21st January 2015, 06:46 | #1022 | Link | |
Suptitle, MediaPlayer.NET
Just wondering if you'd be so kind as to make us an Android remote client? :P |
21st January 2015, 06:51 | #1023 | Link | |
It seems you simply closed my pull request without merging it, is there something I need to change? |
21st January 2015, 10:02 | #1026 | Link | |
All displays out there are 1920x1080, and the remaining 8 lines in a 1920x1088 video bitstream are usually "garbage". Because of that it makes a lot of sense to forcefully cut 1920x1088 down to 1920x1080. Otherwise those 8 garbage lines would be visible, and furthermore they would also result in scaling becoming active when rendering on 1920x1080 display which really doesn't make any sense. |
21st January 2015, 11:57 | #1028 | Link |
User contributed articles
SVP + MPDN, relying on frame rate decimation feature by Blackfyre
* Post will be updated as more users contribute articles about MPDN Last edited by Zachs; 28th January 2015 at 11:29. |
21st January 2015, 17:58 | #1030 | Link | |
Thanks for fixing the Stop/Play issue, it now works perfectly. (Just checked it out) I have found a strange issue when using fullscreen on my primary monitor (I have 3 panels) When I go fullscreen on the main panel the two side panels flash black as the switch occurs. If I then click in one of the side panels it flashes black again and then goes on like normal. This happens every time I click inside the player and then outside or vice versa. The issue doesn't occur when I make it fullscreen on one of the secondary displays. Last edited by DeadlyEmbrace; 21st January 2015 at 18:49. Reason: More to say |
21st January 2015, 23:04 | #1032 | Link | |
It's going to be quite hard to figure out what is going on without having the actual samples to test... It's been a long time since I even had a DVD at home, so I'm not sure how to make a sample out of it but perhaps someone could help... |
22nd January 2015, 04:21 | #1034 | Link | ||
And if your decoder queue is long enough or your machine fast enough, you won't even get so much as a stutter in video. |
22nd January 2015, 04:28 | #1035 | Link | |
22nd January 2015, 04:36 | #1037 | Link | |
EDIT: Ah found it to skip one frame when the crossover happens. Fixed in next release... EDIT2: Found a bug where it would lock up if subtitle changes occur too fast. (Fixed) Last edited by Zachs; 22nd January 2015 at 05:47. |
22nd January 2015, 05:30 | #1038 | Link |
DVD vobsubs appear to be being selected correctly now as well as the GUI show the selection correctly as well. Still have the problem of the subtitles not displaying at seemingly random times. This behavior is apparent in what we discussed earlier. Thanks for fixing the GUI issue.
22nd January 2015, 05:32 | #1039 | Link | |
When you say random times, do you mean going back to the same playback position the subs will appear at times but not others? |
22nd January 2015, 05:53 | #1040 | Link |
I just have XySubfilter installed on my system as of right now. I'll install DirectVobSub and let you know. What I mean by "seemingly random" is that sometimes the dialogue subs don't appear sometimes the signage subs don't appear. I'll try going back and forth to specific positions and see if that has any bearing on whether they appear or not.
direct3d, mpdn, nnedi3, opencl, reclock |
