13th February 2010, 22:16 | #781 | Link |
This x264 issue is bizarre. Some folks have no issues while others are experiencing crashes and still others are successfully encoding but with a bunch of skipped frames.
WTF?!?
mozzle |
13th February 2010, 22:55 | #783 | Link |
I made some testing around the x264 r1416 and the problem is with the builds by Komisar, not the x264 itself.
I don't know which versions were included into MeGUI (generic or core2, 32 or 64 bit). The main problem is that the generic 32 and 64 bit executables are the same, probably due mislabeling. They should be the the 64 version because they don't run on my PC. (The core2 32 and 64 bit version also don't run.) I suggest grab an executable from the following topic http://doom10.org/index.php?topic=3.0 or build one yourself. I did the latter one, and left out the unused lavf and ffms input methods. |
13th February 2010, 23:28 | #784 | Link |
@horvathd:
For my tests I used 1400 & 1416 builds from http://x264.nl and still the same problem with those skipped frames. I should mention that I only mux into MKV, and skipped frames sometimes play normally after muxing the encoded video with audio using mkvmerge. |
13th February 2010, 23:42 | #786 | Link |
@thedozer:
Then probably you should report this issue in this topic (http://forum.doom9.org/showthread.php?t=108571) to the developers. |
14th February 2010, 02:45 | #788 | Link |
I did: http://forum.doom9.org/showthread.ph...19#post1373819
The one with the _ (encoded with the x264 from the dev. server) doesn't play correctly. The other one (encoded with the x264 from the stable server) plays without problems. |
14th February 2010, 08:45 | #789 | Link | |
14th February 2010, 09:42 | #790 | Link |
Useless idea generator
Vulnerability scan of Personal software inspector by Secunia.com claims that
mplayer.exe 0.x version in mencoder tool folder of MeGUI is not supported anymore. ( it means in general authors of such product either did not respond to several vulnerability notifications, or they responded or actively announced the product version is not supported anymore ) Edit: It seems all revealed vulnerabilities for MP 0.x seems patched, but it need not to be checked anymore. http://secunia.com/advisories/produc...ask=advisories OTOH, with mplayer 1.x the situation is not better as far as several vulnerabilities are unpatched Both of Highly Critical vulnerabilities of all 4 unpatched issues seems related to media streaming, so in context of MeGUI they do not look like big issue. http://secunia.com/advisories/produc...ask=advisories
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 / focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC] Last edited by Poutnik; 14th February 2010 at 10:15. |
14th February 2010, 11:59 | #791 | Link |
Honestly said I have no idea anymore regarding the x264 problem. Can someone with the problem please try to encode from the command line with the official build 1416 from x264.nl? (Use the command line from the MeGUI log - replace vfw2x264.exe with x264.exe in the command line if running on x64 and of course replace the file x264.exe with the one from x264.nl). If the problem can be reproduced this way with build 1416 and with build 1376 (from the stable server) it is gone I assume that the x264 build is the source of the problem.
14th February 2010, 12:44 | #792 | Link |
Using 32bit 1416 from x264.nl (not messing with vfw) and the same settings as previously produces a file that:
- the MPC-HC DXVA decoder doesn't crash this time but now has the same problem of skipping frames like the FFDSHOW decoder did (I've never tested 1416 before so maybe that's why there's slightly different behavior from 1400) - FFDSHOW skips frames as previously with megui's dev. server x264 1400 Using 32bit 1376 from x264.nl: - with MPC-HC DXVA decoder plays great! - with FFDSHOW plays great! Last edited by help_me!; 16th February 2010 at 10:38. |
14th February 2010, 16:59 | #794 | Link |
Hi Zathor, I have good news!
With latest MeGUI development version (0.3.3.5 with all the components updated) I don't have anymore freezing problems with unpatched 264.nl 1416 64-bit build. I guess that something in MeGUI code was updated and solved this issue. Now I'm gonna try Komisar 1416 NAL-HRD patched build in order to see if it also works with MeGUI... UPDATE: Okay, the culprit seems to be Komisar's 1416 builds: they keep freezing; don't use them. UPDATE2: Found that probably there's a bug in NAL-HRD patch; see here; Last edited by Fr4nz; 15th February 2010 at 09:55. |
14th February 2010, 18:58 | #795 | Link | |
Here's a 4 second clip from the 10 second Huffyuv source. Size is a bit big as you can understand (120MB) but Megaupload should give you good speeds. Last edited by help_me!; 15th February 2010 at 07:11. |
15th February 2010, 11:29 | #796 | Link | |
addition: i tried 32bit and 64bit outputting to mp4, mkv, and raw. all played back perfectly with both dxva and ffdshow... Last edited by quantum5uicid3; 15th February 2010 at 11:39. |
15th February 2010, 11:46 | #797 | Link | |
15th February 2010, 12:07 | #799 | Link | |
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. Assertation failed! Program: E:\dvd\avs2yuv\x264_x64.exe File: encoder/set.c, Line 679 Expression: dpb_output_delay < pow( 2, sps->vui.nal_hrd_parameters.i_dpb_output_delay_length ) E:\work\Up.2009.1080p.avs: 1920x1080, 2500000/104271 fps, 138282 frames Output error: wrote only 2676405 of 3110400 bytes Fatal Error: The encoder has encountered an unexpected error! |
