14th March 2019, 04:38 | #21 | Link | |
SuperVirus
- if( i_csp >= X264_CSP_I444 && h->param.b_cabac ) - { - /* Disable 8x8dct during 4:4:4+CABAC encoding for compatibility with libavcodec */ - h->param.analyse.b_transform_8x8 = 0; Last edited by filler56789; 14th March 2019 at 04:38. Reason: disambiguation |
14th March 2019, 07:48 | #23 | Link |
I assume that libav fixed the decoding of strict video streams already a while ago, so x264 can now safely remove the compatibility changes for libav before a threshold date. But I don't know which date.
14th March 2019, 07:52 | #24 | Link | ||
FFmpeg avcodec/h264_cabac: Fix CABAC+8x8dct in 4:4:4 avcodec/h264_mb: Fix 8x8dct in lossless for new versions of x264 Libav h264_cabac: Fix CABAC+8x8dct in 4:4:4 h264dec: fix Lossless Decoding (Profile 244) for 8x8 Intra Prediction With old versions of FFmpeg/Libav you can have problems decoding lossless or 4:4:4+CABAC streams encoded with new x264. |
14th March 2019, 11:14 | #26 | Link |
You can remain compatible to "old" and "new" lossless ffmpeg decoding by setting --no-8x8dct at <1% compression loss.
But: is "Remove compatibility workarounds" really in your builds? It's still only part of the "master", not the "stable" branch. Has been like that since almost 2 years now. |
14th March 2019, 11:35 | #27 | Link |
Actually "Remove compatibility workarounds" was only in the experimental sandbox for 2 years, it moved to master 7 days ago, and will presumably be in the next stable push, unless they take it back out at some point, since stable is generally "just" an older master.
14th March 2019, 11:35 | #28 | Link |
MABS update logs for x264-git report:
HEAD is now at d4099dd4 Remove compatibility workarounds |
14th March 2019, 11:44 | #29 | Link | |
Can confirm the changes are also already in the "official" binaries from videolan. |
18th July 2019, 07:53 | #30 | Link |
New upload: x264 core:157 r2971 98ee9d2
x264 0.157.2971 98ee9d2 (libswscale 5.4.101) (libavformat 58.28.102) (ffmpegsource 2.31.0.0) Win32: built on Jul 17 2019, gcc: 9.1.0 Win64: built on Jul 17 2019, gcc: 9.1.0 x264 configuration: --chroma-format=all libx264 configuration: --chroma-format=all x264 license: GPL version 2 or later libswscale/libavformat/ffmpegsource license: GPL version 2 or later Last edited by LigH; 18th July 2019 at 07:56. |
18th July 2019, 18:40 | #32 | Link | |
Software Developer
https://pastebin.com/HkvZdjnQ
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th July 2019 at 18:42. |
18th July 2019, 20:00 | #34 | Link |
Thanks for the info...
This leads to the question how well new commits are tested before they are called stable. From FFmpeg I learned it the hard way that it is a bad idea to always use the very latest "stable" build because thorough testing is not a particular strength of the FFmpeg devs. Is this different for X264? Should I upgrade to a new stable build immediately after it is released, or is it wiser to stick with older versions until there is a real need for an upgrade (like support for new formats, important bug fixes etc) ? |
18th July 2019, 20:35 | #35 | Link | |
https://artifacts.videolan.org/x264/ |
18th July 2019, 21:26 | #36 | Link | |
Software Developer
19th July 2019, 12:40 | #37 | Link |
New upload: x264 core:158 r2984 3759fcb
x264 0.158.2984 3759fcb (libswscale 5.4.101) (libavformat 58.28.102) (ffmpegsource 2.31.0.0) Win32: built on Jul 19 2019, gcc: 9.1.0 Win64: built on Jul 19 2019, gcc: 9.1.0 x264 configuration: --chroma-format=all libx264 configuration: --chroma-format=all x264 license: GPL version 2 or later libswscale/libavformat/ffmpegsource license: GPL version 2 or later |
20th July 2019, 17:08 | #38 | Link |
SuperVirus
https://git.videolan.org/ says:
MOVING TO GITLAB We're moving projects to code.videolan.org, notably: - x264 - VLC for WinRT - VLC for Android - VLMC - NPAPI-VLC - libdvdread - libdvdnav - libdvdcss - biTStream - DVBlast - libdvbpsi - libbluray - libudfread - libaacs - libdplus Regarding x264 specifically (or at least), the problem is that it's impossible to clone the x264 repository on GitLab through git :–/ => git clone git://code.videolan.org/videolan/x264.git Cloning into 'x264'... warning: blah-blah-blah fatal: unable to connect to code.videolan.org: code.videolan.org[0: 88.191.250.9]: errno=No error Oh, yes, anyone can download the latest tarball or zipball through a web browser, but then the compiled binary doesn't show the correct version /commit number -_- |
20th July 2019, 18:04 | #39 | Link |
Did you construct that URL yourself? Because I don't see it anywhere on the GitLab page.
When you select the Clone button there, it'll give you a valid URL: https://code.videolan.org/videolan/x264.git - which works just fine with "git clone". The git protocol is being deprecated all over the web because its insecure and unscalable, in favor of HTTPS.
20th July 2019, 18:47 | #40 | Link | |
SuperVirus
In this case specifically: Code:
$ git clone https://code.videolan.org/videolan/x264.git Cloning into 'x264'... fatal: unable to access 'https://code.videolan.org/videolan/x264.git/': error setting certificate verify locations: CAfile: R:/MAKE6T4/usr/lib/ssl/certs/ca-bundle.crt CApath: none EDIT 1: Okay, I found a workaround, and now git finally 1) "understands" HTTPS and 2) found the damn certificate because I created the directory where the stupid application expected to find it. </CASE_CLOSED> EDIT 2: So far Mercurial has never shown the limitations that git shows on Windows... Until 2 days ago, I had always used git with cmd.exe and in this way it only works with the git protocol... whereas Mercurial has always worked fine on the so-called command-prompt of Windows. Last edited by filler56789; 20th July 2019 at 19:41. Reason: edits |
