13th February 2011, 17:07 | #281 | Link |
I know inputtype=2 is meant for fixing badly deinterlaced footages. But it will appear to me that the original TGMC is doing a much better job, especially for those ill-brained field-duplicated deinterlacers. What parameters I should be tuning for these sources?
13th February 2011, 22:19 | #282 | Link |
Have you tried InputType=1? That's should be the same as what original TGMC does but without the frame duplication (which interferes with the motion analysis). It can be the appropriate method for less degraded sources.
InputType=2,3 drop half the fields - which is pretty extreme, but necessary when the source is a real mess. There's also this approach from a previous post: Code:
s = WhateverSource("Your.src") # Make versions from upper fields and lower fields (use TR2 and ProgSADMask also if you wish) t = s.QTGMC( InputType=2, ... ) # These lines work well with "SourceMatch=1, Lossless=2" (need v3.01+) b = s.QTGMC( InputType=3, ... ) # Now merge the results in some way. Choose ONLY ONE of the lines below and delete the other Merge( t, b ) # Smooth result, may need more sharpening t.Repair( Merge( t, b ), 1 ) # Sharper result, could try 2 at end of this line |
13th February 2011, 23:43 | #284 | Link |
Straight deinterlacing using multi-threading:
SetMemoryMax(M) # Optional line. Leave it out at first. See below for value M SetMTMode(5, X) # See below for value X WhateverSource("Your.src") SetMTMode(2) QTGMC( Preset="Slow", EdiThreads=Y ) # Choose preset based on overall speed/quality you want. See below for value Y Distributor() # This line may or may not be necessary, try it without - it may be faster - Start at the number of cores in your machine - If it crashes, decrease 1 at a time - Otherwise increase 1 at a time until CPU usage is very, very close to 100%, don't go too far or it will slow down Setting Y - Start at about half number of cores and tweak upwards or downwards for best speed. I find Y=1 often works best when using SetMTMode. - Obviously this is a balance with X Setting M - Using the SetMemoryMax line and choosing a good value for M can allow you to use more threads and so get more speed. Particularly important for slower settings - Try 400,600,800,1000 etc. [I should add this to the OP / docs...] |
14th February 2011, 00:19 | #286 | Link |
With Virtualdub I don't think you need the Distributor() line.
Try different versions of MT AviSynth if you get stability issues: Standard 2.57MT, SEt's 2.58MT or SEt's 2.6MT Last edited by -Vit-; 28th April 2011 at 13:51. |
14th February 2011, 01:27 | #288 | Link |
I don't know what that paste was about.
But in any case, MT avisynth is buggy. It might work with one script but not another. You should try the other versions. SEt's versions appear to be most reliable, but each system is different. There are many posts on the subject in this thread. |
14th February 2011, 02:44 | #291 | Link |
I would be interested to know which version of QTGMC you last had stable...
I've made very few changes to the core algorithm for several versions. There's nothing new in version 3 - the presets on their own should result in the pretty much same filter graph as always. I have been adding extra features, but they're all off by default so it should run just as before when you just provide a basic preset. However, I used to have more explicit conditions to remove unused filters, I now rely on avisynth to do that job when it builds the filter graph - I wonder if that is causing a problem. Maybe I should revert to doing things manually again... ____ EDIT: A quick look at the avisynth parsing code and I think if you don't explicitly put a conditional around an unused filter then its constructor is called anyway [correct me if I'm wrong devs]. That's unfortunate, it could cause unnecessary memory use at the least. In practical scripting terms it appears to mean that this: Code:
input = last processed = (setting == 1) ? input.ComplexFilter() : input return processed Code:
input = last processed = input.ComplexFilter() return (setting == 1) ? processed : input I'll revert back to my original method and see if there's a stability difference... stay tuned... Last edited by -Vit-; 14th February 2011 at 06:02. |
14th February 2011, 10:11 | #292 | Link | |
Avisynth language lover
How much impact this has will of course depend on how much memory the filter allocates on construction - many simple filters have nothing beyond a few simple variables, but something that keeps its own frame buffer (for example) will obviously use more. |
14th February 2011, 15:59 | #293 | Link |
...and I thought I was out of here. Well, I managed to reproduce my bug/error albeit in a still not completely conclusive way. And I'm also at the stage where in passing I'd like to apply a couple of old human adages to this technology: A: Honeymoons never last B: Life is a crap shoot.
