Old 24th September 2006, 21:49   #1101  |  Link
popper
Originally Posted by Doom9 View Post
MeGUI is the most comprehensive GUI based ISO MPEG-4 solution.
Avisynth 2.55 for video frameserving. Beta versions are NOT!!! supported
the http://www.doom9.org/Soft21/SupportU...iSynth_255.exe
link is broke in the first post.
popper is offline
Old 24th September 2006, 22:39   #1102  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
That's okay, 2.55 is long outdated and MeGUI will download its own Avisynth package when you run autoupdate the first time, anyway.
foxyshadis is offline
Old 25th September 2006, 00:21   #1103  |  Link
Rash
Rash's Avatar
Let me just ask a very very stupid question, though I sincerely don't know the answer.
How do I know which version of the XviD encoder was used in a mencoder build?
Rash is offline
Old 3rd October 2006, 18:55   #1104  |  Link
sjchmura
Please no one laugh - I am sure this is simple and I apologize for beign so dumb..
I am giving up on nero (as Foxy can attest)
ATSC+AC3-> Mp4 (no brainer)
-> MKV PRESERVING the AC3....
1. In the MEGUI "autoencode" section, after setting up my AVISynth, if you want to PRESERVE the AC3 and not "resample" it to AC3 is there an option? If you choose AC3 the original 5.1 AC3 gets resampled.
DO you just need to mux it manually???
2. To clean up some low-bit rate HDTV ATSC source, should I use undot() or some other filer.....
sjchmura is offline
Old 3rd October 2006, 19:38   #1105  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Originally Posted by Isochroma View Post
Error Report
MeGUI 0.2.3.2192
x264 577-1
Previous x264 worked (575), this one is showing nf parameter error:
Starting job job1 at 4:09:11 PM
encoder commandline:
--crf 20 --no-fast-pskip --nf --no-cabac --subme 7 --analyse p8x8,b8x8,i4x4 --qpmin 1 --me esa --thread-input --progress --no-dct-decimate --no-psnr --output "F:\Desktop\AS2004\A2004.t1.r1-v3.mp4" "F:\Desktop\AS2004\A2004.t1.r1.avs"
successfully started encoding
Processing ended at 4:09:12 PM
Log for job job1
x264 [error]: invalid argument: nf = (null)
The problem is x264 577-1 removed the -nf parameter (Enable Deblocking in the GUI). At least the cmdline syntax list doesn't show it anymore.
Feature Request
On a more personal note, I use only the x264 component, but when updating it auto-checks all the components with updates. I have to manually uncheck them each time. A check all / uncheck all button would be handy; even better would be a second set of checkboxes to indicate whether I want them updated.
Another idea would be to renovate the window into a full components manager, with the ability to add and remove (delete) components, and only update the components that are installed. This would save a lot of time updating.
--nf should be still there... if it doesnt then it's a bug in the x264 commandline parser coz the changelog doesnt says it was removed but
better error checking in x264_param_parse.
add synonyms for a few options.
However checking the 577 changes seems --nf was removed in favour or --n
Sharktooth is offline
Old 4th October 2006, 13:08   #1106  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
In build 578A I added a fix for the --nf switch.
MeGUI should auto-update x264 to that version.
Old 5th October 2006, 14:52   #1107  |  Link
bob0r
Pain and suffering
bob0r's Avatar
581 has --nf fixed again, but better just use --no-deblock
bob0r is offline
Old 5th October 2006, 14:57   #1108  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
confirmed... it was fixed in rev579.
Old 6th October 2006, 15:01   #1109  |  Link
mrdutchie
ok, trying this program for the last 4 days...
not getting it to work.
Sometimes it closes without anyerror after creating a d2v file
I have all the latest files
but getting a error like this
Scripterror about Colormatrix command
I am using avisynth256 can't get the 255 anywhere.
is that causing the problem?
Also for Output. I select 1/2 CD, but there is no profile etc.
Do I need to create my own ones?
I was able to import the Divx profiles and another set of profiles.
I am confused lol....
Thanks
mrdutchie is offline
Old 6th October 2006, 15:52   #1110  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
also the auto-update server is down so megui wont be able to automatically get all the required components.
Old 6th October 2006, 16:52   #1111  |  Link
mrdutchie
seems to work fine.
downloaded all the files from that link
http://mewiki.project357.com/auto/?title=auto
Isn't there a link with a good manual/install ? I saw 1 but the link ain't working...
so.... I am still stuck with my issue.... see above
and where can i find avisynth255 only finding 256 and doom9 links are dead
maybe that's my problem, that they took a function out?
Old 6th October 2006, 17:24   #1112  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
256 should work as well as 255
Old 6th October 2006, 20:41   #1113  |  Link
mrdutchie
I am getting the error
The file "E:\yugioh\episode1.avs" cannot be opened
Script Error : there is no function named "ColorMatrix"
I saw that ColorMatrix is set when you turn on a option in
the Setup under a MPEG2 setting for Color Correction
Old 6th October 2006, 21:39   #1114  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
You need the colormatrix filter or just disable color correction.
Old 7th October 2006, 04:57   #1115  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
Just a note, that mirror is pretty out of date now, I know at least x264 has been updated a lot. Anyone know how to make wget (or any unix command) to synchronise the real /auto folder with mine?
check is offline
Old 7th October 2006, 11:52   #1116  |  Link
Doom9
clueless n00b
You're putting a lot of stress on those servers by redownloading everything.. there's really no point in doing so.. the installer really does nothing but copy files and write an adapted settings file.
You can't really configure
the actual avisynth that is used for opening scripts.
And, that error you posted is pretty self-explanatory imho.. it tells you that AviSynth needs to be installed.. what more do you want?
Doom9 is offline
Old 7th October 2006, 18:12   #1117  |  Link
Tropican
Um, I don't know if this is the right place to post this but the link to the wiki documentation isn't right in the sticky. It should be: http://mewiki.project357.com/Main_Page
Tropican is offline
Old 7th October 2006, 18:19   #1118  |  Link
mrdutchie
seems like there is a bug in the software
Why do I need to put everytime the "Extra" folder with the
4 filters into the folder where my file is that needs to be decoded..
I can't find a place to set a Extra Folder, so it's always can stay there.
Old 8th October 2006, 02:29   #1119  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
@Tropican: thanks for the update.
@mrdutchie: You can specify the location of .cqms in the codec config window for xvid, on the second or third page near the bottom.
check is offline
Old 8th October 2006, 12:27   #1120  |  Link
parcival
Is it going to be fixed? Is there another way to update (get the xml from another server)?
parcival is offline
