Old 19th April 2017, 16:17   #21  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by NikosD View Post
Hey,
I have made a few corrections to your "run.sh" file in order to be more consistent to what is running and what is being displayed.
For example, there is no "SSE3" instruction set tested, it's "SSSE3" and so on.
Also, the "All" setting is actually like "auto" so we don't need that.
I added also --no-asm option and I named it "No SIMD" in the final text, in order to see better the speedups of various SIMD sets compared to "No SIMD" setting
All of my changes are here:
http://txt.do/drlqm
yes, I have little bug for "all SIMD" bench.
I will make new script for choose the best x264 and x265 build between VS2017, GCC7 and ICC17
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 19th April 2017, 16:19   #22  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by SquallMX View Post
6700K Stock 4.0 Ghz
|     CPU             |   x264  |   x265  |   LAVC  |   auto  |   MMX2  |    SSE  |   SSE2  |   SSE3  |   SSE4  |    AVX  |   AVX2  |    All  |
|  Core i7-6700K      |  11.95  |   2.28  |    82  |   1.89  |   0.56  |    0.55  |   0.88  |   0.97  |   1.47  |   1.50  |   1.85  |    N/A  |
the most interessing result ... thx
you can (re)make benchmark at your max overclocking?
Stock 4.0 Ghz
in fact stock is at 4.1 Ghz because turbo max for all core is 4.1 Ghz
You choose imposed 4.0 Ghz for all core or your i7-6700K is really in default stock frequency?
Old 19th April 2017, 16:59   #23  |  Link
NikosD
Don't forget to add the --no-asm option.
The "auto" is just fine for "all" SIMD sets.
Also, as I had told you in PM, the ffmpeg LAV video decoder is a lot faster in HEVC decoding than the script, probably due to more threads involved.
But using that script we can compare different CPUs to each other on the same script and not to absolutely fastest decoding.
Win 10 x64 (18363.720) - Core i3-9100F - nVidia 1660 (442.74)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 19th April 2017, 18:09   #24  |  Link
SquallMX
Special SeeD
the most interesting result ... thx
i7-6700K stock clock for all cores at full is 4.0 GHz. Unfortunately is a DTR so no overclocking because of the cooling conditions.
SquallMX is offline   Reply With Quote
Old 20th April 2017, 12:19   #25  |  Link
Motenai Yoda
Motenai Yoda's Avatar
here my results.log
|  Core i7  920 @3.8  |   7.90  |   1.14  |     49  |   0.96  |   0.37  |   0.37  |   0.60  |   0.65  |   0.96  |    N/A  |   N/A   |    N/A  |
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 23rd April 2017, 17:40   #26  |  Link
RanmaCanada
Well it looks like according to these benches I need to upgrade to at least R1700.
Thank you for the comprehensive tables.
Old 25th April 2017, 08:29   #27  |  Link
Fador
Xeon E5-2699 v4 @ Stock
|  Xeon  E5-2699 v4 |  31.04  |   6.79  |   135  |   4.95  |   1.72  |    1.73  |   2.66  |   2.88  |   4.21  |    4.22  |   4.87  |    N/A  |
Fador is offline   Reply With Quote
Old 27th April 2017, 15:58   #28  |  Link
Yanak
Hello, CPU runs @4.2Ghz
|  Core i7-3770K      |  10.35  |   1.46  |    72  |   1.22  |   0.47  |    0.47  |   0.76  |   0.81  |   1.22  |    1.23  |   N/A  |    N/A  |
Yanak is offline   Reply With Quote
Old 30th April 2017, 09:51   #29  |  Link
shh
2x Xeon E5-2699 v4 @2.20GHz, 128GB RAM, 2xThreads: 22/22 (HT: off)
https://ark.intel.com/de/products/91...Cache-2_20-GHz
2x22 full cores oviously are a little better than just one E5-2699v4 with Hyper-Threading on.
