17th January 2007, 16:53 | #81 | Link |
Posts: n/a
@chros
Just as I pointed out in the other forum, it's the Sonic filters that mess around with telecine/pulldown flags. The VC-1 decoder itself will output 24fps progressive. Have you tried AssumeFPS() ? Last edited by honai; 17th January 2007 at 16:57. |
17th January 2007, 21:06 | #82 | Link | |
AssumeFPS("ntsc_film") as with v2.5.7 From the doc: The AssumeFPS filter changes the frame rate without changing the frame count (causing the video to play faster or slower). |
18th January 2007, 00:52 | #83 | Link |
i didnt
18th January 2007, 02:41 | #84 | Link | ||
mine is EVO -> sonic HD demuxer -> sonic video decoder -> VMR renderer 9. this plays the video fine in the preview but when trying to open the avs file i get this err Quote:
oddly, the demuxed video stream (VC-1) opens fine |
18th January 2007, 03:29 | #85 | Link |
@tomos: AVISynth connects to one output pin in the graph, so if you have all the pins already connected, how can it connect?
Like a little pig, you must save a teat on mother for it to suckle. Remove the video renderer, then AVISynth will be able to connect to the video output pin of Sonic Video Decoder. Last edited by Isochroma; 18th January 2007 at 03:32. |
18th January 2007, 10:41 | #86 | Link |
Here's a stand-alone command line EVOB demuxer for folks to try:
http://www.w6rz.net/evob_demux.zip Usage is: demux <-p> <infile> <video outfile> <audio outfile> <audio track> typically: demux movie.evo bits.mpv bits.mpa 0 The -p option dumps the PES header PTS values. Unfortunately, I have only one .evo sample file that bond pointed me to. So it's not very well tested. However, if folks could PM me with samples (of all flavors, VC-1, H.264, DD, DD+, etc.), it should be fairly easy to add stream types. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
18th January 2007, 10:46 | #87 | Link |
Life's clearer in 4K UHD
Indeed.... I would not mind some samples too!
18th January 2007, 13:27 | #88 | Link | |
18th January 2007, 13:34 | #89 | Link |
Is it right that movies on HD-DVD are 24 fps and not 23.976 ???
regarding to the avs script: I have done some test and calculation. I have opened the 2 feature file in PowerDVD, and the durations: f1: 01:09:13 , f2: 00:49:47 , so overall: 01:59:00 I have tried 3 version of the avs script: 1. no ivtc (none) , 2. TIVTC (as posted) , 3. TIVTC and AssumeFPS(24) The results (by avisynth): Code:
None: TIVTC: TIVTC+24 ------------------------------------------------- frames: 214035 171228 171228 time: 01:59:01:620 01:59:01:620 01:58:54:500 fps: 29.9701 23.9761 24.0000 fps: 5000000/166833 4000000/166833 24/1 |
18th January 2007, 15:00 | #90 | Link | |
[link removed] VC1 encoded, high bitrate (around 20mb/sec !). Sound is DDplus 5.1 according to Powerdvd Just tried your lovely exe on it. Seems to work for video, but not for audio (0k file, tried with audio track 0 & 1) Last edited by Koepi; 18th January 2007 at 20:52. Reason: Re-read rule 6 and the warning of blutach! Cheers, Koepi |
18th January 2007, 15:33 | #91 | Link |
@drmpeg
wvc1.dd plus.evo(15.0 MB) is a small sample. |
18th January 2007, 16:05 | #93 | Link |
Yes Video demuxx seems to work.
Well at least it wirtes some data What graph to use to playback the demux video? Kind of stuck atm Edit: Ok forgot the Sonic HD Demuxer now it works so video is demuxed Last edited by holzi; 18th January 2007 at 16:26. |
18th January 2007, 16:46 | #95 | Link |
I managed to get playback of evo files in zoom player and theatetek. It's really a bit of kludge but both audio and video works. The big problem. I cannot seek. Also, both files must begin at the same time so you cannot resume. Please take special note of the filter chain and ensure all are installed.
For zoom player use the following: 1. Create a file called evo.mediagraph 2. paste the following into the file: LoadFilter({9DC15360-914C-46B8-B9DF-BFE67FD36C6A},ReClock_Audio_Renderer) LoadFilter({51B4ABF3-748F-4E3B-A276-C828330E926A},Video_Mixing_Renderer_9) LoadFilter({7E2E0DC1-31FD-11D2-9C21-00104B3801F6},InterVideo Audio Decoder) LoadFilter({317DDB73-870E-11D3-9C32-00104B3801F7},InterVideo_Demultiplexer) LoadFilter({D7D50E8D-DD72-43C2-8587-A0C197D837D2},Sonic_Cinemaster®_VideoDecoder_4.1) LoadFilter({250D7B7D-4344-41FD-A284-7299B7765F18},Sonic_HD_Demuxer_0001) LoadFilter({E436EBB5-524F-11CE-9F53-0020AF0BA770},Source File_0) LoadFilter({E436EBB5-524F-11CE-9F53-0020AF0BA770},Source File_1) SetFilterFileName(Source File_0,<FileName>) SetFilterFileName(Source File_1,<FileName>) ConnectPin(Source File_0,Output,Sonic_HD_Demuxer_0001,Input) ConnectPin(Source File_1,Output,InterVideo_Demultiplexer,Input) ConnectPin(InterVideo_Demultiplexer,Audio,InterVideo Audio Decoder,In) ConnectPin(Sonic_HD_Demuxer_0001,Video Out,Sonic_Cinemaster®_VideoDecoder_4.1,Video in) ConnectPin(InterVideo Audio Decoder,Out,ReClock_Audio_Renderer,In) ConnectPin(Sonic_Cinemaster®_VideoDecoder_4.1,Video Out,Video Mixing Renderer 9,VMR Input0) 3. Save file in zoomplayer\mediagraph folder 4. In Zoom player (latest version) - go to system - filter management - manual fitlers and choose 'auto by extension' 5. Play file You can also use graphedit to export an xml file to use in theatertek. The problem I encountered with theatertek was that it would not except two blank source pins. Using the graph I created in Graphedit I could export it and use it solely in theatertek. Maybe someone can figure out a tweak. Have fun. Last edited by moshmothma; 18th January 2007 at 16:49. |
18th January 2007, 19:18 | #97 | Link |
Thanks drmpeg! Using the departed trailer EVO, I can successfully demux the H264 video track; it muxes just fine in the latest MKVToolnix 2.0.0 (with first update installed too).
However, the audio track does not work (it's regular AC3), the output file is created but it is 0 bytes. Last edited by Isochroma; 18th January 2007 at 19:29. |
18th January 2007, 19:43 | #99 | Link |
Posts: n/a
@moshmothma
tried your graph on three movies: - Pitch Black: no sound at all - Serenity: no sound at all - Chronicles of Riddick: the Intervideo Audio Decoder downmixes to stereo, no sound if I switch to S/PDIF output It seems that Intervideo doesn't decode DD+ at all, but in case of Riddick simply downmixes the DTS track in there. Tried putting in the Cyberlink Audio Decoder, but won't work either. |
18th January 2007, 20:01 | #100 | Link |
Posts: n/a
The commercial HD-DVD rips I have here use 0xc0 .. 0xc2.
However, two unsolved problems remain: * we can't mux VC-1 elementary streams because the tech spec is payware * we can't mux/decode DD+ (other than proprietary playback/downmixing inside PowerDVD) because there's no DirectShow decoder for it |
