Old 17th December 2005, 23:53   #921  |  Link
Doom9
clueless n00b
@: let me recapitulate your videos and screenshots:
line contains "Pos: 0.8s 10f (0%) 0.00fps Trem: 0min 0mb A-V:0.000[0:0]
the IOException happens in the line "line = sr.ReadLine();" with counter being set to 9.
And MeGui crashes at the line "su.FPS = this.getFPS(line);
Is that correct? What is the content of line when megui crashes and can you step into the getFPS method to find the exact location, and the important variables in that method?
The warnings are just from .Net 2.0.. just shows some of the differences to the 1.1 runtime but they are nothing to be worried about.
Also, can you try commenting out all the code inside the "if (line != null)" and see if you can get past the 10th frame?
also try wrapping all the code inside "(while !proc.HasExited)"
in a try {}
and add the following catch:
catch (Exception e)
log.Append("exception in mencoderEncoding: " + e.Message);
And just to make sure nothing goes haywire on your system, can you try encoding via x264.exe for a change just to see if that works out properly? or try audio encoding
Doom9 is offline
Old 18th December 2005, 12:13   #922  |  Link
klicker4546
Yes, you're right. I stepped in to the method again and made another screen capture vid, which shows the value of the variable before it crashes. After the program exits. I can't see it's value. Maybe I should set here a breakpoint?
Ok, so I take it that I can just ignore those messages then.
I've tried to go along with your suggested debugging instructions. But it seems way to complex to me. I've just started programming (VB .Net) and C# looks way strange to me.
I had an idea though. I'm running VM Workstation. I could set up a working environment, where someone could go ahead with the debugging on my computer as it seems that I am not able to go ahead.
It's the point that I'm not aware where for example the method "(while !proc.HasExited)" starts and ends. Where to insert the try{} and the catch.
in a try {}
catch (Exception e)
klicker4546 is offline
Old 18th December 2005, 12:20   #923  |  Link
Doom9
clueless n00b
alright, I'm attaching a zip file containing two source files.. just plug them into your source directory, compile and run and see what you get. I suspect there will still be problems so try debugging again. Once counter is equal to 9, step through everything pressing F11.. that will jump into every other method that is being called as well. Then please give me the exact line you were on before you pressed F11 and an exception was catched. And if the program still crashes, the same for the crash please (which line are you on before pressing F11 caused the crash).
Doom9 is offline
Old 18th December 2005, 15:59   #924  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
uhm. well, i'll add the winamp AAC+ encoder support (thru besweet+bsn) and will update the nero encoder support.
Sharktooth is offline
Old 18th December 2005, 17:44   #925  |  Link
klicker4546
Ok, thanks again for your help. This this will make it a little easier for me.
I'll let you know what happened.
Old 18th December 2005, 17:55   #926  |  Link
molitar
Question on mencoder I have a AMD 64bit processor but running 32bit windows should I install the xp or the 64bit version? In other words is it based on the operating system or the processor?
molitar is offline
Old 18th December 2005, 17:57   #927  |  Link
Doom9
clueless n00b
@molitar: mplayer2005.11.23.Athlon-64.7z = a 32 bit build for the athlon64.. basically it's an sse3 build.. but it really doesn't seem to matter which build you take.. you can make your own speed tests if you like to verify that.
Doom9 is offline
Old 18th December 2005, 19:11   #928  |  Link
molitar
Ok I got all the components but one suggestion it took me a while to figure out where the full megui was. Was looking for a link for it throughout the thread.. I would suggest where you have the link to download the x264 CLI that you add (includes megui).
molitar is offline
Old 18th December 2005, 19:27   #929  |  Link
Doom9
clueless n00b
the download link is in the first post. I'll add a bold "click here to download" on line4 of that post right after the program description and before the links to all the additional components you will need. I hope that'll be satisfactory. What sharktooth and bobor distribute is not under my control, though at least Sharktooth is going to include the full version in the future.
Doom9 is offline
Old 18th December 2005, 19:44   #930  |  Link
molitar
I crashed using megui. Crash log below: I also noticed that the file requires haali media splitter to open it but when I go to queue it I have 4 haali media splitter tray icons don't know if that could be a part of it or not.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at MeGUI.AVIReader.AVIFileRelease(Int32 pfile)
at MeGUI.AVIReader.Dispose(Boolean disposing)
at MeGUI.AVIReader.Close()
at MeGUI.VideoPlayer.OnClosing(CancelEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
molitar is offline
Old 18th December 2005, 19:51   #931  |  Link
klicker4546
Ok, now. I build MeGui with your changes applied. The application did not crash anymore.
And I did a little more of debugging. The line before it throws the exception is
su.NbFramesDone = getFrameNumber(line);
The counter variable had a value of 10. I stepped once more with F11 and it threw an exception in line
public int NbFramesDone
			get {return nbFramesDone;}
		--->	set {nbFramesDone = value;}
Error message: - AudioPositionTicks 'this.AudioPositionTicks' threw an exception of type 'System.NullReferenceException' long {System.NullReferenceException}
- base {"Object reference not set to an instance of an object."} System.SystemException {System.NullReferenceException}
- base {"Object reference not set to an instance of an object."} System.Exception {System.NullReferenceException}
+ Data {System.Collections.ListDictionaryInternal} System.Collections.IDictionary {System.Collections.ListDictionaryInternal}
HelpLink null string
+ InnerException null System.Exception
Message "Object reference not set to an instance of an object." string
Source "MeGUI" string
StackTrace " at MeGUI.StatusUpdate.get_AudioPositionTicks() in D:\\megui_src\\StatusUpdate.cs:line 206" string
+ TargetSite {Int64 get_AudioPositionTicks()} System.Reflection.MethodBase {System.Reflection.RuntimeMethodInfo}
- Static members
- Non-Public members
_COMPlusExceptionCode -532459699 int
Hope it helps to trace the problem now!
