29th March 2011, 22:52 | #1981 | Link |
2002 [Update] added build number check so that profiles can only be installed using the correct build 2001 [MKV Demuxer] added status information to progress window [One-Click] fixed handling of PGS subtitles |
30th March 2011, 06:00 | #1983 | Link |
With "interlace fix" you are refering to replacing --interlaced in x264 mode with --tff or --bff? This will be implemented soon. Bitrate calculator is the problem with M2TS and non AC3 audio tracks, correct?
30th March 2011, 09:49 | #1984 | Link | |
I have figured out how to reproduce this bug, you need to increase the windows font size to 125% or higher and then you should see it. 100% 125% 150% EDIT: It seems that all video preview windows get stretched
A Man Eating Duck Last edited by AMED; 30th March 2011 at 10:09. |
2nd April 2011, 00:55 | #1985 | Link | |
NY Frame of Mind
In the meantime, I have a tff video that I want to encode smaller, so do I just add --tff to the command line with no other value ? And, adding nothing will encode as progressive and is there any advantage to doing that, quality wise ?
"Talk to me Goose" |
3rd April 2011, 08:08 | #1986 | Link |
The Black Reaper
Feature request: Support for .wav in MKV Muxer and Adaptive Muxer.
Would appreciate this feature very much as it makes my job of ripping my DVD to .mkv while copying the source audio which is .wav a lot easier compared to going to mkvmerge GUI to mux it manually. Anyway I see that changes have been made for the x264 interlaced encoding command line on SF, thanks Zathor! |
3rd April 2011, 18:59 | #1987 | Link |
[Error] Log
-[Information] Versions --[Information] [02/04/2011 17.19.23] MeGUI Version : 2002 (svn) --[Information] [02/04/2011 17.19.23] OS : Windows Server 2008 x86 SP2 (6.0.131072.6002) --[Information] [02/04/2011 17.19.23] Latest .Net Framework installed : 2.0 SP2 (2.0.50727.4016) --[Information] [02/04/2011 17.19.23] Avisynth Version : 2.5.8.5 (21/12/2008 21.46.54) -[Information] Update detection --[Information] [02/04/2011 17.19.23] Connecting to server: http://megui.xvidvideo.ru/auto/ --[Information] [02/04/2011 17.19.24] All files are up to date -[Information] Log for job1 (video, La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.avs -> ) --[Information] [02/04/2011 17.25.52] Started handling job --[Information] [02/04/2011 17.25.52] Preprocessing --[Information] [02/04/2011 17.25.52] Avisynth input script ---[NoImage] # Set DAR in encoder to 47 : 20. The following line is for automatic signalling ---[NoImage] global MeGUI_darx = 47 ---[NoImage] global MeGUI_dary = 20 ---[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_plugin\ColorMatrix.dll") ---[NoImage] LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\VSFilter.dll") ---[NoImage] DirectShowSource("D:\Torrent-COMPLETI\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.mkv", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001) ---[NoImage] #deinterlace ---[NoImage] #crop ---[NoImage] Spline16Resize(672,288) # Spline16 (Neutral) ---[NoImage] #denoise --[Information] [02/04/2011 17.25.52] Job commandline: "C:\Program Files\MeGUI\tools\xvid_encraw\xvid_encraw.exe" -i "D:\Xvid\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.avs" -pass1 "D:\Xvid\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.stats" -bitrate 1678 -ostrength 14 -oimprove 14 -odegrade 14 -turbo -max_key_interval 250 -nopacked -qmatrix "C:\Users\root\Desktop\Matrix\HVS Best Picture.cqm" -imin 1 -imax 3 -pmin 1 -pmax 3 -noclosed_gop -max_bframes 1 -bvhq -bquant_ratio 91 -bmin 1 -bmax 3 -par 141:140 --[Information] [02/04/2011 17.25.52] Encoding started --[Information] [02/04/2011 18.18.23] Standard output stream ---[NoImage] xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 ---[NoImage] Tot: enctime(ms) =3147767.00, length(bytes) = 2133807231 ---[NoImage] Avg: enctime(ms) = 21.76, fps = 45.95, length(bytes) = 14751 ---[NoImage] I frames: 1572 frames, size = 44035/ 69224479, quants = 2 / 2.00 / 2 ---[NoImage] P frames: 71701 frames, size = 18460/ 1323656400, quants = 2 / 2.00 / 2 ---[NoImage] B frames: 71118 frames, size = 10418/ 740924512, quants = 2 / 2.00 / 2 ---[NoImage] N frames: 256 frames, size = 7/ 1840 --[Information] [02/04/2011 18.18.23] Standard error stream ---[NoImage] Trying to retrieve width and height from input header ---[NoImage] xvid [info]: Avisynth detected ---[NoImage] xvid [info]: Input colorspace is YV12 ---[NoImage] xvid [info]: Input is 672 x 288, 23.976fps (24000/1001), starting from frame 0 ---[NoImage] xvid [info]: Number of frames to encode: 144647, Bitrate = 1678kbps ---[NoImage] xvid [info]: xvidcore build version: xvid-1.2.2 ---[NoImage] xvid [info]: Bitstream version: 1.2.2 ---[NoImage] xvid [info]: Detected CPU flags: ASM MMX MMXEXT SSE SSE2 TSC ---[NoImage] xvid [info]: Detected cpus = 8, threads requested = 7, threads in use = 7 ---[NoImage] xvid [info]: Threaded input reading active --[Information] [02/04/2011 18.18.23] Postprocessing ---[Information] Deleting intermediate files --[Information] [02/04/2011 18.18.23] Job completed -[Error] Log for job3 (video, La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.avs -> La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.avi) --[Information] [02/04/2011 18.18.23] Started handling job --[Information] [02/04/2011 18.18.23] Preprocessing --[Information] [02/04/2011 18.18.23] Avisynth input script ---[NoImage] # Set DAR in encoder to 47 : 20. The following line is for automatic signalling ---[NoImage] global MeGUI_darx = 47 ---[NoImage] global MeGUI_dary = 20 ---[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_plugin\ColorMatrix.dll") ---[NoImage] LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\VSFilter.dll") ---[NoImage] DirectShowSource("D:\Torrent-COMPLETI\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.mkv", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001) ---[NoImage] #deinterlace ---[NoImage] #crop ---[NoImage] Spline16Resize(672,288) # Spline16 (Neutral) ---[NoImage] #denoise --[Information] [02/04/2011 18.18.23] Job commandline: "C:\Program Files\MeGUI\tools\xvid_encraw\xvid_encraw.exe" -i "D:\Xvid\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.avs" -pass2 "D:\Xvid\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.stats" -bitrate 1678 -ostrength 14 -oimprove 14 -odegrade 14 -turbo -max_key_interval 250 -nopacked -qmatrix "C:\Users\root\Desktop\Matrix\HVS Best Picture.cqm" -imin 1 -imax 3 -pmin 1 -pmax 3 -noclosed_gop -max_bframes 1 -bvhq -bquant_ratio 91 -bmin 1 -bmax 3 -par 141:140 -avi "D:\Xvid\La.Banda.Dei.Babbi.Natale.2010.ITA.DTS.AC3.720p.Bluray.x264-TSR.avi" --[Information] [02/04/2011 18.18.23] Encoding started --[Error] [02/04/2011 18.18.51] Process exits with error code: -1073741819 --[Information] [02/04/2011 18.18.51] Standard output stream --[Information] [02/04/2011 18.18.51] Standard error stream --[Information] [02/04/2011 18.18.51] Job completed This is the first time this has happened |
3rd April 2011, 20:07 | #1988 | Link |
D:\Torrent-COMPLETI\La.Banda.Dei.Babbi.Natale.... And please stop crossposting. http://forum.doom9.org/showthread.ph...83#post1489383 |
5th April 2011, 12:45 | #1989 | Link |
The Black Reaper
Can any of the devs update the VSFilter with the updated ones found here as it fixes some subtitle issues.
5th April 2011, 17:23 | #1990 | Link |
Can you please post a direct link to your mentioned build? I cannot find a recent one (seems to be from 2008/2009). Maybe you can try other filters from here as well: https://sourceforge.net/projects/mpc...s%20-%20Win32/
5th April 2011, 17:43 | #1991 | Link |
The Black Reaper
Apologies for the link.
http://www.free-codecs.com/directvobsub_download.htm Click "Download [ DirectVobSub 2.39 [2009-06-24] without installer - for Windows 2k/2k3/XP/Vista ]" Couldn't find a direct link but this link should work. The build is 2.39.5.2. The VSFilter in the SF link is 1.5.*.* and has been reported by some of the users on SF that it doesn't work that well for them Details and samples are in the SF bug tracker link in my previous post. |
5th April 2011, 18:37 | #1993 | Link | |
The Black Reaper
I shall try to do a test with the sample files provided on SF with the newer VSFilter provided in MPC and report back. Edit: Did a test with the sample files provided on SF using the current VSFilter in MeGUI which uses the latest VSFilter from MPC. Hardsubbing works fine for me. I guess it is okay to leave the more recent build of VSFilter in MeGUI. Last edited by Lighto; 5th April 2011 at 19:45. |
6th April 2011, 13:57 | #1994 | Link | |
6th April 2011, 20:32 | #1995 | Link |
Mr. Sandman
please read the forum rules expecially the number 6.
if your content isnt an illegal download please make it clear to the moderators coz we cant help with illegal stuff.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th April 2011 at 20:34. |
10th April 2011, 20:22 | #1998 | Link |
Before posting some stupid feature requests I'd like to ask some questions to see which of them are reasonable and which not.
