Old 23rd June 2012, 21:00   #61  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
Originally Posted by Ronin-7 View Post
Very nice UI ozok, any chance of Flac audio encoding support being added in the future ?
Sure. I'll add it to the next release.
ozok is offline   Reply With Quote
Old 23rd June 2012, 23:56   #62  |  Link
ozok
ozok's Avatar
Update
Update:
-Added: Levels
-Added: Support for FLAC
-Added: Option to specify file size (roughly)
-Added: Option to specify aspect ratio
-Added: Checks if file has any chapters
-Fixed: Unnecessary Sox processes
Old 24th June 2012, 19:35   #63  |  Link
Mr. Monte
ozok,
Need some assistance please. When I click on the Audio tab..there are many options. How do I select what audio encoder I want to use. Seems all the tabs are active.
Also, I had a .divx file that encoded fine, but is not one of your supported file options. I had to select the dropdown and select all files to encode it. Might want to add .divx to the list
TIA
Mr. Monte is offline   Reply With Quote
Old 24th June 2012, 19:47   #64  |  Link
ozok
ozok's Avatar
@Mr. Monte the one that is active, that is to say selected, will be used as audio encoder. I'll add divx to supported extensions, thx.
Old 26th June 2012, 15:03   #65  |  Link
ozok
ozok's Avatar
Update:
-Added: Predefs to keep encoding settings for different situations
-Added: TX264 now adds an index if output file already exists
-Added: TX264 now checks output file to detect errors (does not work with splitting)
-Added: Encoding errors will be shown in the log and progress list
-Added: Audio encoder can be selected from a list
-Improved: Carried splitting options to filters page
-Fixed: Files added during encoding did not show on progress list
-Fixed: Invalid files could be added during encoding
Old 26th June 2012, 18:55   #66  |  Link
ozok
ozok's Avatar
Update:
-Fixed: TX264 shows error even though output files exist
-Updated: FFMpeg to N-41843-gc17808c
-Updated: mkvmerge to 5.6.0
-Updated: mkvextract to 5.6.0
Old 28th June 2012, 00:48   #67  |  Link
Spaceman-Spiff
I'm really liking this encoder GUI a lot. Thanks for the work, ozok
Spaceman-Spiff is offline   Reply With Quote
Old 28th June 2012, 01:42   #68  |  Link
Video Dude
Senior Member
Does this option consider audio as well?
For example, if I set the file size to 500MB, will the x264 video stream be 500MB or will the mp4/mkv (video+audio) be 500MB?
Video Dude is offline   Reply With Quote
Old 28th June 2012, 10:26   #69  |  Link
ozok
ozok's Avatar
@Video Dude, video+audio will be 500MB. But as i stated in the change log, it gives a rough estimation. It won't work if you select to copy or disable audio, for now.
Old 29th June 2012, 21:13   #70  |  Link
BK-201
First off this is a really nice encoder, it has actually replaced my other ones, and it works pretty well under Wine for Ubuntu XD
Secondly there are some things I've noticed:
1.) Even though there there is a x264.exe only the 8bit version works, when the 8bit x264.exe is swapped with the 10bit one and when the encode is started the video gets skipped, then the audio attempts to encode but it errors out at the end. So, Question is, why wont the 10bit x264.exe work?
2.) When encoding any file that has multiple subs/audio tracks, the encode will fail. I don't know if this is a problem because of the Wine emulation or a problem altogether.
3.) and finally on my small screen, the bottom buttons are cut off, everything below the crf values are not shown, might you be able to add a scroll bar that appears for smaller resolution screens?
BK-201 is offline   Reply With Quote
Old 29th June 2012, 21:20   #71  |  Link
ozok
ozok's Avatar
@BK-20
1. I don't know much about 10-bit encoding so I can't be more help.
2. Please send info about your file. Also send logs. I don't have any problem converting files with more than one audio/subtitle tracks. You can send samples, too.
3. I'll look into that. What is you resolution?
Old 29th June 2012, 22:38   #72  |  Link
BK-201
@Ozok
1.) That's okay 10-bit encoding wasn't of much importance.
2.) My file is ~24min long, has 2 audio and 2 subs, MKV container
My settings: Video - crf23, profile high, level 3, preset slower, tune animation, container MKV, other settings are default. Audio - NeroAAC HE2 CBR 32
Here is a sample of my video (sorry it's kinda large 40mb) : http://www.mediafire.com/?cyx8hr7cobkf8rv
This shows where the error began: http://sadpanda.us/images/1049951-RVJZPTT.jpg
3.) My screen resolution is 1024x600
Old 30th June 2012, 11:10   #73  |  Link
ozok
ozok's Avatar
@BK-201 one of the audio tracks of your source has 6 channels. I assume you try to encode that one. Hev2 only accepts stereo input AFAIK. Either you must use "HE" or you must mixdown 6 channels to stereo under "Effects".
Old 1st July 2012, 11:41   #74  |  Link
ozok
ozok's Avatar
Update:
-Added: Option to force TX264 to use 32-bit backends
-Added: Option to auto save log
-Improved: TX264 checks if system is 64-bit instead of CPU
-Fixed: Corrected "Time Left" to "Time Passed"
Old 2nd July 2012, 05:42   #75  |  Link
rexdeymond
@ozok
1. Previously I was very satisfied with fearture "-Fixed: TX264 shows error even though the output files exist" is helpful and make easy to use [for newbie encoder like me], but I'm still hoping on the "Option to specify the file size [fixed file size or automatically calculate birate with video [i mean just file size option not with birate]]", and if you please, could you please additional video input WMV and more
2. Can I request a feature custom width and length of the form window that can be shifted to be enlarged or reduced, because the size of the form window that is very large and cover half the screen for a 10 inch screen notebook belongs to me
3. I want to now encoder audio with nero aac min birate for LC, i always encoder video with nero aac birate 64kbps always come HE/LC not come LC
4. TX264 may I upload it to the local forum in the state I, as a GUI encoder recommendation but I keep mentioning ozok as a creator. Faster internet speed in the country only for the local link, link international english language is too slow and not too care about the community in the state I
rexdeymond is offline   Reply With Quote
Old 2nd July 2012, 10:55   #76  |  Link
ozok
ozok's Avatar
@rexdeymond
1) I'll add support for wmv files.
2) That is asked really often so in the next release users will be able to reduce size of TX264 window.
3) Make sure profile is is set to "LC".
4) Yes of course. But remember to send me the link.
Old 3rd July 2012, 02:18   #77  |  Link
Video Dude
Senior Member
Thank you ozok for a great program.
File size estimation with copy audio is exactly what I was looking for. Thank you for consideration to possibly add it in a future release.
Old 3rd July 2012, 18:47   #78  |  Link
rexdeymond
@rexdeymond
I have made a mirror link for the file TX264 (0.7.8) to:
You may use link upload me as an alternative link download
Old 5th July 2012, 14:51   #79  |  Link
ozok
ozok's Avatar
Update
-Added: TX264's window size can be reduced now
-Added: Support for wmv files
-Added: File size now works with audio copy and no audio
-Fixed: File size audio bitrate was not used problem
-Fixed: Drag&Drop cold not add some file types
-Fixed: Audio copy did not work with mp3 (thx to zoom)
-Fixed: Audio copy audio track index problem (thx to zoom)
-Fixed: "Level" value could not be saved
-Updated: AlphaControls to 7.66
Old 6th July 2012, 04:49   #80  |  Link
soneca
ozok,
Great gui, keep improving!
soneca is offline   Reply With Quote
faac, mkv, mp4, neroaacenc, x264
