Old 30th January 2018, 22:00   #1321  |  Link
Khanattila
Khanattila's Avatar
What does this mean?
video=ConvertToYUV444(video).KNLMeansCL(d=1, a=2, s=4, h=4, device_type="CPU", device_id=0).ConvertToYUV420
add channels="YUV"
github.com
Khanattila is offline   Reply With Quote
Old 30th January 2018, 22:15   #1322  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
video=ConvertToYUV444(video).KNLMeansCL(d=1, a=2, s=4, h=4, device_type="CPU", device_id=0,channels="YUV").ConvertToYUV420
Why CPU device does not support this mode?
Atak_Snajpera is online now   Reply With Quote
Old 30th January 2018, 23:04   #1323  |  Link
Khanattila
Khanattila's Avatar
Implementation-defined, however, it is difficult for the CPUs to support that mode.
The program is GPU oriented, and GPU work well with INT8, INT16, INT32, HALF and FLOAT.
So it makes sense not to support intermediate precision like INT9, INT12 or INT14.
However, there is a special format INT_101010, where the channels of each element (10 bits per channel) are packed into a single INT32.
Unfortunately, it is not very supported.
github.com
Old 31st January 2018, 12:35   #1324  |  Link
Atak_Snajpera
Ok. No problem. I was just curious...
Old 2nd February 2018, 10:51   #1325  |  Link
Khanattila
Khanattila's Avatar
You are welcome
github.com
Old 12th February 2018, 15:41   #1326  |  Link
littlepox
Hi all, need some help with KNLMeansCL on AMD RX Vega64:
denoised Y clip comes with broken data (mostly zero, very few times random output). This is a known issue (https://github.com/Khanattila/KNLMeansCL/issues/26) and we will await the patch.
Meanwhile, we would like to know whether using RGB is a safe workaround or not(assume we don't want to touch UV planes) :
a = "your file with YUV-8bit format.m2ts"
src8 = core.lsmas.LWLibavSource(a,threads=1)
src16 = core.fmtc.bitdepth(src8, bits=16)
Y = core.std.ShufflePlanes(src16, 0, vs.GRAY)
nr16y = core.resize.Bicubic(Y, format=vs.RGB48,matrix_in_s="709")
nr16y = core.knlm.KNLMeansCL(nr16y, d=1, a=2, s=3, h=1.3, channels="RGB", device_type="GPU")
nr16y = core.resize.Bicubic(nr16y, format=vs.GRAY16,matrix_s="709")
nr16y.set_output()
It looks OK for a few samples but we would like to know whether it is indeed unaffected by the same issue. Thanks for help!
littlepox is offline   Reply With Quote
Old 12th February 2018, 16:38   #1327  |  Link
Khanattila
Khanattila's Avatar
nr16y.set_output()
Hi littlepox, thanks for your report.
The main problem is I do not have a Vega GPU. In the country where I live the cost is very high, over 800€!
I also tried AMD's CodeXL, but for now, I do not see something strange. Future investigations are required.
I do not know if the workaround you suggest works or not, there is a problem with the new AMD OpenCL compiler for Vega.
There are probably some optimizations in place that are not clear.
github.com
Old 25th February 2018, 12:14   #1328  |  Link
fadedmaple
fadedmaple's Avatar
GPU use ratio is Low
Hi,i`m use KNLMeansCL in vapoursynth with GTX1060 .
The system is Win10 and driver 390.77.
I found the GPU performance can not be fully realized.
the vpy script like this
src = core.lsmas.LWLibavSource(r'E:\OB\MEET_THE_FOCKERS_HDCLUB\BDMV\STREAM\00372.m2ts')
src = core.knlm.KNLMeansCL(src,d = 3,a = 6, h = 1.2,channels="Y",device_type = "gpu" )
src = core.knlm.KNLMeansCL(src,d = 3,a = 6, h = 1.2,channels="UV",device_type = "gpu" )
Only 0.3 fps ,And take up 10%-30% GPU usage。
Is it unable to run out of GPU or is it my own problem?
fadedmaple is offline   Reply With Quote
Old 25th February 2018, 15:56   #1329  |  Link
Khanattila
Khanattila's Avatar
Hi fadedmaple, can you post the whole script?
The situation you describe is typical of a CPU-bottleneck.
github.com
Old 25th February 2018, 16:57   #1330  |  Link
fadedmaple
fadedmaple's Avatar
here the whole script ,nothing special
from vapoursynth import core
import vapoursynth as vs
src.set_output()
If i set the parametes as default (d = 1,a = 2),the x265 get a faster speed,even faster than no denoise.
So I think it really is using my GPU.