1) In the scrip creator: Why is resizing limited to 720 in the width? Shouldn't it allow for full HD resolution? 2) When processing anamorphic cinema-scope input (e.g. 720x576 video, with 70 pixel top and bottom border, identified as ITU 16:9 PAL): After auto-cropping and checking the anamorphic encoding box, the resulting video turned out to have 720x304 resolution. Why isn't it possible to get the original height (minus cropping), thus keeping all the original lines but only stretching them in the width at playback (since that is what gets done anyway). I was kinda expecting a resulting video with 436 height and whatever width matching to it. Would this be possible? Maybe with a simple check box? Or are there good reasons for not allowing this? 3) Would it be possible to add options for keeping the original video and audio data but still allowing for trimming? Or does that require external tools? 4) Currently the whole vob file gets analyzed and with this settings the encoding gets started. Would it be possible to first trim the video in the avs cutter and then analyze it? Thus getting the best default settings for the intended video part? I'm asking this because recently I had two music videos, both anamorphic, interlaced (hard telecined) and 720x480 NTSC data at 29,79. The first resulted in a 29,79 fps and the other in a 23,79 fps video. The reason is probably that in both vob files were more than just those clips. In the one however all video was interlaced and at 29,79 and in the other the second part of that file was progressive, thus the analyzer said 'partly film', whereas the the interesting part of it would have been completely interlaced. 5) I just toyed with VirtualDubMod and found the filter preview window that is showing the original video as well quite nice. Would something similar be possible? 5b) Adding filters by clicking (and previewing the result) would also be nice. But I guess I'm dreaming here. ^_- 6) Also I still have trouble understanding the result of cropping on the resulting video size / aspect ratio: I have a video (720x480 anamorphic) where I crop 4 pixels left and two right. I would have expected the resulting video to be just about 6-8 pixel smaller in width than the original, but the result turned out to be wider than that (about the size of the height of the window title bar more in width). Still being a noob I was expecting that if I start playing the original file and the encoded file in 1:1 with MPC that if I move the windows to match the pixels should about exactly map 1:1 as well, thus keeping the aspect ratio perfectly fine without any distortion. Unfortunately that isn't the case, ans so far I could not get the expected result even when setting the DAR in the script manually. Is this a bug? Or am I mistaken and the expected result can not be achieved? If not, what is the best that can be achieved? BTW: where can I read about the math involved that MeGUI/AviSynth needs to do to create the script. I like to understand what is going on here. That's it. I'm sorry that it got this long. Last edited by Mizra; 10th April 2011 at 20:24. |
10th April 2011, 20:57 | #1999 | Link |
1) Resizing is limited so you can't resize to a higher resolution than the source. Except in some cases it wouldn't make sense to do so. In short it's there to prevent inexperienced users from doing something stupid.
2) What it should do if you checked the anamorphic encoding box and didn't touch anything else is resize to 720*432 and set the appropriate flags. It's then the players responsibility to stretch the video correctly. I haven't used the feature in a while though. If you didn't check the box 720*304 would be the expected resolution. Are you sure you checked the box. Also how did you determine the resolution. Maybe your player scales the video down instead of up when it corrects the aspect ratio. 3) Not with Avisynth and generally you can't trim a file on an arbitrary location without reencoding at least parts of it. I think Avidemux supports that. 5a) I think AVSPMod supports this feature if you need it now. You can find it on the Avisynth forum. I haven't tried it, but maybe you can just edit the script to stack the two videos. 5b) You can comment out commands with a # and hit F5 to refresh the preview. 6) By default the anamorphic encoding is followed by a resize to mod16. This would also explain why the videos don't look the same. You can select other options in the dropdown. Avisynth documentation can be found at avisynth.org, which currently doesn't work for me If you want to use some of the more complicated stuff you find on the Avisynth forum here there is usually plenty of documentation in the corresponding thread. Usually there is also a manual included when you download new filters. |
10th April 2011, 22:12 | #2000 | Link | |||||||
Another idea would be to add a horizontal slider that separates the window in a left and right part, one showing the original video and the other the resulting one. I saw something like that somewhere and it was the most convenient idea I've seen to handle those type of preview problems. Quote:
(BTW: resize in the sense of cropping or scaling?) But I was believing that providing DAR in the script could be used to correct the effect completely (by telling the player how it should be). Am I mistaken here? Quote:
