27th April 2010, 11:29 | #102 | Link | |
I have them on flickr now but for some reason I couldn't make the appear here(I used the Insert photo button with no visible result), here is an example: Thank you in advance. Best regards. Last edited by the_provider; 27th April 2010 at 11:35. |
27th April 2010, 15:39 | #103 | Link |
Practising Schemer
Well definitely try dehalo_alpha.
Maybe Code:
FFT3dGPU(sigma=3.0, plane=4, bt=0,sharpen=1, bw=32, bh=32) DeHalo_alpha() LSFmod(defaults="slow") Or even Code:
MCTemporalDenoise(edgeclean=true, ecrad=4, stabilize=true, maxr=2) DeHalo_alpha() LSFmod(defaults="slow") |
27th April 2010, 15:45 | #104 | Link |
The first image appears to be an optical halo. I've seen this on a lot of older flying spot scanner transfers, the white areas "glow".
I don't think dehalo filters will work for that. The second image looks like it's been camcorded from a TV set? It has optical glowing AND an electronic halo (smaller darker line). The halo remover would likely get rid of the thick black line, but not the white light spilling over the boundary. The third one is entirely electronic, but it looks like all of the detail in this image is confined to the middle frequencies. Removing the halos is likely to be of limited success. |
27th April 2010, 22:45 | #105 | Link |
First I would like to thank everybody who take the time to reply.
I would like to do that, too but I keep getting the same error: Error reading source frame 0: Avisynth read error: CAVIStreamSynth: System exception - Acces violation... I use the following script: LoadPlugin("C:\Software\GORDIA~1\DGMPGDec\DGDecode.dll") LoadPlugin("C:\Downloads\BitComet\VirtualDub-1.9.9\plugins\Repair.dll") LoadPlugin("C:\Downloads\BitComet\VirtualDub-1.9.9\plugins\RemoveGrain.dll") LoadPlugin("C:\Downloads\BitComet\VirtualDub-1.9.9\plugins\mt_masktools-25.dll") Import("C:\Documents and Settings\Catalin\My Documents\Video_related\BlindDeHalo3_mt2.avs") LoadPlugin("C:\Software\GORDIA~1\AviSynthPlugins\UnDot.dll") # SOURCE mpeg2source("C:\BitComet_Download\BurebistaDVD\VIDEO_TS\Burebista1.d2v") #Version() ConvertToYV12() BlindDeHalo3() # CROPPING crop(2,20,716,536) # RESIZING LanczosResize(720,368) # DENOISING: choose one combination (or none) Undot() where BlindDeHalo3_mt2.avs(I have a core 2 duo processor) contains: function BlindDeHalo3( clip clp, float "rx", float "ry", int "strength", \ float "lodamp", float "hidamp", float "sharpness", float "tweaker", \ int "PPmode", int "PPlimit", bool "interlaced") { rx = default( rx, 3.0 ) ry = default( ry, 3.0 ) strength = default( strength, 125 ) lodamp = default( lodamp, 0.0 ) hidamp = default( hidamp, 0.0 ) sharpness = default( sharpness, 0.0 ) tweaker = default( tweaker, 0.0 ) PPmode = default( PPmode, 0 ) PPlimit = default( PPlimit, (abs(PPmode)==3) ? 4 : 0 ) interlaced = default( interlaced, false ) sharpness = (sharpness>1.58) ? 1.58 : sharpness tweaker = (tweaker > 1.00) ? 1.00 : tweaker strength = float(strength)*(1.0+sharpness*0.25) RR = string((rx+ry)/2.0) ST = string(float(strength)/100.0) LD = string(lodamp) HD = string(pow(hidamp,2)) TWK0 = "x y - 12 "+ST+" / "+RR+" / /" TWK = "x y - 12 "+ST+" / "+RR+" / / abs" TWK_HLIGHT = "x y - abs 1 < 128 "+TWK+" 128 "+TWK+" - "+TWK+" 128 / * + "+TWK0+" "+TWK+" "+LD+" + / * " \ + "128 "+TWK+" - 20 / 2 ^ 128 "+TWK+" - 20 / 2 ^ "+HD+" + / * 128 + ?" i = (interlaced==false) ? clp : clp.separatefields() oxi = i.width oyi = i.height sm = i.bicubicresize(m4(oxi/rx),m4(oyi/ry)) mm = mt_lutxy(sm.mt_expand(),sm.mt_inpand(),"x y - 4 *").mt_expand().mt_deflate().blur(1.58).mt_inflate().bicubicresize(oxi,oyi,1.0,.0).mt_inflate() sm = sm.bicubicresize(oxi,oyi,1.0,.0) smd = mt_lutxy(i.sharpen(tweaker),sm,TWK_HLIGHT) smd = (sharpness==0.0) ? smd : smd.blur(sharpness) clean = mt_lutxy(i,smd,yexpr="x y 128 - -").mergechroma(i) clean = mt_merge(i,clean,mm) LL = string(PPlimit) LIM = "x "+LL+" + y < x "+LL+" + x "+LL+" - y > x "+LL+" - y ? ?" base = (PPmode<0) ? i : clean small = base .bicubicresize(m4(oxi/sqrt(rx*1.5)),m4(oyi/sqrt(ry*1.5))) ex1 = small.mt_expand().blur(.5) in1 = small.mt_inpand().blur(.5) hull = mt_logic( mt_lutxy( ex1.mt_expand().RemoveGrain(12,-1), ex1, "x y - 1 1 / * 1.0 ^ 1 - 5 *" ) \ ,mt_lutxy( in1, in1.mt_inpand().RemoveGrain(12,-1), "x y - 1 1 / * 1.0 ^ 1 - 5 *" ) \ ,"max", U=-128, V=-128) \ .bicubicresize(oxi,oyi,1.0,.0) postclean = (abs(PPmode)== 1) ? mt_merge(base,small.bicubicresize(oxi,oyi,1.0,.0),hull,Y=3,U=2,V=2) \ : (abs(PPmode)== 2) ? mt_merge(base,base.RemoveGrain(19,-1),hull,Y=3,U=2,V=2) \ : (abs(PPmode)== 3) ? mt_merge(base,base.RemoveGrain(4,-1),hull,Y=3,U=2,V=2) \ : clean postclean = (PPlimit==0) ? postclean \ : mt_lutxy(base,postclean,yexpr=LIM,U=2,V=2) (PPmode==0) ? clean : postclean interlaced ? weave() : last return( last ) } #--------------------------------------------------------- function m4(float x) {return(x<16?16:int(round(x/4.0))*4)} OR DeHalo_alpha, of course with the proper change in the Import command in my script: function DeHalo_alpha(clip clp, float "rx", float "ry", float "darkstr", float "brightstr", float "lowsens", float "highsens", float "ss") { rx = default( rx, 2.0 ) ry = default( ry, 2.0 ) darkstr = default( darkstr, 1.0 ) brightstr = default( brightstr, 1.0 ) lowsens = default( lowsens, 50 ) highsens = default( highsens, 50 ) ss = default( ss, 1.5 ) LOS = string(lowsens) HIS = string(highsens/100.0) DRK = string(darkstr) BRT = string(brightstr) ox = clp.width() oy = clp.height() uv = 1 uv2 = (uv==3) ? 3 : 2 halos = clp.bicubicresize(m4(ox/rx),m4(oy/ry)).bicubicresize(ox,oy,1,0) are = mt_lutxy(clp.mt_expand(U=uv,V=uv),clp.mt_inpand(U=uv,V=uv),"x y -","x y -","x y -",U=uv,V=uv) ugly = mt_lutxy(halos.mt_expand(U=uv,V=uv),halos.mt_inpand(U=uv,V=uv),"x y -","x y -","x y -",U=uv,V=uv) so = mt_lutxy( ugly, are, "y x - y 0.001 + / 255 * "+LOS+" - y 256 + 512 / "+HIS+" + *" ) lets = mt_merge(halos,clp,so,U=uv,V=uv) remove = (ss==1.0) ? clp.repair(lets,1,0) \ : clp.lanczosresize(m4(ox*ss),m4(oy*ss)) \ .mt_logic(lets.mt_expand(U=uv,V=uv).bicubicresize(m4(ox*ss),m4(oy*ss)),"min",U=uv2,V=uv2) \ .mt_logic(lets.mt_inpand(U=uv,V=uv).bicubicresize(m4(ox*ss),m4(oy*ss)),"max",U=uv2,V=uv2) \ .lanczosresize(ox,oy) them = mt_lutxy(clp,remove,"x y < x x y - "+DRK+" * - x x y - "+BRT+" * - ?",U=2,V=2) return( them ) } function m4(float x) {return(x<16?16:int(round(x/4.0)*4))} Any other way of using DeHalo? I am using Avisynth 2.6 Thank you in advance. |
21st November 2013, 19:08 | #112 | Link |
I'm trying to use the abcxyz function, I already have the masktools2 2.0a48 installed, but it still give me the error message "there is no function named yv12lutxy", what else am I missing?
EDIT: I found out what's the problem. I was confused by the wiki page, where it said there's an updated version with masktools2, but the link was linking to the masktools version. http://avisynth.nl/index.php/Abcxyz Last edited by lansing; 21st November 2013 at 20:44. |
22nd November 2013, 04:40 | #113 | Link | |
It's fixed now. |
