Old 3rd January 2009, 16:29   #1  |  Link
M_Knox
Custom user
M_Knox's Avatar
Hex bit operands plugin v0.8 for PgcEdit (2009.02.05)
As of PgcEdit 9.1 release I may present you my little plugin for this excellent program (as already announced by r0lZ).
Hex bit operands requires PgcEdit version 9.1 or later to function. If you use it with any previous version the plugin will be disabled - in this case upgrading PgcEdit to a supported version will not enable plugin by default, you'll have to do it manually.
The plugin allows to display operands of SET bit operations (|=(or), &=(and), ^=(xor)) and bit comparison (&) in hexadecimal notation.
The second function of the plugin is to display descriptions of bit operations.
A few examples of the plugin-enabled output:
Set gprm(0) &=(and) 0x0000 (clear all bits)
Set gprm(0) &=(and) 0xFCE2 (preserve bits 1, 5-7, 10-15)
Set gprm(0) &=(and) 0xFFEF (clear bit 4)
Set gprm(0) |=(or) 0xFFEF (set bits 0-3, 5-15)
Set gprm(0) |=(or) 0x0000
Set gprm(0) ^=(xor) 0xFFEF (toggle bits 0-3, 5-15)
Set gprm(0) ^=(xor) 0xFFFF (toggle all bits)
if ( gprm(0) & 0x0314 ) then { Set gprm(0) ^=(xor) gprm(0)}
These description can be turned on and off independent of hexadecimal format (i.e. you may display operands in decimal format while displaying the descriptions and vice versa).
As you can see, the description is not added to bit comparison, because the output would be too cluttered.
To download the plugin go to the "Plugins" section of r0lZ's homepage (http://download.videohelp.com/r0lZ/pgcedit/#plugins)
Please post any feedback in this thread.
Thank you for your attention.
edit:
As in case of any changes to the plugin I will not force r0lZ to update his homepage, I created an alternative link to the latest version of the plugin:
http://members.elysium.pl/morris/pro...plugin_v08.rar
M.O.R.R.I.S.: Mechanical Obedient Replicant Responsible for Infiltration and Sabotage
morris#rarlab*com
M_Knox is offline   Reply With Quote
Old 3rd January 2009, 16:34   #2  |  Link
Wombler
Affable Wanderer
Wombler's Avatar
Excellent job M_Knox!
Thanks for that.
Wombler
Wombler is offline   Reply With Quote
Old 4th January 2009, 01:44   #3  |  Link
blutach
Country Member
blutach's Avatar
Many many thanks for this.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 5th February 2009, 18:54   #4  |  Link
M_Knox
Custom user
M_Knox's Avatar
hexbitoperands plugin v0.8
I slightly updated the plugin, so it now allows display descriptions in comparison operations (that one was for you, blutach! ). I've also added an option to enable hexadecimal output for all Set operations (like simple assignment, addition, multiplication, etc.) - but these operations do not have descriptions.
For the download link please see the first post in this thread.
morris#rarlab*com
Old 6th February 2009, 00:05   #5  |  Link
blutach
Country Member
blutach's Avatar
Thanks very much!
Regards
Les
hexadecimal, operands, pgcedit, plugin
