11th February 2016, 22:47 | #36041 | Link | |
GeForce GTX 660 | Core i5-4430 | DDR3 1866Mhz 16GB | 1080p VS239H-P | Win7 x64 |
11th February 2016, 23:17 | #36042 | Link |
madvr is more GPU heavy than EVR though. perhaps your CPU might still be fine if your GPU were better, cant tell for sure.
11th February 2016, 23:19 | #36043 | Link |
HEVC 4K 10-bit is *extremely* CPU intensive still, you would need an absolute high-end CPU to decode it, and even then it may not work entirely fluidly depending on the bitrate.
If you want an old PC to handle such content, your best bet is to buy a GPU with support for decoding it. Also, to start, make sure you use a 64-bit player, since HEVC decoding is generally much faster on 64-bit.
11th February 2016, 23:41 | #36044 | Link | |
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
12th February 2016, 00:02 | #36045 | Link | |
12th February 2016, 00:23 | #36046 | Link | |
His test video is also 60fps. Unrealistic video specs imo. |
12th February 2016, 00:25 | #36047 | Link | ||
Using x86 I cannot play that video smoothly with a i7-5960X at 4.2GHz and a 980Ti at 1506MHz, it isn't the GPU that is the problem it is the CPU. My i7-5960X cannot keep the decode queue full using LAV's 32-bit HEVC decoder. 64-bit is pretty much required for 4K 10-bit HEVC software decoding today.
madVR options explained |
12th February 2016, 01:56 | #36048 | Link | |
The same can be said for the color gamut, which is matrixed to the gamut set in calibration. What won't work is the playback of copyright-protected UHD content.
12th February 2016, 01:58 | #36049 | Link | |
Finally opted for EVR-CP/nearest neighbor when I noticed that the "frame rate" was over 100fps and looking to go higher while feeding a 60fps display... Don't have a 3D rig here but could this be due to the vid being 3D. If so I suspect the only way to play it right would be with full hardware decoding in the GPU..which is kinda scarce at the moment. Looks like upgrade time..again Cum on bak to the red side Jim Last edited by MistahBonzai; 12th February 2016 at 02:01. |
12th February 2016, 02:02 | #36050 | Link |
If the queues aren't filling, your settings are probably still too aggressive.
12th February 2016, 02:32 | #36051 | Link | |
12th February 2016, 02:34 | #36052 | Link |
Some actually have to downgrade, (or add a second card?) To get real 10 bit hevc hardware decode. When you really have enough contents, it will get supported, so I personally really don't stress over it.
Anyways, if I am right, madvr performance should not care if the source is hevc or what not, all that matters should be size (pixel ) and fps. Sent from my SM-T700 using Tapatalk |
12th February 2016, 04:40 | #36053 | Link | |
12th February 2016, 05:15 | #36054 | Link |
Okay fellows, Thanks!
The test video is 4k 10bit 60fps 50Mbit/s, so it is not yet the heaviest the format allows, the heaviest would be with 128Mbit/s and rec.2020 with Metadata which has to be scaled by madVR. As far as I understand, a hardware decoder is essential for the next generation of video, because even current generation overclocked desktop CPUs are barely managing. A new GPU with hardware decoder will bring the CPU usage to 0% as I see with the heaviest 40Mbit/s 1080p 24fps bluray content. My GTX660 handles video just fine with only 20% load of the VPU (video decoder) on 40Mbit/s 1080p videos. The GPU load is around 10% because I use Lanczos and Bicubic, nothing special. I don't feels the need to upgrade my GPU (I don't play games at all), but for HEVC hardware decoding maybe I should.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. Last edited by James Freeman; 12th February 2016 at 05:24. |
12th February 2016, 08:19 | #36056 | Link |
Hi guys with the latest madvr .90+. I'm having with issues with the delayed video frame as for the OSD I'm only having 2 drop frame and 0 delayed frame but video was totally out of sync with the audio, as it progress the delay increases.
My Laptop Specs: Intel 4770hq i7 16GB RAM NVIDIA GT 745M |
12th February 2016, 10:09 | #36057 | Link | |
I've tested MadVR's HDR to SDR conversion and it works well, but it's not optimized for each HDR display (and of course reap some of the benefits of HDR content on SDR displays, which is great). HDR10 calibration is such a mess that manufacturers are the only ones to know how they handle HDR on each display. Hence the need for proper HDR support, as MadVR has no way to know which display is connected and which settings are optimal for that display. What's great is that it's giving us options to try to find optimal settings (like the nits settings). It would be nice to have an HDR passthrough option though, just in case it gives us a better (as in more accurate) picture for some HDR displays which can be autocalibrated by the manufacturer in accordance with whichever HDR10 calibration rules they have decided to implement for their display, as there is no standard. Let's not open an HDR10 calibration discussion here, it's off topic, but Madshi has made it very clear that the current HDR implementation was an HDR to SDR conversion for SDR displays, and that a proper passthrough HDR implementation would only be possible with HMDI 2.0a support at GPU/Driver/API levels.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 12th February 2016 at 16:33. |
12th February 2016, 10:39 | #36058 | Link | |
Thirdly, i'm slightly pissed off my JS9000 doesn't fully support HDR, damn marketing, lol. The good news with HDR is that local dimming on most TVs won't "bug" when used with a HTPC, as the TV lights up areas with movements it also lights up subtitles, making local dimming nearly useless on HTPC setups as it ruins the movie more than helping. Logically these new subtitles will have fixed positions due to HDR metadata so i hope Madshi will incorporate that or give an option to disable subtitle HDR metadata. Last edited by XTrojan; 12th February 2016 at 10:46. |
12th February 2016, 14:37 | #36059 | Link | |
On another note, I've been playing around with some HDR demos on a non-HDR TV. Anyone know roughly what nits I should be choosing for an (uncalibrated) LG plasma? Last edited by iSeries; 12th February 2016 at 14:42. |
12th February 2016, 20:18 | #36060 | Link |
I was finally able to watch a 3D Blu-ray yesterday. I converted an ISO to an MKV with MakeMKV. The movie was an MPEG4-AVC version of Avengers: Age of Ultron. The source was an uncompressed frame-packed rip sent to an active 3D display.
I must say I was impressed. While the 3D effect is modest at times, the level of detail was excellent. I was even able to use crispen edges to sharpen the image further. If I was to choose a version of a movie to watch, I would go for the 3D version. It is a shame 3D technology is being abandoned. But it would take a lot of new titles in my collection to care enough about this tech. The quirks include some unnecessary time browsing the TV's menus to get 3D working and some trouble getting the 3D glasses to sync with the display. The whole process could be simplified to improve the experience.
