18th March 2007, 16:12 | #762 | Link | |
AXP and Duron (old, no sse, generic) - w2ksp4, no additional codecs\splitters\packs. AXP under clean ws2003. Just invoke ffdshow via player's control, i.e. mpc - filters -> ffdshow video decoder, then close, then invoke once more. Or the same via tray control. |
18th March 2007, 19:30 | #764 | Link |
ffdshow/AviSynth wrangler
Okay, here's another updated version of my AviSynth filter:
The current installer based on revision 1048 (and previous versions) can be found here Patch is here Changes are that setting 0/1/0 and disabling "Apply Pulldown" should prevent any buffering ahead, just like the old filter. I've also added some code to send an onStop event to the filters when using the DirectShow encoder and encoding finishes, as I need to do some cleaning up if encoding should work more than once in a row. Note: if you're using ffvfw (the Video for Windows wrapper around ffdshow) for encoding with the AviSynth filter turned on and it is set to buffer ahead you *will* get repeated frames at the beginning of your encode, as VfW *always* expects a compressed frame to come out when it hands an uncompressed frame to a codec - and there's nothing I can do about that. Encoding using the DirectShow "ffdshow video encoder" works fine, though.
now playing: [artist] - [track] ([album]) |
18th March 2007, 19:49 | #765 | Link |
I guess this is a bug:
If I use ffdshow (rev 1020) to playback VC-1 (HD-DVD) (using Haali's splitter, AnyDVD and ZP), I get a white picture (pure white screen) if I don't resize the picture. With resize (lanzos), I have a nice picture. But I don't want to resize (1920*1080 is already there...) BIggest Bug so far: If ffdshow is used in the video-part (does not matter if it is only postprocessing-raw-filter after the original MS VC-1 Codec or directly the ffdshow-VC-1-decoder): Instead of correct speed of 23.976 fps, it recognizes 29.999 fps. So, the video is much faster than the audio which indeed is the case...without ffdshow in the video-chain, with pure MS VC-1, it works, eventhough SPDIF is still somewhat jaggy (core duo 6400 at 3.6 ghz). Last edited by multiblitz; 19th March 2007 at 01:02. |
19th March 2007, 00:43 | #766 | Link |
Curious BetaTester
with rev1050 and before
can't get ffdshow to be used with virtualdub (us sure it work before) it falls back to opening with xvid is there something up with the vfw part? cheers
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
19th March 2007, 01:19 | #767 | Link |
It works fine here. If you have both installed it is to be expected that Xvid is used instead of ffdshow. VFW doesn't have a merit system afaik.
MPC-HC 2.2.1 |
19th March 2007, 03:14 | #769 | Link |
Curious BetaTester
i did'nt know about that, cheers
19th March 2007, 07:08 | #770 | Link | |
x264 developer
There is a little 64bit asm (though mostly we just let gcc compile the same asm for 32 and 64bit). But there are no windows-specific codepaths in libavcodec. |
19th March 2007, 09:51 | #772 | Link |
19th March 2007, 10:14 | #773 | Link | |
19th March 2007, 10:47 | #774 | Link |
Angel of Night
It's been patched. Current versions of icl just crash when you use AMD, they don't even bother to use the slow route anymore. (At one point VM9 was going to patch them to crash on Intel instead of AMD... ;p)
19th March 2007, 10:57 | #775 | Link | |
19th March 2007, 15:46 | #776 | Link | |
19th March 2007, 16:20 | #777 | Link |
I have patched the genuineintel check in the ICL libraries, so SIMD instructions should work on AMD processors too. Are you sure it crashes on AMD?
MPC-HC 2.2.1 |