That said, and after two successive crashes I managed to get a successful 9 hr encode (fast preset) for my l hr 10 min video. I also managed to custom start three threads for my modest core duo T8100. That should have given it some elbow room. Again, the encode and subsequent tests were avisynthproxy in avidemux and an x264 medium quality preset. On playback without even looking too hard I noticed some soft softs which are discernable in the following captures which reflect the order with which I tested various things. Areas to look for are bldg to far right, lst floor window 2nd from left and 2nd fl window lst on left. (1) shows the smoothing/obliteration equal to my full encode. I re-reproduced it using different crt and abr settings with identical results. (2) here, I rebooted avisynthproxy in SourceMatch 2 25p mode. The anomaly disappeared. (3) further reboot back into default QTGMC and here the smoothing went bananas, equivalent to what I experienced on Saturday. (4) booted avs script with default QTGMC in 25p (selecteven) mode...the problem disappeared. (5) finally back to original avs in 50p and once again the error was gone. I should add that I think the source sample is not virginal. It might have undergone some slight slow motion filtering. Vit, you mentioned 'memory corruption'. Whatever that's supposed to mean it doesn't get me very far. From my amateurish experience with computers over the years, in a case like this I'd always thought a hardware problem generally either translate into something that works or breaks. Be it the hardware itself or the task it was trying achieve. But it doesn't 'bend'. And this random smoothing strikes me as being just that: bending. The problem isn't systematic except for the fact it's only ever occurred in 50p mode, never with 25p. Is there something to be learned here? Maybe I should play it safe and stick with that. (SM=2 by the way was a decided upgrade from SM=1). Further, is there any reason NOT to do a quality archive copy @7000-8000 kbs using sourcematch just in 25p and either a) count on my Sony flatscreen's 100mhz 'motion flow' to iron out the judder or b) later on down the line when I'd like to play around with some 720p upscaling go about doubling the frames then and hopefully not suffer a quality hit. As I always back up the finished DV render on mini-DV tapes that shouldn't be a such a huge risk. You say, Vit, you've never had a 'failure' in hundreds of cases of QTGMC. But maybe you're on systems using quad-cores or far better. Which brings up the 'minimal configuration' issue. Is there one for this avisynth plugin? I just had a last thought as I write these words. All the tests I've done were through to an x264 encode. Wouldn't the truly rigorous method be to output to another DV avi file? How much might the encoder end of these operations be interfering in performance/image quality? As I recall x264 loop filter settings bear on perceived sharpness. Doesn't this complicate matters? Thanks for your continuing help. |
14th February 2011, 16:04 | #294 | Link |
Oops, my attachments disappeared.
