2nd July 2009, 14:59 | #21 | Link |
There's a difference between changing defaults. ie: being changed on a regular basis, and, changed, ie: being changed after how many years?
http://www.7-zip.org/ |
2nd July 2009, 15:14 | #23 | Link | ||
Software Developer
Whether x264 simply ignores all parameters that are already covered by the preset or whether it throws an error when I try to explicitly change a parameter that is already covered by the preset, I just don't like the idea that the preset doesn't allow me to customize any parameters. It would lead to the situation where I would like to use preset X, but there's one parameter I need to adjust. Then I would have to completely drop the preset and specify ALL parameters explicitly. That's really not very convenient... Quote:
First of all we start with the x264 defaults (always). Then we apply a preset (optionally). Finally we apply all custom parameters. That's basically how any x264 GUI works. For example: In MeGUI you can select a preset first and then you can adjust single options in the configuration window So we basically don't change the default, but we provide "shortcuts" for popular parameter combination. You can call it however you like. Still we should give the user the opportunity to change single parameters when needed, even when a preset was selected...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd July 2009 at 15:19. |
2nd July 2009, 15:53 | #24 | Link | |||
I wanted to suggest that, in my opinion, --presets should like --profiles "override all other options no matter what,.." and/or complain then one changes an option that is already specified by the preset. I got it that you don't share that opinion and we both have different ways we think about it, plain and simple. Cu Selur |
2nd July 2009, 16:26 | #27 | Link | |
that being the case, can we finally have a 360 device preset ASAP too?. that currently stands at, and plays without stutter is a max of 10Mbit/s H@L4.1, ref 3 for 1920×1080 at 30 fps (confirmed as the max for 25fps PAL 360 playability too, 11Mbit,ref3 was bad on beetlejuice dvd , as was 10Mbit,ref4) in a generic mp4 container. http://support.xbox.com/support/en/u...aybackfaq.aspx "... Q: What does the Xbox 360 console support for H.264? A: The Xbox 360 console supports the following for H.264: File extensions: .mp4, .m4v, mp4v, .mov, .avi Containers: MPEG-4, QuickTime Video profiles: Baseline, main, and high (up to level 4.1) Video bit rate: 10 Mbps with resolutions of 1920 × 1080 at 30 fps. See the question about max bit rate, resolution, and frames per second. Audio profiles: AAC, 2-channel, Low Complexity Audio max bit rate: No restrictions. See the question about max bit rate, resolution, and frames per second. ..." Last edited by popper; 2nd July 2009 at 16:53. |
2nd July 2009, 19:54 | #28 | Link |
here's a suggestion for
ultrafast: Code:
--ref 1 --scenecut 0 --partitions none --me dia --mvrange 64 --merange 4 --subme 0 --no-mixed-refs --no-chroma-me --no-8x8dct --aq-mode 0 --trellis 0 --threads auto --no-cabac --no-deblock --no-psnr --no-ssim --non-deterministic |
2nd July 2009, 21:18 | #29 | Link |
HDConvertToX author
X264;1;Ultra Fast;--keyint 250 --bframes 1 --trellis 0 --ref 1 --deblock 0,0 --subme 2 --direct spatial --me hex --no-ssim --merange 8 --b-adapt 0 --no-chroma-me --aud X264;2;Very Fast;--keyint 250 --bframes 2 --trellis 0 --ref 2 --deblock 0,0 --subme 3 --direct spatial --me hex --no-ssim --merange 10 --b-adapt 0 --no-chroma-me --aud X264;3;Fast;--keyint 250 --bframes 3 --trellis 0 --ref 3 --deblock -1,-1 --subme 4 --direct auto --me hex --no-ssim --merange 12 --weightb --b-adapt 2 --b-pyramid --partitions p8x8,i8x8 --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.0:0.0 X264;4;High Performance;--keyint 250 --bframes 3 --trellis 0 --ref 3 --deblock -1,-1 --subme 5 --direct auto --me dia --no-ssim --merange 14 --weightb --b-adapt 2 --b-pyramid --partitions p8x8,i8x8 --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.0:0.0 X264;5;Balanced;--keyint 250 --bframes 3 --trellis 0 --ref 3 --deblock -1,-1 --subme 5 --direct auto --me dia --no-ssim --weightb --b-adapt 1 --partitions p8x8,b8x8,i8x8 --8x8dct --aud --aq-mode 0 --aq-strength 0 X264;6;Better Quality;--keyint 250 --bframes 5 --mixed-refs --trellis 1 --ref 4 --deblock -1,-1 --subme 6 --direct auto --me umh --no-ssim --weightb --b-adapt 2 --b-pyramid --partitions p8x8,b8x8,i8x8 --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.0:0.0 X264;7;Extreme Quality;--keyint 250 --bframes 4 --mixed-refs --trellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --me umh --no-ssim --weightb --b-adapt 2 --no-chroma-me --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.1:0.0 X264;8;Insane Quality;--keyint 250 --bframes 6 --mixed-refs --trellis 2 --ref 6 --deblock -1,-1 --subme 7 --direct auto --me umh --no-ssim --merange 20 --weightb --b-adapt 2 --b-pyramid --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.0:1.0 X264;9;Slug;--keyint 250 --bframes 8 --mixed-refs --trellis 2 --ref 8 --deblock -2,-1 --subme 8 --direct auto --me esa --no-ssim --merange 24 --weightb --b-adapt 2 --b-pyramid --partitions p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 X264;10;Placebo;--keyint 250 --bframes 16 --mixed-refs --trellis 2 --ref 16 --deblock -2,-1 --subme 9 --direct auto --me tesa --no-ssim --merange 24 --weightb --b-adapt 2 --b-pyramid --partitions all --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
2nd July 2009, 22:16 | #30 | Link |
Straight to video
Thanks Dark Shikari.
How about a new DV preset? In most of the prosumer camera footage I've seen, --deblock -1:-1 is too weak (0:0 works better for me). That makes me wonder if the other film preset parameters such as psy-rd are also in need of adjustment for DV. I'm no expert, so I can't say.
3rd July 2009, 05:33 | #31 | Link | |
Is that mean for "Slower" profile I should turn the "merange" from 24 (as in Placebo profile) to 0 (Zero) ? |
4th July 2009, 06:38 | #34 | Link |
cool, this sounds great
i think we should do something similar to msu's x264 preset comparison thing to find optimal combinations of options @buzzqw- "high performance" is kinda ambiguous... and why does the 7th preset have subme9?? i think threads=1 should be added to the placebo preset |
4th July 2009, 11:01 | #37 | Link | ||
4th July 2009, 11:23 | #39 | Link | ||
64 for slow 128 for placebo at 1920. 24 for slow 32 for placebo at 720p. LE : what about auto --keyint and --min-keyint aproximated for the fps ? Now i use ffmpeg to get the fps and this script for 24-60 FPS : Quote:
development, interface, x264 |
