14th December 2010, 02:13 | #123 | Link | |
My actual output file? WinDVD says it is 25p: check one of my previous posts: (the result of my previous code without --fps 23.976) http://forum.doom9.org/showpost.php?...5&postcount=95 Last edited by rica; 14th December 2010 at 02:52. |
14th December 2010, 02:35 | #124 | Link |
OK, the latest code gave 23.976 with --fps 23.976 switch, (even it says it is 25/1)
thanks: EDIT: But Vegas didn't like that and it doesn't want to open it. _ _ _ _ Last edited by rica; 14th December 2010 at 02:53. |
14th December 2010, 06:54 | #125 | Link | |
I'm using two Panasonic HS700 camcorders to record independent left/right 1920x1080/60p h264 mts streams and would like to encode them into single 3840x1080/60p side-by-side video. Appreciate if you could provide any guidance. Many thanks and best regards. Last edited by mariner; 14th December 2010 at 08:09. |
14th December 2010, 08:28 | #126 | Link |
aka Rabomil
@mariner
You could use an Avisynth script like this: Code:
VideoLeft = directshowsource("C:\x264\left.mkv", audio=false) VideoRight = directshowsource("C:\x264\right.mkv", audio=false) VideoStacked = StackHorizontal(VideoRight,VideoLeft) ConvertToYV12(VideoStacked) |
14th December 2010, 11:41 | #127 | Link | |
1. Does this work on .mts streams directly? This is way over my head, so would appreciate if you could provide full script. 2. How to select the audio track used? 3. The 3840x1080 video is to be spanned over two projectors, so hdmi 1.4a is not required. Do you know any video card that will decode this is DXVA? Many thanks. Last edited by mariner; 14th December 2010 at 11:46. |
14th December 2010, 12:28 | #128 | Link |
1. No, it has to be re-encoded, so you have to use mkv. That is the full script for full SBS. It works on m2ts streams if you have 2 m2ts streams, but you have to re-encode the right eye, so mkv is the only way. You can use SSIFsucka or multiAVCHD, it would be much easier for you if you don't know to handle avs scripts.
2. You merge them in with mkvmerge after you demux them from your blu-ray disc. 3. Any video card that is DXVA capable. As far as I know, the only cards capable of HDMI 1.4a are from nVidia's 4xx series and above and ATI's 5xxx series and above. Full script for half SBS: Code:
lv = DirectShowSource("left.mkv") rv = DirectShowSource("right.mkv") stacked = StackHorizontal(HorizontalReduceBy2(lv), HorizontalReduceBy2(rv)) ConvertToYV12(stacked) Code:
lv = DirectShowSource("left.mkv").crop(crop values) rv = DirectShowSource("right.mkv").crop(crop values) stacked = StackHorizontal(HorizontalReduceBy2(lv), HorizontalReduceBy2(rv)) ConvertToYV12(stacked) Last edited by crl2007; 14th December 2010 at 12:32. |
15th December 2010, 03:26 | #129 | Link |
Like rica, my right eye video is too short so it is completely useless. It is approximately 30 seconds too short for a 2 hour and 41 min film (I'm sure you can guess which film I am working with). So I am bummed. It seems there is something wrong with the 3D decoder or the x264 encoder. I'm starting to think I am going to have to look for another solution.
UPDATE: eac3to calculated the original length of the video to be 232607 frames. However, once the right eye is encoded, it is only 231893. This is 714 frames short. I am trying to figure out if this could have anything to do with the message from x264 indicating it sees the video as 25 fps even though I forced it to encode at 23.976. I changed my right.avs file to the following: LoadPlugin("H264StereoSource.dll") H264StereoSource("decoder.cfg",232607) AssumeFPS(23.976) Let's hope that does the trick. It seems to be working so far. I guess I'll know for sure in approximately 14 hours. :| Mike Last edited by BigPines; 15th December 2010 at 08:05. |
15th December 2010, 12:21 | #132 | Link | |
1.The source is two complete 1920x1080/60p 28mbps h264 mts streams captures by two Panasonic hs700 camcorder, not 3DBD. A step by step guide to combine these two into a single 3840x1080/60p video would be most appreciated. 3. ATI's UVD2 found in 5 series card cannot cope with these 28mbps 60p streams in DXVA, yielding only 50fps. While Nvidia's PV4 can deal with it, it remains unclear if it will cope with 3840x1080/60p streams. Feedback will be appreciated. Many thanks and best regards. |
15th December 2010, 12:54 | #133 | Link |
For 3840x1080 you must use Limobar's avs script. Just that instead of mkv you use m2ts. Directshowsource is capable of opening m2ts streams. Only that you will have a mkv file as a final result.
