14th April 2009, 13:08 | #2121 | Link |
Home Theater Freak
BTW deank, are you aware of this thread that mentioned something about a free utility called AVCHD patcher that helps to make AVCHD menu to be played correctly on a PS3? Sorry I sold off my PS3 and now I didn't have a chance to test on it...Here's the link: http://www.dvinfo.net/conf/blu-ray-a...s-you-can.html
Here's the direct link: http://www.avsforum.com/avs-vb/showp...postcount=1662 Cheers!~ Last edited by desray; 14th April 2009 at 13:23. |
14th April 2009, 13:08 | #2122 | Link |
Programmer (or just 教务长)
Oh, okay. I suggested the option because fifteen said that he tested on DVD, not BD-R.
I believe that your test will be successful if you use [Blu-ray for BD-R]. Stricter.... is not applied in this case anyway. --- About AVCHD Patcher - I strongly suggest users NOT TO TRY IT EVER on multiAVCHD output. I know what it does and it is not needed for multiAVCHD index.bdmv file. goBD does the same and its idea was to make BD structures written on USB or DVD to be accepted as AVCHD in PS3 and some other players. Last edited by deank; 14th April 2009 at 13:13. |
14th April 2009, 13:24 | #2123 | Link | |
Home Theater Freak
14th April 2009, 14:30 | #2128 | Link |
Brazilian PS3 Fanboy
Dean, you said something about language tags, and I have a suggestion: I can't seem to make subtitles be understood as Portuguese, it is always identified as "Other".
However, mkv2vob is able to identify the language correctly, as you can define the language when adding a file. I know that the purpose of multiAVCHD is different, as I can load numerous files, but maybe there could be an audio/subtitle language option on the "Edit" tab that opens up when editing the titles names. On that option, you could actually choose between many languages the ones you are adding. Just a suggestion, anyway, as it is not actually a problem. Keep up the good work! Cheers! |
14th April 2009, 14:56 | #2129 | Link |
You may try to rename the subtitles and put them in order as:
movie.mkv movie.01.por.srt movie.02.eng.srt or you may try to use "CLIPINF Editor" to correct the subtitles and soundtrack.
Paul Ng Last edited by drpaulng; 14th April 2009 at 15:04. |
14th April 2009, 21:39 | #2135 | Link | ||
@deank
i ve no other log than the one i have post yesterday. i put it again : Quote:
and same issue. The mpls containing the m2ts of the movie is 00000.mpls too Here is the log : Quote:
In these two cases, the compilation does nothing, it stop after only 2 seconds. |
14th April 2009, 21:47 | #2136 | Link |
It is a weird thing to ask but can you put 'cmd.exe' in your multiAVCHD folder? You should find it in windows\system32\cmd.exe
The error in the log: [15:13:56] Converting PLAYLIST to AVCHD (E:\King Arthur\BDMV\PLAYLIST\00000.mpls). [15:13:56] Error obtaining information (tsMuxeR)!(00000.mpls)... [15:13:56] No valid information found! (00000.mpls)... means that multiAVCHD tries to obtain info (using tsmuxer) and it doesn't work... It doesn't have anything to do with your source. Last edited by deank; 14th April 2009 at 21:51. |
15th April 2009, 00:30 | #2137 | Link |
Home Theater Freak
Gosh...what's with this mpls (playlist) thing going on? I haven't really try the new feature as I dun need to get the chapters to work...but issit really that hard to get it work? deank, can you list down the step(s) perhaps on how to go about doing it? I can try to help out in the testing and see what's wrong...
From the screenshots, I guess all I need to do is to use TXMuxer and add the PLAYLIST (with files extension 'mpls') and mux it, right? So the result will be having the movie with chapter markers added in, right? |
15th April 2009, 08:13 | #2140 | Link |
Yesss !
@deank : your clue about cmd.exe put me on the runway cmd.exe in the multiAVCHD not worked but.... it make me realize the problem could be the directory where i put the multiAVCHD (in my case : D:\- APPLICATIONS -\- Utilitaires vidéo -\multiAVCHD) so i move multiAVCHD to C:\multiAVCHD and TADAAAA !!!!!! It works ! So thx a lot. Last edited by navycrow; 15th April 2009 at 08:17. |
