18th March 2012, 13:29 | #9981 | Link |
Firefox User
@nev:
since rev 21a7ead LAV splitter stalls the system for ~1 minute with this MP4 sample, which only stalls for 0.5~2 seconds before. (OS: XP SP3) Sample: http://roy.orz.hm/samples/Nisemonoga...okoku_480p.mp4 |
18th March 2012, 13:31 | #9982 | Link | |
18th March 2012, 13:44 | #9984 | Link | |
Firefox User
Disabling DXVA in MPC-HC Video Decoder or using LAV Video have no problem. Last edited by roytam1; 18th March 2012 at 13:47. |
18th March 2012, 13:55 | #9985 | Link |
Play fine for me with MPC-HC DXVA2 or Software, cannot test DXVA1.
In any case, seems more like a bug in the decoder. Like i explained before, nothing really changed in the splitter, except some minor ffmpeg fixes.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 18th March 2012 at 14:01. |
18th March 2012, 16:37 | #9986 | Link | |
On my XP SP3 machine with 9800GTX and MPC-HC DXVA1 that file doesnt hang, but I get bad blocking for the first ~12 seconds of the file. LAV Video Cuvid ofcourse not affected. Edit: MPC-HC MP4 Source filter and its the same. so if this is fixable its a MPC-HC DXVA decoder bug most likely. Last edited by dead_screem; 18th March 2012 at 17:48. |
18th March 2012, 18:31 | #9987 | Link |
RedDwarf Fan
Is there any way to tell whether hardware acceleration is active when playing a video?
Looking at GPU-z does suggest that it is because of the video engine load and CPU usage also suggests that it is, but 15 ref frame 1080p hardware acceleration doesn't seem likely. |
18th March 2012, 21:17 | #9989 | Link |
Did you guys happened to have the experience of DXVA2 copy back mode has a green strip on top of the video with some 720p h264 videos while DXVA2 native mode works correctly?
mpc-hc latest version NV3100 Video card with laptop Thinkpad T410 LAV latest stable version |
18th March 2012, 22:11 | #9990 | Link |
I have not seen it, but if you have a file that shows the problem, please cut a small piece out of it (10-20MB, use a tool like DGSplit), and upload it to Mediafire (and post the link, of course)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 18th March 2012 at 22:21. |
18th March 2012, 22:51 | #9991 | Link |
nevcairiel, I've come accross a couple of blu-ray discs that for some reason cannot find the audio tracks. The discs both have 2 audio tracks, both being 5.1 Dolby Digital (one in Swedish, and one in English) the movies are: The Girl who Played with Fire and The Girl who Kicked the Hornets Nest. Lav Splitter loads, as does Lav Video and MadVR, but no audio filters load up.
Using the latest MPC-HC 4153 with the latest Lav Filters 0.49 release version. If you need any other information please let me know. (the discs are the US or North American releases)
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
18th March 2012, 23:13 | #9992 | Link |
Software Developer
gleb:
I failed to reproduce the freeze issue, pressing "S" for over 10 seconds and different positions in the sample file. I used LAV, both 0.49 and the latest beta linked by nev here. LAV was used as splitter and audio/video decoder, MadVR (0.82.5) as video renderer. You can help debug if the issue is related to ZP's DSP filter by disabling the filter in the options (Adv. Options / Playback Audio - Enable Internal Equalizer ...) nev: ZP has detailed error dialogs which explain why Smart Play fails (Adv. Options / Playback / Smart Play / Settings - Show smart play graph creation errors). Or if the dialogs are annoying, you can have their output saved to a file instead (same options dialog area). When smart play fails to build the graph, ZP lets directshow build its own graph, only replacing the audio and video renderers per user selection. Last edited by Blight; 18th March 2012 at 23:26. Reason: investigation complete |
19th March 2012, 11:07 | #9993 | Link |
I have a request I would like if we see the line Title: instead of language: in MPC-HC. The reason is that you can have several subtitles with the same language and it's pretty hard to know which one viewing when you view the language:
Can you maybe make it so that both the title and language appear? eg: Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 43mn Bit rate mode : Variable Bit rate : 25.8 Mbps Maximum bit rate : 31.5 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.518 Stream size : 18.6 GiB (80%) Title : Toy Story 3 Default : Yes Forced : No Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Codec ID : A_DTS Duration : 1h 43mn Bit rate mode : Variable Bit rate : 2 506 Kbps / 1 510 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossless / Lossy Title : Engelsk DTS 7.1 HD-MA Language : English Default : No Forced : No Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Codec ID : A_DTS Duration : 1h 43mn Bit rate mode : Variable Bit rate : 2 848 Kbps / 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Title : Engelsk DTS 5.1 HD-MA Language : English Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 1h 43mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 472 MiB (2%) Title : Dansk AC3 5.1 Language : Danish Default : Yes Forced : No Text #1 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Dansk tale Language : Danish Default : No Forced : No Text #2 ID : 6 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Title : Dansk PGS Language : Danish Default : No Forced : No Text #3 ID : 7 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Title : Dansk tale Language : Danish Default : Yes Forced : No Menu 00:00:00.000 : en:00:00:00.000 00:04:53.543 : en:00:04:53.543 00:06:20.255 : en:00:06:20.255 00:11:37.405 : en:00:11:37.405 00:15:17.166 : en:00:15:17.166 00:18:34.196 : en:00:18:34.196 00:19:23.871 : en:00:19:23.871 00:26:17.117 : en:00:26:17.117 00:28:59.404 : en:00:28:59.404 00:31:47.822 : en:00:31:47.822 00:33:22.333 : en:00:33:22.333 00:35:50.064 : en:00:35:50.064 00:37:30.123 : en:00:37:30.123 00:40:11.325 : en:00:40:11.325 00:41:12.637 : en:00:41:12.637 00:43:37.490 : en:00:43:37.490 00:44:49.270 : en:00:44:49.270 00:48:19.521 : en:00:48:19.521 00:52:28.061 : en:00:52:28.061 00:53:51.895 : en:00:53:51.895 00:57:11.970 : en:00:57:11.970 00:58:20.705 : en:00:58:20.705 01:01:09.999 : en:01:01:09.999 01:02:06.639 : en:01:02:06.639 01:02:57.023 : en:01:02:57.023 01:06:35.032 : en:01:06:35.032 01:11:21.735 : en:01:11:21.735 01:15:57.261 : en:01:15:57.261 01:17:35.817 : en:01:17:35.817 01:19:43.195 : en:01:19:43.195 01:23:01.935 : en:01:23:01.935 01:24:59.594 : en:01:24:59.594 01:28:15.582 : en:01:28:15.582 01:34:18.277 : en:01:34:18.277 |
19th March 2012, 12:13 | #9994 | Link | |
If you use in MPC-HC the Navigate -> Subtitle Language menu, or the Play -> Filters -> LAV menu, it'll show stream titles and the language.
19th March 2012, 16:12 | #9997 | Link |
Indeed. Thats MPC-HCs doing, request the feature there.
There is also ITrackInfo which can be used to get only the title and/or language without all the codec information from IAMStreamSelect
19th March 2012, 17:03 | #9999 | Link |
However, i do not see any problems with that file. Plays just fine with DXVA2-CB for me, no green strip or anything.
