Old 17th March 2009, 19:57   #2101  |  Link
turbojet
If VC-1 is really the problem this should work as long as you have powerDVD 8 installed, you can always trial it if you don't.
Old 17th March 2009, 20:18   #2102  |  Link
turbojet
lordraider you are probably only one of millions out there hearing everything about mkv and nothing about BD.
You may in some cases be able to save some time by removing streams without encoding video and blanking extrsa but it hasn't been tested by many yet.
Old 17th March 2009, 20:45   #2103  |  Link
DaMacFunkin
Hmm, do you know of a guide or a step by step progress to use CLVC1Loader.ax ??? I'm stumped.
Cheers.
DaMacFunkin is offline   Reply With Quote
Old 17th March 2009, 20:56   #2104  |  Link
turbojet
Setting cyberlink splitter and decoder to a higher merit with graphstudio may work too. But otherwise you can use crude vc1tweak installer I made a little bit ago.
Old 17th March 2009, 21:12   #2105  |  Link
jewish
Which folder do we put this file in ? CLVC1Loader.ax?
Kind regards
jewish is offline   Reply With Quote
Old 17th March 2009, 21:48   #2106  |  Link
lordraider
i finished The incredible Hulk with BD rebuilder, everything went fine, no errors. Then i build an iso file with imgburn with udf 2.5. from the folder : "INCRED_HULK_2008_G51" which was created by bd rebuilder. When I mount it with virtual deamon powerdvd 8 starts and says : "There is a disc with an unsupported format in drive F:".
The content of the root is BDMV and CERTIFICATE just like the original bluray (which plays fine on powerdvd 8). What did I do wrong?
Anybody an Idea?
lordraider is offline   Reply With Quote
Old 17th March 2009, 21:49   #2107  |  Link
DaMacFunkin
Hi Turbojet, sorry to be a pain and thanks for your help, i have installed your tweak vc-1 on vista 64 bit, now what?
I have tried an encode of the troublesome file with libavcodec selected for vc-1 in ffd and all that outputs is a grey still.?
Old 17th March 2009, 21:50   #2108  |  Link
DaMacFunkin
Anybody an Idea?
Did you rip using default settings with AnyDVD HD? Some disks don't like you taking anything at all out of them.
Old 17th March 2009, 21:51   #2109  |  Link
turbojet
virtual daemon is daemon tools?
virtual clonedrive is the only mounting software I know of that correctly mounts BD.
Old 17th March 2009, 21:56   #2110  |  Link
turbojet
DaMacFunkin load any vc-1 m2ts into graphstudio and see what is being used to decode. If it's anything other than cyberlink loader, go to graph > insert filter > directshow filters > cyberlink vc-1 loader > change merit and set to preferred +2 and try loading the m2ts again and see if cyberlink vc-1 loader is decoding it. After you are done with the troublesome file(s) make sure to uninstall vc1tweak as it's pretty buggy for encoding a lot of vc-1 streams.
Old 17th March 2009, 21:58   #2111  |  Link
lordraider
I indeed use deamon tools, i'll try virtual clonedrive . Thx for the tip.
Old 17th March 2009, 22:50   #2112  |  Link
drmih
Originally Posted by DaMacFunkin View Post
I decided to take it upon myself to see if there was a problem with some Universal titles after many unsucessful attempts at Wanted Region B (see my previous posts) so i thought i would try The Mummy 3 UK Release. The title keeps crashing x264 - some of the extras streams are VC1 1080i encoded.. Help!!!
I also had this problem. The easiest solution I found was to identify the extra m2ts files which won't work and then find the size of the largest. Change the .ini setting to only encode files larger than the above, and do as a bd-25.
drmih is offline   Reply With Quote
Old 17th March 2009, 23:11   #2113  |  Link
schlaufer
schlaufer's Avatar
Anybody an Idea?
I had a similar problem with a likely long label.
