Old 23rd January 2010, 19:42   #41  |  Link
sheck
OK, I'll add it.
sheck is offline   Reply With Quote
Old 24th January 2010, 06:44   #42  |  Link
setarip_old
setarip_old's Avatar
Thank you ;>}
BTW - Perhaps not stated because it's all too obvious but, you should let folks know that it works equally as well with single files as it does with batches...
setarip_old is offline   Reply With Quote
Old 26th January 2010, 01:10   #43  |  Link
sheck
v 0.4.0.0 Released
Changes:
* MKVcleaver can now be maximized and resized
* Position and size settings are now stored in custom.ini
* Saving of position and size can be turned on and off by pressing Alt+Shift+R
* Track setting are now only reset if information about the files has changed.
* Remove button will be grayed out until at least one file is checked in the left pane.
* Extract button will be grayed out until something that can be extracted is checked in either left or right panes.
* Double right click on a file in the left pane to get detailed info on a file.
* 2-letter language tag can be appended to the end of audio and subtitle tracks.
* Language tag can be turned off and on by right click in the upper right corner of Filename Options box.
* Language tag option is saved in custom.ini file.
Everything else will be added upon either majority requests or my own whim.
Old 27th January 2010, 04:48   #44  |  Link
Caroliano
It is crashing on me in the middle of extraction of subtitles, chapters and atachments of 26 files. The fist time it stoped answering on episode 9, when I tried to reproduce it, it crashed at episode 10. I'm using Win7 64bits, and MKVtoolnix 3.1.0. Here the crash report:
Assinatura do problema:
  Nome do Evento de Problema:	APPCRASH
  Nome do Aplicativo:	MKVcleaver0400.exe
  Versão do Aplicativo:	0.4.0.0
  Carimbo de Data/Hora do Aplicativo:	4b509352
  Nome do Módulo de Falhas:	ntdll.dll
  Versão do Módulo de Falhas:	6.1.7600.16385
  Carimbo de Data/Hora do Módulo de Falhas:	4a5bdb3b
  Código de Exceção:	c0000005
  Deslocamento de Exceção:	0002e29b
  Versão do sistema operacional:	6.1.7600.2.0.0.256.1
  Identificação da Localidade:	1046
  Informações Adicionais 1:	0a9e
  Informações Adicionais 2:	0a9e372d3b4ad19135b953a78882e789
  Informações Adicionais 3:	0a9e
  Informações Adicionais 4:	0a9e372d3b4ad19135b953a78882e789
If there is something else I can do to help the debug, please say.
It is an very handy tool. Thank you.
EDIT: I tried again, only from epi 9 onwards, and it crashed at the episode 10 again. If I extract only episode 9 or 10 alone, it does not crash, and the extraction goes fine. It also worked from episode 11 to 26 in batch mode fine. The problem I see is that episode 1-10 have only 2 subtitle tracks, while 11-26 have 3.
I'm asking to extract the first subtitle track in each archieve, and they are equal for all them. It should do what I ask, or at least give an warning.
Caroliano is offline   Reply With Quote
Old 27th January 2010, 10:21   #45  |  Link
setarip_old
@scheck
More often than not, when completed, shows "99%" rather than 100% and no statement "Finished"
Old 27th January 2010, 20:06   #46  |  Link
sheck
Originally Posted by setarip_old View Post
@scheck
It does go to %100, but you won't see it, 'cause it then clears the statusbar on finish. Statement "Finished" is not needed.
Old 27th January 2010, 20:12   #47  |  Link
setarip_old
@scheck
If by "status bar" you are referring to the lower section of the window where the percentage completed appears, that is exactly the problem I am seeing.
Many times, although the process has obviously completed, the status bar stops and indefinitely stays at "99%".
Old 27th January 2010, 20:16   #48  |  Link
sheck
Well, I don't have Win 7 and MKVcleaver was designed to run on 32 bit OS. So, I can only guess as to what to do.
When it crashes, does it display some sort of error or just disappears ?
Since it is 64 bit, try running in XP compatibility mode.
I just tested it on my PC with files that have 3 subtitle tracks and 2 subtitle tracks and MKVcleaver did not crash.
Edit: eventually I will get WIN 7 64 bit for testing and design 64 bit version of MKVcleaver. But that day might not be in the nearest future.
Old 27th January 2010, 20:17   #49  |  Link
sheck
@scheck
Well, yeah that shouldn't happen.
Could you describe exactly what you do and in which cases this happens, because I cannot reproduce this behavior ? On my PC the status bar is blank when MKVcleaver finishes.
Old 27th January 2010, 20:48   #50  |  Link
setarip_old
@scheck
I have been testing its ability to extract subtitle streams with individual MKVs (NOT batches), as follows:
1) Drag & drop MKV file into leftside window
2) Click on "+" to expand the MKV's tree
3) Place a checkmark to the left of the "Subtitle track" lited in the tree in the leftside window
4) Click on "Extract tracks!" radiobutton
Old 28th January 2010, 00:34   #51  |  Link
ron spencer
DVD Magistrate
I cannot get it to work at all...I get the error:
Line 2473 (File "C:\thepath\MKVcleaver0400.exe"):
Error: Array variable subscript badly formatted.
ron spencer is offline   Reply With Quote
Old 28th January 2010, 01:26   #52  |  Link
war59312
war59312.com
Originally Posted by sheck View Post
Changes:
Nice!
Though sadly it is not remembering if it is maximized or not, maximized=1 seems to have no effect.
war59312 is offline   Reply With Quote
Old 28th January 2010, 01:29   #53  |  Link
sheck
Originally Posted by war59312 View Post
Nice!
It works fine on my PC. Make sure resize=1 is set too.
What OS are you running it on ?
Old 28th January 2010, 01:32   #54  |  Link
sheck
What OS are you running ? I was getting this problem in Wine. I hope you're not running it under Wine, that's not supported.
If not, then describe step by step what you're doing, so I can recreate this problem.
Old 28th January 2010, 01:38   #55  |  Link
sheck
@scheck
Can you post a screen shot of this problem ? No matter what I do, I cannot get this to happen to me.
Old 28th January 2010, 03:26   #56  |  Link
Caroliano
It grays out (aero feature) and apears an default windows error message saying that the app stoped working, and additional details as I pasted here. MKVcleaver does not give any error by itself.
That did the trick. Now it is working fine.
But now every time I open it apears the annoying UAC alert. Thus, real win7 64bit suport is still wanted. ^^'
Old 28th January 2010, 04:32   #57  |  Link
ron spencer
DVD Magistrate
XP Pro SP3
All I do is open the program, point to mkvtoolnix, open an MKV, choose it, then I just tried to extract something...nothing more.
Old 28th January 2010, 20:09   #58  |  Link
sheck
XP Pro SP3
Ron, I'm running tests on MKVcleaver right now to try to recreate your problem. This might take a while...
Old 28th January 2010, 20:55   #59  |  Link
ron spencer
DVD Magistrate
ok great!!
Not sure why there is a problem on my XP...bizzaro
Old 29th January 2010, 00:37   #60  |  Link
sheck
ok great!!
Ron, can you make sure that mkvmerge is working properly ? Open command line and navigate to your mkvtoolnix folder and run: mkvmerge -i "mkv file" Make sure you get output.
batch extract, extractor, matroska, mkv, mkv batch, mkv decoder, mkvextract