Old 18th December 2005, 21:04   #932  |  Link
Doom9
clueless n00b
when you step into the method "getFrameNumber(line)", what does happen? If you press F11 when you're on line
You'll go to line 494 where the method getFrameNumber starts.. what is the content of the variable
string frameNumber
inside that method? It should be 10, should it not?
And what's the value of nbFramesDone and value in
Perhaps you could just give me a link to the mencoder build you're using? Man I wished I would sit in front of that pc.. it's probably the most frustrating thing for any programmer.. while it doesn't always solve things, being able to get your hands on a debugger that shows the actual problem.. you just can't beat the bugfixing power of that.
Your exception location makes no sense though, you the only way the ProgressWindow accesses the variable AudioPositionTicks is when you have an audio status update. Are you really 101% sure you are looking at the right place? On line 222 in VideoEncoder.cs I declare StatusUpdate. On line 227 in the same file I set su.JobType to 0, meaning it's a video job, and that's not changed through event propagation or anywhere in the class itself.
So can you add additional breakpoints in StatusUpdate.cs on line 18 (
double div = (double) AudioPositionTicks / (double)AudioLengthTicks;
) and line 373 in ProgressWindow.cs (
if (su.JobType == 1) // audio status update
). If those are triggered, step through them until you get an exception. Note the line number of the exception, do the whole thing again, stop stepping one line before the exception and give me a list of the locals please (only local variables of ProgressWindow and StatusUpdate please).
Basically the exception you're reporting here makes no sense.. it looks like you're encoding video but the status update is for an audio job.. needless to say that this will never work.
Another perhaps easier attempt: put a breakpoint on line 272 in VideoEncoder.cs. Dump the contents of the variable su at that point.. that's the StatusUpdate object that gets propagated to the MeGUI and ProgressWindow class, and that's where the exception comes from ultimately. And do you ever get into the catch in VideoEncoder.cs on lines 285 and below?
@molitar: loaded assemblies are usually not info anybody needs, however, all steps taken from the loading of MeGUI until th exception.. that's information you should never leave out, even if it turns out not to be useful.. it's covering all the basics that make a good bug report.
Doom9 is offline
Old 18th December 2005, 22:01   #933  |  Link
stax76
stax76's Avatar
I'm not a debugging expert but for me the only thing that really works is to configure VS to break immediatelly even if the exception is handled, appears to have many advantages and on top of that some really weird things happened here until I configured VS like that. Of course sometimes a exception can be expected and this is not wanted but on such methods the DebuggerNonUserCodeAttribute can be applied so VS won't break.
On the Debug menu, click Exceptions.
In the Exceptions dialog box, select Thrown for an entire category of exceptions, for example, Common Language Runtime Exceptions.
http://msdn2.microsoft.com/en-us/library/d14azbfh.aspx
stax76 is offline
Old 19th December 2005, 03:24   #934  |  Link
klicker4546
Oh man, do we ever get it resolved?
And I am absolutely sure that it was that line where the exception occurs. So far can see it! I'm not too familiar with debugging and just a beginner with programming in general.
Ok, I will try what you'd wanted me to try. I'll attach two vid-caps of the last debugging session to my next message.
Old 19th December 2005, 12:45   #935  |  Link
Doom9
clueless n00b
if there's a way for me to remote access your desktop then I think it would be rather easy. However, if you just gave me the link to your mencoder build, I could compile the latest code on my own to see if anything as funky happens. I'm almost certain su.JobType is equal to 1 on your box, no idea why it happens, but it would explain the exception you're getting.
Doom9 is offline
Old 19th December 2005, 13:49   #936  |  Link
klicker4546
Ok, I'll download vnc and setup remote access. It would really ease up the whole process. :-) Let me see what I can do. Ok, here's the link to the mencoder build I use.
Mencoder
Old 19th December 2005, 14:40   #937  |  Link
Chris Benoit
IS there a way to import a bunch of avs files altoghether?Instead of opening the avs one by one and adding to the queue wouldn't it be better to open a bunch of them at the same time,so they will be queudd altogether?
Chris Benoit is offline
Old 19th December 2005, 14:46   #938  |  Link
Doom9
clueless n00b
well,it's a pretty big presumtion to assume every source would be encoded exactly the same way..
Doom9 is offline
Old 19th December 2005, 15:12   #939  |  Link
klicker4546
Hello doom9,
I have set up ultravnc. If you want you can do the debugging on my desktop.
I will send you the rc.key file for a secured connection if you like.
Do you have any instant messenger like ICQ or so?
Please let me know if you wanna go ahead with it.
Edit: I did a litlle more debugging. I am able to get to line 285 and further. So that an exception was catched. I attach a screenshot and a copy of the error message.
File Type: txt exception.txt (577 Bytes, 84 views)
Old 19th December 2005, 15:13   #940  |  Link
Chris Benoit
Well what harm could it be for that option to exist?If someone doesn't need it he's not obligated to use it.
I on the other hand only need avc encoding for psp,and for every file i need to encode i use the psp profile,so it would save me a considerable amount of many if every time i could just open all avs files at once.
So what do you say?
