Old 27th November 2009, 03:16   #1  |  Link
some dude
Old AviSynth Filter
Their is this old filter for avs 2.0 called simple resize that had a function called warped resize. It could adjust the aspect ration of a video using horizontal and vertical stretch, kind of like a fisheye lens. My tv only does this feature with 480i s-video, composite, and RF input, meaning that the only way I can remove the boarders from 4:3 video in hdmi, component, or vga input is to stretch the video to 16:9. The filter was also released for avisynth 2.5 Alpha but when I tried to use it there were serious chroma issues. I uninstalled avs 2.58 and installed 2.08 to use this old filter and it works without the issues but now I can't use all of my other filters.
Does anyone know of another filter similar to this?
some dude is offline   Reply With Quote
Old 27th November 2009, 03:33   #2  |  Link
Point us to the source code of the filter and we can try to fix
the chroma issues for you.
EDIT: I found trbarry's filter. I assume that is the one.
Please describe the chroma issues in more details.
Old 27th November 2009, 03:48   #3  |  Link
some dude
Maybe I went too far by saying serious but the chroma gets out of place and it seems like alot of trouble to move it back. I also think the chroma gets distorted with rest of the image but I'm not sure about that. Here is an example image.
avs 2.58
avs 2.08
Old 27th November 2009, 03:49   #4  |  Link
Looks pretty serious to me!
Even in YUY2 there are errors. I'll try to find some time to look at it.
Old 27th November 2009, 03:52   #5  |  Link
some dude
Thank you so much!
Old 19th December 2009, 13:37   #6  |  Link
Hi Dude
From my version of SimpleResize
Change Log:
2003/01/16 V 0.3.3 Avisynth 2.5 support, PluginInit2
2002/09/16 V 0.3.2 Fix horizontal chroma shift bug
2002/07/29 V 0.3.1 Removed 4x horizontal pixel count requirement
2002/02/04 V 0.3 Added InterlacedResize & InterlacedWarpedResize functions
2002/01/29 V 0.2 Additional SSE2 & SSEMMX optimizitions, Better warp formula
2002/01/20 V 0.1 Initial release V 0.1
Note v0.3.2
Dont know if this fixed your bug, you say for AS v2.5, (never used the filter).
Old 19th December 2009, 21:14   #7  |  Link
some dude
I have that same readme with the version I downloaded, the error remains. If only I knew how to program I would look at the filter myself. But learning to program is not an option because I can't even get myself to finish reading chapter 3 on this book I have about how to programing in blitzbasic.
Old 19th December 2009, 22:02   #8  |  Link
And it's all in optimized assembler, which makes it even harder to follow. Tom comments his code well, though.
Old 19th December 2009, 22:15   #9  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Assuming it's the same dll I just downloaded from http://avisynth.org/warpenterprises/, have you tried adding:
converttoyuy2
The filter will fail to work correctly on YV12 clips (as above), but will not produce a warning. The converttoyuy2 advice is in the readme.
Edit: Oops, didn't see neuron2 mentioning YUY2 errors as well! I can't see any...
David
wonkey_monkey is offline   Reply With Quote
Old 19th December 2009, 22:17   #10  |  Link
Yo Dude
http://www.filefactory.com/file/a121...Resize_MOD.zip
EDIT:- Above Link now DEAD.
To download recompiled SimpleResize(),
Contains:-
Original,
FOLDER RecompiledOriginal
FOLDER SSE2_DISABLED
FOLDER SSEMMX_DISABLED
Try them all, suspect SSE2 will be your problem, will not of course be as
fast but the SSE-MMX version may work.
gud luck
EDIT:- Correction, the SSE2_DISABLED May work, else use SSEMMX_DISABLED
which also disabled SSE2.
Old 20th December 2009, 00:07   #11  |  Link
some dude
Thanks for looking at the code guys.
StainlessS - I tried all three versions of the plugin that you provided, their was no change in the end results.
Old 20th December 2009, 01:21   #12  |  Link
Yo Dude,
http://www.filefactory.com/file/a121...e_TryAgain.zip
EDIT:- Above link now DEAD.
Take two, Action!
(Missed one out)
Old 20th December 2009, 03:22   #13  |  Link
some dude
Still no luck, thanks anyways though.
Old 20th December 2009, 05:13   #14  |  Link
IanB
Avisynth Developer
Fizick is using a modified version of this in his MVTools, might be worth seeing what he changed.
IanB is offline   Reply With Quote
Old 20th December 2009, 05:56   #15  |  Link
some dude
I am so sorry. I feel like an idiot. I didn 't even try changing the color space like davidhorman recommended. I just tried converting to yuy2 before applying the filter and it works. I'm sorry if I caused you guys extra work.
aspect ratio, simple resize, simpleresize, warped resize, warpedresize