I've shortened the label with ImgBurn (under ISO/Tools) and it worked fine.
schlaufer is offline   Reply With Quote
Old 17th March 2009, 23:21   #2114  |  Link
lordraider
Ok, I installed virtual clonedrive and now the movie starts in PowerDVD, the intro works, the menu's are working, loaded an extra , it worked too. But if I try to play the movie or select a scene it won't start, the screen stays black. I don't know if it is a powerdvd issue or bd rebuilder did something wrong.
I tried to open the mt2s file with windows mediaplayer and it plays fine.
It is a Universal Title (the incredible hulk)
Jdobbs if you need some more info or a file for debugging just ask and I'll send it to you.
Here is the log. (only from the movie part)
[Status]
LABEL=INCRED_HULK_2008_G51
VERSION=v0.20.03 (beta)
SOURCE_SIZE=45492909958
SOURCE_VIDEO_SIZE=44155416576
TARGET_SIZE=24589107200
REDUCTION=.526585765032462
RESIZE_1080=0
AUDIO_TO_KEEP=eng
SUBS_TO_KEEP=all
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=50
REBUILD_COMPLETE=1
[00009]
AUDIO=1000
PGS=11111111110000000000000000000
M2TS_TARGET=12520246583
RATE=13122
NSIZE=12130719744
FLINK=0
MLINK=0
Old 17th March 2009, 23:37   #2115  |  Link
Biffa001
any more help on the below probs guys?
I'm stuck
Originally Posted by Biffa001 View Post
I've updated AVISynth to the latest 2.58 version and tried again - still no joy, the same x264.exe crash.
- I've also noticed that when BD_Rebuilder gets to this point:
shouldn't Haali and FFDshow bee seen in the taskbar, as they aren't?
Any other suggestions please ? Thanks for your help, it's appreciated, hope we get to the bottom of this!
Biffa001 is offline   Reply With Quote
Old 18th March 2009, 00:01   #2116  |  Link
turbojet
Biffa001: Check stream window and if it's VC1 try the VC1tweak I mentioned earlier today. If its H.264 or MPEG2 make sure you have latest ffdshow and in video decoder options make sure H.264 is set to ffmpeg-mt (although libavcodec may decode more) and MPEG2 is set to (libavcodec). If you've tried all these can you cut out a part that doesn't decode with something like dgsplit and upload it to a place like http://www.sendspace.com and post the link?
Also what drmih works fine without all the hassle if you are encoding to BD25 but if you are encoding to BD5/9 you might not want to keep all streams smaller then the stream that is causing problems untouched. I know with 300 it was 3x 1.8-2 GB 1080i VC-1 streams that if I kept everything smaller it would be larger then the BD9 I was aiming for. However if VC1tweak doesn't work you don't really have another option as far as I know.
Old 18th March 2009, 03:06   #2117  |  Link
mot
"Problem with Americans"
When opening American Gangster(movie only) your latest 2003 gives error and aborts............any help for this would be greatly appreciated.
Thanx for all your wonderful work!!!
mot is offline   Reply With Quote
Old 18th March 2009, 09:37   #2118  |  Link
robinthehood
While doing "Blindness" German Region B everything seemed fine until the closing minutes and then while "multiplexing M2TS file" i got this error
BD Rebuilder experienced an error 8 [08:25:13] DoEncoding() 00009 8, this is the first error i've had, anyone able to shed any light?
robinthehood is offline   Reply With Quote
Old 18th March 2009, 14:22   #2119  |  Link
tekmobile
Webmaster
Using the latest version 0.20.03
Just done Quantum Of Solace full copy to BD25 but there was a problem with skipping through the movie when played back through TMT2.
By skipping im meaning every time you try to skip a chapter the chapter changes and the timeline moves but the movie restarts from the begining.
No errors were encountered or reported through the entire encode and the origional ISO plays properly with no issues.
tekmobile is offline   Reply With Quote
Old 18th March 2009, 14:30   #2120  |  Link
GaPony
Funny that you should mention that. I got the same error this morning when doing a movie only copy (BD9) with Pirates of the Caribbean 3. It first gave a notice of audio/PGS sizing issue and asked if I wanted to continue, then continued with the immediate error as you stated..
GaPony is offline   Reply With Quote