I have an nvidia 4xx series, but I never tested with 3840x1080/60p over hdmi 1.4a. I don't have a 3dtv. |
15th December 2010, 16:21 | #136 | Link | |
I know the error at the end is expected but do we know what causes it? Maybe if we understood that, we would understand that it is not normal. *shrug* Please enlighten me. Mike |
15th December 2010, 16:32 | #137 | Link |
I think there're something wrong in cfg file and that's why it miss some frames:
DisplayDecParams = 1 # 1: Display parameters; ConcealMode = 0 # Err Concealment(0:Off,1:Frame Copy,2:Motion Copy) RefPOCGap = 2 # Reference POC gap (2: IPP (Default), 4: IbP / IpP) POCGap = 2 # POC gap (2: IPP /IbP/IpP (Default), 4: IPP with frame skip = 1 etc.) IntraProfileDeblocking = 1 # Enable Deblocking filter in intra only profiles (0=disable, 1=filter according to SPS parameters) DecFrmNum = 0 # Number of frames to be decoded (-n) |
15th December 2010, 17:17 | #139 | Link | |
1. Created a 3D700.avs file with following: Code:
VideoLeft = directshowsource("D:\3D\left.mts", audio=false) VideoRight = directshowsource("D:\3D\right.mts", audio=false) VideoStacked = StackHorizontal(VideoRight,VideoLeft) ConvertToYV12(VideoStacked) Code:
D:\3D>x264 -o 700.mkv 3d700.avs avs [info]: 3840x1080p 0:0 @ 10000000/166833 fps (cfr) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cach e64 x264 [info]: profile High, level 5.1 x264 [info]: frame I:4 Avg QP:28.00 size: 799 x264 [info]: frame P:211 Avg QP:31.00 size: 131 x264 [info]: frame B:622 Avg QP:31.00 size: 125 x264 [info]: consecutive B-frames: 0.4% 0.2% 0.0% 99.4% x264 [info]: mb I I16..4: 100.0% 0.0% 0.0% x264 [info]: mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.0% 0.0% 0.0% 0.0% 0 .0% skip:100.0% x264 [info]: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct: 0.0% skip:100.0% L0:-1.$% L1:-1.$% BI:-1.$% x264 [info]: 8x8 transform intra:0.0% x264 [info]: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.0% 0.0% x264 [info]: i16 v,h,dc,p: 99% 0% 1% 0% x264 [info]: i8c dc,h,v,p: 100% 0% 0% 0% x264 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x264 [info]: kb/s:62.07 encoded 837 frames, 34.24 fps, 62.46 kb/s D:\3D>pause Press any key to continue . . . This is input file properties: Code:
General ID : 1 (0x1) Complete name : D:\3D\left.mts Format : BDAV Format/Info : Advanced Video Codec File size : 41.6 MiB Duration : 13s 938ms Overall bit rate : 25.0 Mbps Maximum Overall bit rate : 28.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.2 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=3, N=30 Codec ID : 27 Duration : 13s 963ms Bit rate mode : Variable Bit rate : 23.6 Mbps Maximum bit rate : 26.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.190 Stream size : 39.3 MiB (95%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : 14s 16ms Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Video delay : -34ms Stream size : 657 KiB (2%) Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 13s 449ms Video delay : -34ms Last edited by mariner; 15th December 2010 at 17:31. |
15th December 2010, 18:53 | #140 | Link |
If you have a nvidia graphic card, please try to run your mts streams through DG Tools. But if you don't have a secondary right eye stream, the stereoscopy is useless, because you will see 2D. The right eye is slightly shifted or lowered for stereoscopy to take place.
Those frames are missed because of the decoder. The guy that made the decoder said that this is normal. We have to deal with it until something better and faster will surface. And free, of course, because with about 5000$ you can have a professional encoder/decoder. I only had 2 seconds missing from an entire movie, never had such problems as to miss more than 2 seconds from the right stream. |
