Old 13th April 2009, 16:29   #2101  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Okay, open it in tsmuxerGUI and check what it will say.
Old 13th April 2009, 18:01   #2102  |  Link
shv
I did already first test with 3 movies and it works without any problem. After only 20min I had all 3 movies on the Fat32 disc. Thank you for this nice feature it is a great help to prevent much manual work for watching movies with the PS3. I used AVCHD manager before and needed to start TsMuxeR for each movie and go back with the disc to the PC to switch the active movie.
shv is offline   Reply With Quote
Old 13th April 2009, 19:10   #2103  |  Link
navycrow
do you thrust peoples sometimes ???
it say what i told you
navycrow is offline   Reply With Quote
Old 13th April 2009, 19:14   #2104  |  Link
deank
deank's Avatar
Download the full Setup (from 1st post) and try again.
Uncheck [x] Delete temp files and check your _temp folder... there should be 00000.meta... please paste its contents to compare to tsmuxer's meta in gui.
Old 13th April 2009, 21:11   #2105  |  Link
golemik
Hi deank
Congratulation - this is ideal for me soft.
I have - multiAVCHD 2.5 (built 523)
1) Could you make a change in menu properities - Headline offset- to X and Y coordinate system separatelly.
2) Can I add audio file to menu?
Regards
golemik is offline   Reply With Quote
Old 13th April 2009, 21:18   #2106  |  Link
deank
deank's Avatar
Headline offset is used in all 3 types of menues (classic/thumb/xmb) and I guess you're asking for the XMB one. There is not much space in the GUI to fit one, but I'll think of it.
The audio - no - until a proper muxer is available to mux avc+igs+ac3. At this point I managed to do avc+igs in a real brute-force way.
Old 13th April 2009, 21:49   #2107  |  Link
Butterfly666
Butterfly666's Avatar
Yes, update to build 499 and you'll find an option in settings [x] and delete video if removed
MTS/m2ts file will be renamed to *.del if option is unchecked. Also clpi/mpls files will be renamed to .del in their folders.
Hi Deank, I had tested but what about if I want to add the old movie back (renamed to .del) with other movies in 1 MultiAVCHD again?
MultiAVCHD doesnt read the file or title name from .del.
Butterfly666 is offline   Reply With Quote
Old 13th April 2009, 21:53   #2108  |  Link
fifteen
Did anyone had a chance to try multiAVCHD output with the new buttons (for Blu-ray) to players OTHER THAN PS3?
New Bluray output to BD5 (DVD+R):
works on Sony BDP-S350
doesn't work on Samsung BD-P1500
fifteen is offline   Reply With Quote
Old 13th April 2009, 21:55   #2109  |  Link
deank
deank's Avatar
You people really have strange ideas...
you can rename all .del files back to .clpi/mpls/m2ts and put an index.bdmv in your old/deleted multiavhcd compilation.
Old 13th April 2009, 22:15   #2110  |  Link
@gordan
Seven Pounds.2008.D.BDRip.720p_RST.mkv
Do not discuss torrent downloads on this board, per forum rule 6.
http://forum.doom9.org/forum-rules.htm
Old 13th April 2009, 22:34   #2111  |  Link
deank
deank's Avatar
Originally Posted by fifteen View Post
New Bluray output to BD5 (DVD+R): works on Sony BDP-S350, doesn't work on Samsung BD-P1500
Well the button says BLU-RAY FOR BD-R (not for DVD), so I asked for comments about people trying it with BD-R/RE discs. Thanks anyway. It was not meant to work with DVD in the first place.
@neuron: I'm sorry - I probably missed this post... d..
Old 13th April 2009, 22:52   #2112  |  Link
Butterfly666
Thanks again for the guide Deank !
Old 13th April 2009, 23:30   #2113  |  Link
fifteen
Just thought you'd like to know results on DVD media.... I'll test with BD-R/RE shortly.
Old 13th April 2009, 23:58   #2114  |  Link
turbojet
If you remove AUXDATA directory does DVD play on Samsung BD-P1500?
Old 14th April 2009, 07:22   #2115  |  Link
tkamp
Hi DeanK
I have a little proposal for a feature:
It would be nice to be able to append titles/videos to an already authored AVCHD. This would cut down the authoring time, and you would be able to collect all your titles in the same AVCHD.
Regards
tkamp is offline   Reply With Quote
Old 14th April 2009, 08:10   #2116  |  Link
deank
deank's Avatar
It is possible.
Read here or read the 1st post.
A small tweak was added in latest build:
If you import MPLS files they will show in Editor tab with FOLDER_NAME taken from the path. For example
D:\Training_Day\bdmv\playlist\00000.mpls
you will see Training Day in Editor tab.
Old 14th April 2009, 12:25   #2117  |  Link
deank
deank's Avatar
Build 524:
MPLS file import:
* Fixed: A_LPCM was not detected
* Fixed: Audio track delays were not detected
* Added: [x] Keep all audio tracks now affects MPLS tracks, too.
* Added: [x] Add embedded subtitles now affects MPLS tracks, too.
* Added: [x] Add external subtitles now affects MPLS tracks, too. (you can add 00XXX.srt / 00XXX.sup with 00XXX.mpls)
* Added: [x] Add external audio tracks & [x] and keep original now affect MPLS tracks, too.
(You can add 00XXX.dts/ac3/lpcm with 00XXX.mpls / you can also use .LID. for audio and subtitles, ie 00XXX.fre.srt 00XXX.deu.ac3)
In other words you can load your movie mpls file and strip it off of all subtitle and audio tracks (except the 1st one or add external) and get smaller output size.
@navycrow: Please try again with your movie. I'm sorry - the problem may have been with the improper detection of the A_LPCM in your movie.
Old 14th April 2009, 12:54   #2118  |  Link
desray
Home Theater Freak
desray's Avatar
Let me try on my Samsung BD-P1400 and report back the result.
desray is offline   Reply With Quote
Old 14th April 2009, 12:56   #2119  |  Link
deank
deank's Avatar
Make sure to use [AVCHD for DVD/BD-R] and [x] Stricter AVCHD folder format option. Otherwise I doubt it will work.
Old 14th April 2009, 13:05   #2120  |  Link
desray
Home Theater Freak
desray's Avatar
Sorry deank, didn't get what you meant...you mean to say to check the Stricter AVCHD folder format? But I thought we're testing on a BD media? Why will I want to check this option?
