Old 17th May 2020, 05:05   #1361  |  Link
DiablosDemon
hmmmmmmm
I had a earlier post that referenced the problems I was having with Minusthebear's script but I think It went to a moderator. It was automatically putting the FPS at 30 no matter what I changed. hopefully that post will show soon.
DiablosDemon is offline   Reply With Quote
Old 19th May 2020, 01:12   #1362  |  Link
DiablosDemon
found the 30FPS
I found why the 30 FPS was hard wired at the very bottom of the script.
interpolated= SVSmoothFps(autolevels, super, vectors, "{rate:{abs:true, num:30, den:1}}", mt=threads).sharpen(last_sharp,mmx=false).sharpen(last_sharp,mmx=false).blur(last_blur,mmx=true)
Changed it to 16 and it was better, still something else going on with this to change how many frames I input. must be part of this line I'm still trying to figure it out.
I'm still not sure about the super in my previous post.
I was hoping this would work faster using the GPU for some tasks.
Old 2nd June 2020, 04:54   #1363  |  Link
`Orum
Originally Posted by pinterf View Post
Anyway, a quick and dirty UnsharpMask replacement for Avs+
<snip>
This seems to cause artifacts on the right side of the frame for me, near (but not on) the edge, from the top of the frame to the bottom, though it varies in brightness/contrast and is less visible in some areas than others.
Is there another option for UnsharpMask() with 64 bit and HBD support? I'm guessing it's due to the blur filter, so maybe just replacing that would be enough.
Edit: Looks like you can just swap out the original blur with aBlur from AWarpSharp2. Here's the modified script, which doesn't have the artifacts from the original, but also will no longer work with RGB:
function UnsharpMask(clip clip, int "strength", int "passes", bool "highq", int "threshold") {
	strength  = default(strength, 64)
	passes    = default(passes, 3)
	highq     = default(highq, true)
	threshold = default(threshold, 8)
	blurclip = aBlur(clip, passes, highq ? 1 : 0)
	e = "x y - abs " + String(threshold) + " scaleb > x y - " + String(strength/128.0)+ " * x + x ?"
	Expr(clip, blurclip, e, "", "") # U and V are copied
My filters: DupStep | PointSize
`Orum is offline   Reply With Quote
