Old 2nd November 2019, 20:17   #28941  |  Link
Mike-uk
Originally Posted by FreaQ View Post
How do I enable One-Pass CRF Encoding?
I already put FIXED_CRF=19 in my bdrebuilder.ini but the option ist still grayed out.
Anything else I have to consider?
you shouldnt need to amend the.ini to get 1 pass,
re download the latest version and pop into a folder somewhere and by default it will be 1 pass auto quality
Mike-uk is offline   Reply With Quote
Old 2nd November 2019, 21:35   #28942  |  Link
FreaQ
Starfish
FreaQ's Avatar
One Pass is only enabled with ABR option. But I want the CRF option.
FreaQ is offline   Reply With Quote
Old 2nd November 2019, 21:43   #28943  |  Link
cartman0208
I think I answered that some days ago ... do NOT use FRIM source or internal LAVF for frame serving ... just leave it at DirectshowSource ...
cartman0208 is offline   Reply With Quote
Old 2nd November 2019, 22:13   #28944  |  Link
FreaQ
Starfish
FreaQ's Avatar
Thanks that did the trick. Did not have ffdshow installed.
Old 3rd November 2019, 15:32   #28945  |  Link
jdobbs
Originally Posted by FilipeAmadeuO View Post
Jdobbs
Can I send Michi the testing version you have sent me by PM ?
It improves a lot the FF/REW problem on Dolby vision titles.
Any development on that issue ?
Thanks
I don't mind. But, you may want to hang on, I'm about to send you a link to another test version via PM.
Website: www.jdobbs.net
Old 3rd November 2019, 15:37   #28946  |  Link
FilipeAmadeuO
Further testing on m2ts stuttering. I used BDrebuilder for movie only and in that case both m2ts are joined.
The stuttering still exists, so my conclusion is that the problem is probably on tsmuxer remuxing.
Probably itīs some correction that itīs not 100% fixed.
FilipeAmadeuO is offline   Reply With Quote
Old 5th November 2019, 22:29   #28947  |  Link
jdobbs
BD Rebuilder v0.60.29
I have updated the first post of this thread with a link to the latest version of BD-RB. Changes for this release:
- Updated the UHD remuxing routines to more
  accurately represent the access points for
  FF/REW on dolbyvision sources.
- Added routine to scan/examine dolbyvision
  streams and align iframes in the reencoded
  output for matching CPI() references.
- Added code to extract and convert timed
  text subtitles to SRT from MP4 files during
  import so they can be used in BD creation
  or output to ALTERNATE formats.
- Other minor corrections and cosmetic fixes.
Old 6th November 2019, 03:08   #28948  |  Link
Lathe
Lathe's Avatar
Thanks Boss!
I don't normally do 4k, so sorry I'm a little fuzzy on what exactly BDRB does with these sources. Can you import a 4k source, say an MKV file that is 3840 by 2160 and I would guess that it would also be x265, right? Then, what are your options as to what to do with it? Can you then render it as a playable standard Blu-ray with x264. Does it automatically resize it? Can you render it to a 'normal' playable x264 MKV file? I'm just not sure what BDRB does exactly or what UHD sources you can import with it.
I don't have a 4k setup. I have an OPPO BDP-83 which I just sent to OPPO to have it reconditioned. I like it mainly because it is pre-Cinavia and I back up a LOT of my stuff. And, I have a very old Plasma that hasn't died yet and still looks really good, so I'm just wondering if I can take some of these 4k sources, either the full 4k Blu-ray or an MKV file taken from it and make it playable on my 'standard' Blu-ray equipment, and exactly what options I have to do so?
I appreciate any input, thanks!
Lathe is offline   Reply With Quote
Old 6th November 2019, 03:20   #28949  |  Link
Lathe
Lathe's Avatar
Just another quickie... (it doesn't take me long to recover )
Assuming, that BDRB does this then, how is the 'quality' retention. I mean, when you take even a really large standard Blu-ray, say over 40 Gigs and you use BDRB to render it to a BD25, the results are beautiful. How does that compare if you are converting full 4k resolution to standard Blu-ray resolution (assuming BDRB does this) I mean, is the quality retention just as comparable, or with the resizing and all, is it simply better just to stay with the standard HD versions. Just curious if it is worth the trouble...
Old 6th November 2019, 11:48   #28950  |  Link
gonca
I'm surprised you can get started
gonca is offline   Reply With Quote
Old 6th November 2019, 20:34   #28951  |  Link
cartman0208
Scroll up ... I think jdobbs kind of answered this about 10 posts before yours
Old 6th November 2019, 22:47   #28952  |  Link
gonca
You mean that jdobbs said that UHD to HD conversion isn't supported yet?
Old 6th November 2019, 22:49   #28953  |  Link
gonca
Not positive what you are asking. But if you plan to have it stay UHD, there is no choice. The specification requires it to be HEVC (X265). If your intent is to resize it and create a 1080p BD-25... BD-RB doesn't have an option to resize UHD to HD yet.
This is the post Lathe
Old 7th November 2019, 01:38   #28954  |  Link
FilipeAmadeuO
Jdobbs
Any chance to add a option of replacing audio/subtitle on BD/UHD ?
I know that I can do it by replacing files on workfile but I have to redo everything twice.
Old 7th November 2019, 02:28   #28955  |  Link
zamengo
Jdobbs
You don't need to do everything twice, replace track before muxing, i have no problem with this.
zamengo is offline   Reply With Quote
Old 7th November 2019, 05:56   #28956  |  Link
Lathe
Lathe's Avatar
DOHHHHHHH!
Well, at least I do not require a picture of a sleek, sexy elk...
Old 7th November 2019, 06:01   #28957  |  Link
Lathe
Lathe's Avatar
Oh okay... So, all that BDRB does then with UHD sources or any content that has that resolution is just compress it but KEEP that same resolution, and what, use x265 to compress it...?
What would help me a little better is if someone could please just state exactly what BDRB does with UHD or 4k sources. That would clear it up for me. Thanks for the clarification, though, about it apparently not converting it from UHD to a regular x264 playable Blu-ray.
Old 7th November 2019, 06:06   #28958  |  Link
Lathe
Lathe's Avatar
... and, I am STILL not getting any notifications when someone posts here. What do I hafta do, sacrifice a goat in my backyard or something...?!
I just now added 'http://forum.doom9.org' for Chrome to allow this site to set cookies. I didn't think that I specifically had to do that, but nothing else has worked so far...
Old 7th November 2019, 06:11   #28959  |  Link
Lathe
Lathe's Avatar
Sorry to talk to myself, but... So, what I am understanding from this so far is that BDRB will convert all OTHER formats to a playable Blu-ray or an Alternate file (MKV for example) But, as far as any 4k content, that is dealt with ONLY within it's own format, right? So, in the case of UHD material, that is the ONLY format with which BDRB does NOT convert it to any other format, is that right? So, in other words, BDRB deals with either HD material OR UHD material, each one handled COMPLETELY SEPARATELY, right?
Old 7th November 2019, 08:39   #28960  |  Link
MrVideo
MrVideo's Avatar
I haven't gotten any e-mail from any thread I'm in here on Doom9.