I use vseditor to benchmark ,when set d=3 a=6 ,CPU usage is very low,why CPU-bottleneck?
Old 25th February 2018, 17:52   #1331  |  Link
Khanattila
Khanattila's Avatar
I never used vseditor, but I suspect it could slow things down.
RX 480 8GB (1330MHz / 2000MHz) ~1,29 FPS with 90-100% GPU Load.
script.vpy
core = vs.get_core()
clip = core.lsmas.LWLibavSource("Sample.mkv", format="YUV420P8")
# 1920x1080 clip from a Blu-ray.
clip = core.knlm.KNLMeansCL(clip, d=3, a=6, channels="Y",  device_type = "GPU")
clip = core.knlm.KNLMeansCL(clip, d=3, a=6, channels="UV", device_type = "GPU")
clip.set_output()
launcher.bat
vspipe script.vpy NUL -p
PS. Furthermore, there is the possibility LWLibavSource has decoding problems in that particular situation.
You should use a blank clip rather:
core.std.BlankClip(width=1920, height=1080, format=vs.YUV420P8, length=1000)
github.com
Old 26th February 2018, 07:47   #1332  |  Link
fadedmaple
fadedmaple's Avatar
script.vpy
clip.set_output()
launcher.bat
Thanks for you explain and advise,i find a very strange thing.
I record a short video here https://youtu.be/yvW8pOkl2_I
I have use a BlankClip in the video,you can see the GPU load change after I close and reopen the chrome .
Old 26th February 2018, 12:35   #1333  |  Link
HolyWu
HolyWu's Avatar
You should really use something like GPU-Z instead of Win10's task manager for measuring GPU Load.
HolyWu is offline   Reply With Quote
Old 26th February 2018, 13:48   #1334  |  Link
fadedmaple
fadedmaple's Avatar
A rookie mistake ...
It works well with 90-100% GPU Load.
Old 26th April 2018, 12:45   #1335  |  Link
tuanden0
Could you give me a link to download onpencl for AMD? I can't find it anywhere
tuanden0 is offline   Reply With Quote
Old 26th April 2018, 13:07   #1336  |  Link
LigH
LigH's Avatar
In general, a hardware accelerated OpenCL driver should be part of a current graphic card driver (not knowing AMD, but nVidia drivers do install OpenCL.dll and additional hardware specific DLL files in the system director{y/ies}).
New German Gleitz board
Old 26th April 2018, 13:49   #1337  |  Link
Atak_Snajpera
OpenCL is a part of AMD GPU driver.
Old 26th April 2018, 15:25   #1338  |  Link
tuanden0
thank you, I installed
Old 17th November 2018, 11:15   #1339  |  Link
tormento
Acid fr0g
tormento's Avatar
@Khanattila what about trying to create a FFT3DCL filter?
@turment on Telegram
Old 21st November 2018, 09:54   #1340  |  Link
Arhu
I'm seeing some weird frame order issues that appear to be happening with KNLMeansCL for me. I'm not sure for how long it has been happening because I only noticed recently with some UHD encodes. It may go back a few months.
1. Without KNLMeansCL frames seem to be fine in the output.
2. With d=0 and some values vor s, a and h sometimes a frame is skipped and later on another frame is repeated.
3. With d>0 and particularly with some UHD sources I occasionally but repeatedly get jumbled frames. E.g. for frames 1, 2, 3, 4, 5, 6 I'd get 1, 2, 3, 2, 5, 6 or something like that.
I didn't have time for more tests yet, but wanted to ask if this is a known problem or if anyone knows why this could be happening? Maybe something with the GPU or some buffer? I'm using a Geforce 1060, currently updating drivers.
Here's a sample script from staxrip:
import os
import sys
ScriptPath = 'D:/stax/staxrip/Apps/Plugins/VS/Scripts'
sys.path.append(os.path.abspath(ScriptPath))
core.std.LoadPlugin(r"D:\stax\staxrip\Apps\Plugins\both\ffms2\ffms2.dll")
core.std.LoadPlugin(r"D:\stax\staxrip\Apps\Plugins\vs\fmtconv\fmtconv.dll")
core.std.LoadPlugin(r"D:\stax\staxrip\Apps\Plugins\both\KNLMeansCL\KNLMeansCL.dll")
clip = core.ffms2.Source(r"D:\clip.mkv", cachefile = r"D:\clip_temp\clip.ffindex")
clip = core.fmtc.bitdepth(clip, bits=16)
clip = core.knlm.KNLMeansCL(clip, d = 2, s = 4, a = 4, h = 0.5)
clip.set_output()
Arhu is offline   Reply With Quote
