1st January 2010, 05:11 | #402 | Link | |
The beta crashes, the alpha says it cannot render (like it misses the codec). Alpha now doesn't work anymore even on my Core 2 Duo, as if the beta version is now preventing a rollback to work (to switch I simply register the other filter, having alpha and beta in two separate folders). |
1st January 2010, 12:10 | #403 | Link |
Could someone help me with the debug?
download the following file, unzip it and run the two .bat files. Feedback the results to me. http://di-avc.com/test.7z You must use the single-care cpu because the decoder crashes on it.
The Next Generation Internet Video Codec project.[/url]. |
1st January 2010, 13:44 | #404 | Link |
test.bat
first decoder inited! first decoder inited! 1 decoder inited! 2 decoder inited! 3 decoder inited! 4 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 4234111 counters used by decoder and 12102 counters used by others. Decoding speed: 83 fps Code:
first decoder inited! 1 decoder inited! 2 decoder inited! 3 decoder inited! 4 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 4431532 counters used by decoder and 15220 counters used by others. Decoding speed: 79 fps I can test on Athlon64 x2/Sempron/Atom/Core Duo if you need...but not before tonight. |
1st January 2010, 16:55 | #405 | Link |
On a single-core A64:
test.bat Code:
first decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 4107778 counters used by decoder and 11540 counters used by others. Decoding speed: 86 fps Code:
first decoder inited! 1 decoder inited! 2 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 4198624 counters used by decoder and 11584 counters used by others. Decoding speed: 84 fps Last edited by ForceX; 1st January 2010 at 17:05. |
1st January 2010, 17:04 | #406 | Link | |
This is a mbaff bitstream and I use it as a conformance verification. I compared the result gotten by my decoder and jm, it is exactly equal. How you get "that stream is not decoded properly by DiAVC"?
1st January 2010, 17:07 | #407 | Link |
4:2:0 hater
sgltrd.exe basketball720x576.264 first decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! AppName: sgltrd.exe AppVer: 0.0.0.0 ModName: sgltrd.exe ModVer: 0.0.0.0 Offset: 000aa4a7 Code:
mttrd.exe basketball720x576.264 first decoder inited! 1 decoder inited! 2 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! AppName: mttrd.exe AppVer: 0.0.0.0 ModName: mttrd.exe ModVer: 0.0.0.0 Offset: 000aa4a7 With a Pentium M 730. |
1st January 2010, 17:13 | #408 | Link |
I mean I'm getting this kind of output:
http://i45.tinypic.com/2db8jyc.png Also the video freezes and stutters. I'm using Elecard demuxer. It may be the demuxer's incompatibility but other AVC decoders give proper output with Elecard. |
1st January 2010, 17:16 | #409 | Link | |
1st January 2010, 17:17 | #410 | Link |
Sempron 1800mhz (1 Core):
first decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 4470703 counters used by decoder and 13453 counters used by others. Decoding speed: 79 fps Code:
first decoder inited! 1 decoder inited! 2 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 4661021 counters used by decoder and 13264 counters used by others. Decoding speed: 76 fps Code:
first decoder inited! 1 decoder inited! 2 decoder inited! 3 decoder inited! 4 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 2657842 counters used by decoder and 11391 counters used by others. Decoding speed: 58 fps Code:
first decoder inited! 1 decoder inited! 2 decoder inited! 3 decoder inited! 4 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 2482841 counters used by decoder and 10982 counters used by others. Decoding speed: 62 fps Code:
first decoder inited! 1 decoder inited! 2 decoder inited! 3 decoder inited! 4 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 1971485641 counters used by decoder and 8748719 counters used by others. Decoding speed: 90 fps Code:
first decoder inited! 1 decoder inited! 2 decoder inited! 3 decoder inited! 4 decoder inited! decoder iit post 1! decoder iit post 2! decoder iit post 2! decoder iit post 4! decoder iit post 5! 99 frames decoded totally. 2021019457 counters used by decoder and 9506171 counters used by others. Decoding speed: 88 fps |
1st January 2010, 17:46 | #411 | Link | |
1st January 2010, 18:22 | #412 | Link |
To STaRGaZeR:
Another test for more crash information. http://di-avc.com/test2.7z Only pentiumM and athlon64 cpu are needed because the decoder only crashes the two cpu.
1st January 2010, 20:07 | #413 | Link |
Athlon 64, I get this:
J:\test2>snglthrd.exe paris_cif_24.264 isSSSE3 0 1 decoder inited! nalu type 7 nalu type 8 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 1 curSLCtype 2 I 1 poc 0 slctype 2 mbx 0 mby 0 mbtype 3 info 0 mb_start 0 mbmode 0 AfterMBtype arth range 14c value 521ec0 btlft 14 |
1st January 2010, 20:15 | #414 | Link |
4:2:0 hater
I get exactly the same. Crash:
AppName: snglthrd.exe AppVer: 0.0.0.0 ModName: snglthrd.exe ModVer: 0.0.0.0 Offset: 000aa76a Last edited by STaRGaZeR; 1st January 2010 at 21:25. |
1st January 2010, 21:15 | #416 | Link |
Thank you both. Looks there exist some incompatibility of SSE2 code with the two cpu.
Have a more test to sure it. http://di-avc.com/test3.7z
1st January 2010, 21:29 | #417 | Link |
4:2:0 hater
snglthrd.exe paris_cif_24.264 isSSSE3 0 1 decoder inited! nalu type 7 nalu type 8 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 5 nalu type 1 curSLCtype 2 I 1 poc 0 slctype 2 mbx 0 mby 0 mbtype 3 info 0 mb_start 0 mbmode 0 AfterMBtype arth range 14c value 521ec0 btlft 14 iprd mode end! cbp 47 qp 26 idx 0 isSig 1 dt tok c AppName: snglthrd.exe AppVer: 0.0.0.0 ModName: snglthrd.exe ModVer: 0.0.0.0 Offset: 000aa76a |
1st January 2010, 22:26 | #419 | Link |
A new bata version is available.
changes: fix a bug (a fault use of a sse3 code in sse2 functions). Great thanks to ForceX, STaRGaZeR, Fadeout and the_corona for their help.
The Next Generation Internet Video Codec project.[/url]. Last edited by schweinsz; 1st January 2010 at 22:31. |
1st January 2010, 22:36 | #420 | Link |
Software Developer
With the Beta release I have a strange problem: The video is jumping back and forth like crazy
I went back to the Alpha (2009-12-14) and problem is gone...
avc, diavc, fastest decoder, h.264, software |
