23rd January 2011, 18:50 | #8981 | Link |
Hello Cornflower .. I was reading the posts for this same error. I did not see that anyone answered your question, so I am including myself with your problem. I just opened up Ripbot and was excited about using it, but every video I open gives me the same error message. Any help on how to fix this will be greatly appreciated. Thanks
24th January 2011, 00:05 | #8982 | Link | |
24th January 2011, 18:54 | #8983 | Link |
Has anybody used RipBot on a Mac using Parallels? I just tried it last night, and found the performance to be significantly worse than I expected. I was encoding Mary and Max (2009), which took around 6.5hrs on my Core 2 Duo Windows 7 laptop, and it took around 3.5 hours on my Core i7 Mac Book Pro. I had all 4 CPU cores assigned to the VM, and had somewhere around 6GB of RAM availble to the VM. Does that sound about right, or am I getting slowed down by the fact that I'm running RipBot in a VM? Would it be significantly faster on BootCamp?
24th January 2011, 19:56 | #8984 | Link |
Your MacBook has a Core i7 6xxM, which is a dual core CPU.
As such, it won't be as fast as a quad core i7. Your OS sees 4 CPUs because of Hyper-Threading (2 threads * 2 cores = 4 threads). If you're using a 32-bit edition of Windows, try installing a 64-bit edition. The encoding will be a little faster because the 64-bit version of x264 encoder will be used. Installing Windows with BootCamp will give you better results, but how much time will you save ? 1 hour ? 5 minutes ? I don't know. If you've got the time, try to see it by yourself P.-S : I don't know your encoding settings, but 3.5 hours seems a pretty good score for me. FYI it takes 7-8 hours for a 1080p movie with CQ18 on a Core i7 820QM. |
24th January 2011, 22:28 | #8985 | Link | |
It's a 64-bit version of Windows, btw. Also, the movie takes somewhat less time to encode because it's animated. Regular 1080p movies take around 10-16 hours on my Windows box (the Core 2 Duo one, that is). Haven't done much encoding with the Parallels setup yet, since it's a pain (no BD drive yet, one's on the way). |
25th January 2011, 00:04 | #8986 | Link |
I have a problem with ripbot
When I opened a file I get this error cannot open file: .......blu-ray_structure_info.txt Is there a solution? can someone upload a package in which all of the latest tools and include ripbot are? must pay attention to something if the tools installed? |
25th January 2011, 00:34 | #8987 | Link |
Hey all, Having an issue that i hope someone can help me with
I've been using a older version of RipBot264 (dont recall what the release number is but its probably a few releases back). well after downloading the latest version, i've noticed an issue with audio. I recently was archiving a few blu rays i own and noticed that after muxing, when i choose audio i want to be use for final encoding, i have no option to copy stream anymore ? I usually pick DTS 5.1 master or TRUE HD and used to be able to use that audio for the final encode (i encode to MKV) now i dont have this option anymore only 5.1 options i can choose from are aac or AC3. i usually go with AC3 and the highest bit-rate option (640kbps) how can copy stream like i used to be able to? thanks |
25th January 2011, 12:57 | #8988 | Link |
@Mario0708
edit ripbot264.ini change StoreTempFilesin=AUTO to StoreTempFilesin=C
25th January 2011, 20:57 | #8990 | Link | |
I already have an i7 920 OC'ed to 4GHz that does around 30 something FPS on 2nd pass of 720p encodes. But I am building a comp for my brother with the new i5 2500K, and I hope he can get even faster encodes than I do |
26th January 2011, 15:30 | #8993 | Link |
What exactly is the HD Audio option? I see it references core in the changelog. I am testing the newest version and I see the option to choose the core (so this is not the same as grabbing the full HD Audio track).
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
26th January 2011, 15:57 | #8995 | Link |
Yeah, I just ran Ripbot on a BluRay and you cannot grab the full HD Audio track, just the core.
26th January 2011, 19:17 | #8999 | Link | |
General Complete name : D:\mkv\Shows no audio on ripbot\I Am Legend.mkv Format : Matroska File size : 12.9 GiB Duration : 1h 43mn Overall bit rate : 17.8 Mbps Encoded date : UTC 2011-01-15 03:45:01 Writing application : MakeMKV v1.6.3 win(x64-release) Writing library : libmakemkv v1.6.3 (0.7.7/0.8.1) win(x64-release) Video ID : 1 Format : VC-1 Format profile : AP@L3 Codec ID : WVC1 Codec ID/Hint : Microsoft Duration : 1h 43mn Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Language : English Audio ID : 2 Format : TrueHD Codec ID : A_TRUEHD Duration : 1h 43mn Bit rate mode : Variable Maximum bit rate : 3 366 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Title : 5.1 Language : English Text ID : 3 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English Menu 00:00:00.000 : en:Chapter 00 00:02:13.133 : en:Chapter 01 00:07:58.478 : en:Chapter 02 00:12:09.729 : en:Chapter 03 00:15:17.750 : en:Chapter 04 00:18:22.267 : en:Chapter 05 00:23:24.569 : en:Chapter 06 00:26:44.269 : en:Chapter 07 00:31:51.409 : en:Chapter 08 00:34:17.722 : en:Chapter 09 00:38:06.450 : en:Chapter 10 00:39:36.707 : en:Chapter 11 00:44:24.662 : en:Chapter 12 00:49:12.449 : en:Chapter 13 00:54:16.086 : en:Chapter 14 00:57:15.432 : en:Chapter 15 01:00:02.098 : en:Chapter 16 01:03:02.111 : en:Chapter 17 01:04:51.220 : en:Chapter 18 01:09:39.175 : en:Chapter 19 01:11:42.464 : en:Chapter 20 01:15:33.862 : en:Chapter 21 01:19:07.743 : en:Chapter 22 01:21:43.899 : en:Chapter 23 01:26:44.532 : en:Chapter 24 01:28:56.998 : en:Chapter 25 01:34:28.162 : en:Chapter 26 |
26th January 2011, 19:29 | #9000 | Link |
Added: demuxing TrueHD from .mkv container (demuxed .thd MUST be manually selected after demuxing!!!)
