comparison here. It would be very nice, if we can decode ac3 correctly only by eac3to, like "eac3to test.ac3 test.wavs -azid". Thanks. Last edited by nickintheforest; 3rd January 2013 at 00:08. |
3rd January 2013, 00:14 | #11984 | Link | |
Haha! My focus is still on madVR for the time being...
3rd January 2013, 00:44 | #11985 | Link |
For best AC3, E-AC3 and AAC decoding you need: (1) Nero 7 (Nero 8 won't work!) (2) Nero HD DVD / Blu-Ray plugin Code:
-phaseShift shift phase (when doing stereo downmixing, see "down2") -mixlfe mix LFE in (when doing stereo downmixing, see "down2") Last edited by Snowknight26; 3rd January 2013 at 00:48. |
3rd January 2013, 01:09 | #11986 | Link |
Not downStereo, but rather downDpl. Back channel phase shift is a typical feature of Dolby ProLogic downmixing; basic stereo downmixing would not care much about the back channels.
3rd January 2013, 01:38 | #11987 | Link |
Curious, why the change from Nero to libav as the preferred DD decoder?
Desktop - Windows 7 x64, Core i7-2700, 16 GB DDR3, GeForce GTX 650 Ti Laptop - Windows 8 x64, Core i5-540M, 8 GB DDR3, X45000MHD Media Center - Windows 7 x64, Core i7-2600, 8 GB DDR3, GeForce GT 240 |
3rd January 2013, 03:27 | #11989 | Link |
Errors that libavcodec spits out break the progress bar:
v02 Extracting video track number 2... a03 Extracting audio track number 3... v02 Muxing video to Matroska... a03 Extracting TrueHD stream... a03 Decoding with libav/ffmpeg... a03 Reducing depth from 24 to 16 bits... a03 Encoding FLAC with libFlac... a03 Creating file "G:\brave.flac"... a03 Skipping identical AC3 frames (seamless branching)... -[truehd @ 009471a0] Lossless check failed - expected 00, calculated 15. [truehd @ 009471a0] Lossless check failed - expected 00, calculated e7. ---[truehd @ 009471a0] End of stream indicated. [truehd @ 009471a0] Lossless check failed - expected 00, calculated 91. |
3rd January 2013, 05:46 | #11993 | Link | |
[removed link by tebasuna51] Last edited by tebasuna51; 3rd January 2013 at 12:23. |
3rd January 2013, 12:08 | #11994 | Link |
@madshi:
Options: -downDpl downmix multi channel audio to Dolby Pro Logic II -downStereo downmix multi channel audio to simple Stereo -phaseShift shift phase (when doing stereo downmixing, see "down2") -mixlfe mix LFE in (when doing stereo downmixing, see "down2") Anyway, thanks a lot for this invaluable tool!
..:: sundance ::.. Last edited by sundance; 3rd January 2013 at 12:17. |
3rd January 2013, 12:39 | #11996 | Link |
Posts: n/a
madshi, thanks a lot for numerous fixes and improvements.
I asked that before and I don't want to annoy anyone, but I wanted to ask you, as a dev, personally - is there any chances for these ipms in a future versions? • avi, mp4, mov, mpg, flv demuxing(maybe even muxing, that would be fantastic). Basically, avi/mp4 support is most important feature I think eac3to is lacking, along with • Proper ac3 decoding. Whilst a freeware prog like azid can properly decode ac3, it's a real shame such powerful instrument as eac3to uses nero/libav for that, because both decoders has defects. • and also, downmix to mono and ac3/dts dialnorm applying - minor, but still useful features. /Thank you. Last edited by get8p; 3rd January 2013 at 12:43. |
3rd January 2013, 14:35 | #11999 | Link |
@all
To report bugs please use the thread http://forum.doom9.org/showthread.php?t=166487 @get8p please read http://forum.doom9.org/showthread.php?p=1608655#post1608655 and http://forum.doom9.org/showthread.php?t=166487 Use -keepDialnorm. @phate89 a mix DPL II can recover the surround (more or less) with the appropiated decoder in audio receivers.
eac3to |
