17th January 2012, 00:53 | #14041 | Link |
That filename is illegal because it can't be used as a volume label. Why would anybody use a name like that anyway? But even with that said, I don't know why you are posting it as a bug when you haven't found anything at issue. Does it play correctly? I would think so. My guess is that Total Commander is wrong (considering the fact that both files are the exact same length). But even if they don't match -- unless you can tell me what issue there is, I don't see why you're reporting it as a bug. It's entirely possible that TSMUXER made some small change in a header, etc. as a result of the long filename. But unless it causes a problem, I don't know why we're talking about it...
17th January 2012, 08:42 | #14042 | Link |
hmm... This name for an example. The name as a name, on Internet open spaces meets often. I can put many examples when renaming of folders gives identical at comparing. I always compared and never received distinction. It has happened for the first time. Yes, i consider as an error. Shouldn't change algorithm the code at identical setting. Also shouldn't depend on a name of folders, a location of a source, the carrier and etc. Don't blame Total Commander, it is the faultless program. I repeat once again, "output bluray folder" is played back correctly. However, i thought that you can explain such behavior. Sorry, if that.
http://www.imagebam.com/image/b578fc170205049 P.S. I suppose that anybody never spoke to you about it. But my profession the system administrator... A habit to check and compare the code in blood. Excuse me at my bad english. Last edited by Locator; 17th January 2012 at 09:24. |
17th January 2012, 17:25 | #14044 | Link | ||
Done. End. This is nothing more than an academic discussion and serves no purpose here. If you want to discuss if further you need to start a new thread -- as it clearly isn't a BD-RB bug. Last edited by jdobbs; 17th January 2012 at 17:29. |
17th January 2012, 18:49 | #14045 | Link | |
Bob. |
18th January 2012, 17:50 | #14046 | Link |
I am having a problem making a DVD-5 of my "A River Runs Through It" blu-ray. It runs fine through converting subtitles to DVD format, MPLEX runs to 100%, then throws an error message. Ending Log entries follow:
[00:18:22]PHASE ONE complete [00:18:22]PHASE TWO - Rebuild Started - [00:18:22] Rebuilding stream 00011 [1 of 1] - [00:18:22] Building ALTERNATE OUTPUT Structure - [00:18:23] Converting 2 subtitles to DVD format. - [00:19:40] Starting MPLEX. - ERROR in attempt to mux (MPLEX) [00:22:02] - Failed to REBUILD The target hard drive has plenty of space available. I have uninstalled and reinstalled everything related to BD-RB (I think). When I run "Inspect", it indicates "OK" everywhere except for: - FFDSHOW VC-1 set incorrectly: [1]. It was [0] the first time I ran inspect, so I thought maybe that was an issue and I made a change. What should this entry be? Any ideas or suggestions to try are welcome and appreciated. Update: Tried with and without subtitles being included - no change. Ran same source through Clown-BD - it ran fine, the output looks fine. Update: Ran a couple additional different BD titles to DVD-5 alternate output with 1 audio and 2 subtitles. All ran fine. Output fine. Apparently there is something specifically about the "River Runs Through It" BD that BD-RB chokes on? Could the Dolby TrueHD lossless audio track on the source be causing a problem? Last edited by Rich86; 22nd January 2012 at 07:43. |
19th January 2012, 17:05 | #14047 | Link |
Not sure if this is the right place, But I just installed BDrebuilder 0.39.07, Then I ran inspect.exe, Which it said ffdshow and avisynth not recommened versions, I downloaded the versions here the one's you recommened, Or since this is a newer version of BDrebuilder should I download the new versions of ffdshow and avisynth?
19th January 2012, 19:12 | #14049 | Link | |
I've been testing a newer release of FFDSHOW for a few weeks now and haven't experienced any issues -- but I'd recommend you stay with the one linked in the first post of this thread until I'm confident the newer one is safe. FFDSHOW gets a lot of version releases and frankly I can't test all of them sufficiently. If you do decide to use a version other than the one linked in the first post -- I will not accept bug reports until you revert and reattempt your encode with that one. Last edited by jdobbs; 19th January 2012 at 19:18. |
19th January 2012, 21:09 | #14050 | Link | |||
20th January 2012, 03:43 | #14052 | Link |
After reading this ongoing exchange, I'm more incerested in "Will it Blend?". The disk that is.
Back on topic: The program works great for me. I'm quite happy with it and with jdobbs. So much so that I've donated a couple of times. Keep it up. |
20th January 2012, 16:36 | #14053 | Link |
Programmer
Some questions about INI config file. I have after every updated BD-Rebuilder, copied over my old INI file to keep my settings and then just renamed the version # at top.
This time around I decided to check if anything changed from one version to the next. By going thru the menus and some doc, I was able to figure out why I had some different, but there are some I do not know why I had them set the way I did. My older INI had AVCHD=0 versus the AVCHD=1 as found in latest version. What is this setting? I could not find details on it on the HIDDENOPTS.TXT I had these set as well and found there options on the GUI menu, but unsure why I had them set the way I did. Perhaps I read something in forums on using these settings this way. Can you briefly explain what these 2 do. I mainly only do 1080p Blurays so not sure these would even matter except for maybe the bonus features in 480i DEINTERLACE=0 (From setup menu - Use DEINTERLACER on interlaced sources) IVTC_PULLDOWN=1 (main menu - IVTC sources with 3:2 pulldown) Also is there a way to put commented line in INI file that will be ignored? I would like to add a FORCE_NOENCODE=1 that I can comment and uncomment when I want to. Otherwise I am always looking back to HIDDENOPTS.TXT to remember what the option is called. |
20th January 2012, 16:57 | #14055 | Link | |
AVCHD=1 -- Strict AVCHD. Some players require it for playing BD-5/9 DEINTERLACE=1 -- Turns interlaced into progressive, useful to get rid of annoying comb lines when playing back on a PC. Not necessarily needed for standalone playback. It can "smooth" the source a little. IVTC_PULLDOWN=1 -- Retains the original FILM picture structure on sources with pulldown. Should normally be kept set. Not setting it will result in hard-telecined output on a telecined source. I usually comment the INI file by preceding the comment line with a "#" -- but anything will work. Just don't add comments to the same line as the setting. Last edited by jdobbs; 20th January 2012 at 17:03. |
20th January 2012, 17:06 | #14056 | Link | ||
Programmer
#FORCE_NOENCODE=1 And then just uncomment it when I want BD-Rebuilder to see it. Will this not work? |
20th January 2012, 23:15 | #14058 | Link |
Think i've found a small bug. Just finished doing an alternate output for a miniseries blu-ray to pal DVD-5, the encode went ok but the temp folder was not removed. More specifically, during the remuxing / rebuilding a folder called THE_PILLARS_OF_THE_EARTH_D1 was created, when done with the process the final output folder was created called THE_PILLARS_OF_THE_EARTH_D1_DVD that contained the VOB files. However the now empty THE_PILLARS_OF_THE_EARTH_D1 folder was not deleted. A small glitch in the folder deleting process?
20th January 2012, 23:36 | #14059 | Link |
Had a problem backing up killer elite which I bought, Kept coming up x264.exe has stopped working, Finally I got it, Had to go into the BDRebuilder Setup menu and check this option to turn it on:Use X264's internal LAVF for decoding. Now I tried to do main movie only to a dvd-5 but now that's coming up x264.exe has stopped working, Do I have to go back and change = Use X264's internal LAVF for decoding and turn it off?
21st January 2012, 01:10 | #14060 | Link | |