EDIT: Sorry for error. I'd thought attachments would remain in a link form with info file name. Didn't want to bloat the thread. I've removed pics 4 & 5. The middle image represents what the correct encode should like anyway. Last edited by sadie; 14th February 2011 at 20:26. |
14th February 2011, 19:20 | #295 | Link |
For this kind of source file (known as 1080-60i):
Video ID : 2064 (0x810) Menu ID : 100 (0x64) Format : MPEG Video Format_Commercial_IfAny : HDV 1080i Format version : Version 2 Format profile : Main@High 1440 Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=3, N=15 Codec ID : 2 Bit rate mode : Constant Bit rate : 25.0 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.536 and thinking that almost all the time the camera will shoot in natural and good light-so the footage will look OK-what is the best: to stay interlaced and encode to x264(or MainConcept h264 AVC Broadcast) at 8-12 Mbps(not sure if 12 is not a waste of space) or to go progressive(720p) also encoded in x264 or MC-264avc at 6-8Mbps? For the second choice which settings for fast encoding speed?And keep 59.94 or to make a pulldown to 23,97? My script looks now (obvious with the help of some people from this forum): Code:
SetMemoryMax(900) SetMTMode(5,6) LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DGDecode.dll") MPEG2Source("C:\test5min.d2v") SetMTMode(2,6) AssumeTFF() ConvertToYV12(interlaced=true) Import("C:\Program Files\AviSynth 2.5\plugins\QTGMC3.05.avsi") spline36resize(1280,720) QTGMC( Preset="Fast", EdiThreads=4 ) Thanks Last edited by marcopolo80; 14th February 2011 at 19:29. |
14th February 2011, 21:26 | #296 | Link |
Here's a revised version of QTGMC (v3.10) which reverts to the approach of v2.x. This will call far fewer filter constructors, using less memory and maybe prevent the crashes some people have had. If you couldn't run the recent versions, please give this one a quick test and report back. I haven't updated the OP yet in case this doesn't help. I tested this multi-threaded in VirtualDub (1.9.10) on some 1920x1080x60i material at preset "Slow" - it was fine:
QTGMC v3.10 ____ sadie: I've never seen smearing like that out of QTGMC. Might it be x264? That can cause smearing, especially given that it's a fairly complex scene and you said you were going down to CRF 26? And it's strange that it is not consistently reproducible. These are deterministic algorithms, there isn't scope for variation. x264 does have a non-deterministic multi-threaded mode (the order of the threading calls is unpredictable and they get some tiny speed advantages by not worrying about that), but I don't think that mode is a default. However, x264 is getting in the way with these examples. I always encode lossless 1st pass, then x264 the result. You should try to reproduce the error in a lossless format. Better still you should post that source snippet, so I can try to reproduce the issue. ____ marcopolo80: That seems like a decent start, but you've made a mistake with the resizing - you shouldn't vertically resize before the deinterlacing. The last part of the script should be this: Code:
#... spline36resize(1280,1080) QTGMC( Preset="Fast", EdiThreads=4 ) spline36resize(1280,720) Last edited by -Vit-; 14th February 2011 at 21:43. |
15th February 2011, 12:32 | #298 | Link |
-Vit-!
Amazing!!! Now my HD source work SetMTMode(2,4) and placebo preset without crash (before work only SetMTMode(2,2)). I am also note speedup 20...40%. Waiting from Stephen R. Savage YUY2 release. Good work. |
15th February 2011, 14:37 | #299 | Link |
Thanks yup. I'll take that as confirmation that I've at least fixed something. I've updated the OP to v3.10
Avisynth only calls what it needs when frame-serving, but it initializes everything that isn't explicitly guarded with a condition. QTGMC contains a huge number of filters, many of which are not used unless you choose a particular setting. However, almost all of them were being initialized, which must have been using a great deal of memory - it was hard to tell because the avisynth cache uses a huge amount of memory anyway. Other scripters with conditional / optional processing should note the example above. |
15th February 2011, 15:40 | #300 | Link |
In My case, calling "mt_masktools-26.dll" in script, did the trick...
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools-26.dll") SetMemoryMax(1024) SetMTMode(5,8) DirectShowSource("C:\Documents and Settings\XyZ\Desktop\Svadba2.avi") SetMTMode(2) ConvertToYV12(interlaced=true) Import("C:\Program Files\AviSynth 2.5\plugins\QTGMC3.10.avsi") spline36resize(720,576) QTGMC( Preset="Slow", EdiThreads=8 ) spline36resize(720,432) I'm getting 34.10 fps with "Slow" preset on i7's Tnx Vit again ) p.s. Vit, this script, is it correct for 720x576 ( DV-PAL-interlaced 25.000)-->720x432? Last edited by @MeGui; 15th February 2011 at 16:25. |