|  2x Xeon E5-2699 v4 |  37.19  |   9.36  |   118   |   5.48  |   2.13  |   2.12  |   3.25  |   3.48  |   4.90  |   4.89  |   5.28  |    N/A  |
shh
shh is offline   Reply With Quote
Old 3rd June 2017, 08:06   #30  |  Link
Selur
Selur's Avatar
I overclocked my system to 4 GHz to see how this would affect the benchmark, and got some mixed results.
|  Ryzen 7 1800X Eight-Core Processor          |  21.91  |   3.39  |    74  |   2.59  |   1.19  |    1.14  |   1.66  |   1.76  |   2.05  |    2.18  |   2.12  |    N/A  |4GHz (Mainboard default)
|  Ryzen 7 1800X Eight-Core Processor          |  22.14  |   3.43  |    73  |   2.52  |   1.21  |    1.15  |   1.64  |   1.73  |   2.22  |    2.24  |   2.32  |    N/A  |4GHz (only changed the cpu mult)
|  Ryzen 7 1800X Eight-Core Processor          |  22.35  |   3.41  |    74  |   2.59  |   1.14  |    1.14  |   1.56  |   1.75  |   2.17  |    2.32  |   2.37  |    N/A  | 4GHz (only changed the cpu mult) + MalwareBytes and Windows Defender disabled
I'm wondering why the LAVC benchmark is so low compared to the old unoverclocked result I posted before:
|  Ryzen 7 1800X Eight-Core Processor          |  21.28  |   3.42  |   118  |   2.72  |   1.13  |    1.13  |   1.71  |   1.83  |   2.52  |    2.53  |   2.65  |    N/A  |@Stock speed
Not aware that I changed anything else on my system aside from updating Windows, since the last benchmark.
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 3rd June 2017, 20:04   #31  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Hi Selur
AMD make new compilator optimized for Ryzen (linux only?)
http://developer.amd.com/tools-and-s...g-cc-compiler/
You can try to make compilation for x264 and x265, make test with this benchmark and post your result?
THX
Old 29th July 2017, 15:32   #32  |  Link
jd17
If anyone is interested, I tested my i5-7500 as well, thanks for compiling the benchmark!
|  Core i5-7500       |   9.21  |   1.89  |    64   |   1.55  |  0.45   |   0.45  |   0.72  |   0.78  |   1.19  |   1.20  |   1.52  |    N/A  |
jd17 is offline   Reply With Quote
Old 5th August 2017, 10:24   #33  |  Link
sacd
Learning
Interesting benchmark, measures all the right applications.
This is my new editing PC running the benchmark_auto from the first post dated April 14 2017 (CPU OC 4.5GHz):
|  Core i9-7900X      |  32.97  |   6.24  |   157  |   4.70   |   1.57  |    1.58 |   2.50  |   2.74  |   4.07  |    3.98  |   4.82 |    N/A  |
sacd is offline   Reply With Quote
Old 6th August 2017, 17:07   #34  |  Link
drizzit
My results with the auto bat, manually overclocked to 4.4GHz
|  Core i7-4790K      |  11.70  |   2.10  |    78  |   1.74  |   0.49  |    0.49  |   0.82  |   0.89  |   1.39  |    1.40  |   1.75  |    N/A  |
drizzit is offline   Reply With Quote
Old 10th August 2017, 15:34   #35  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
you can say if you have real full CPU charge at 100% for x264 test with 8C/16T CPU and higher (if someone have 16C/32T).
thx
Old 10th August 2017, 21:45   #36  |  Link
Clare
I had to modify the script to run in Linux.
| Core i7-6700HQ      |  8.96   |   1.75  |    88   |   1.43  |   0.27  |    0.28 |   0.49  |   0.54  |   1.05  |    1.12 |   1.45  |    N/A  |
Here is the link to the modified script for Linux: https://gist.github.com/WyohKnott/72...10a4aea92af788
It depends on python-cpuinfo, and of course, you need to install ffmpeg, x264 and x265 from your distribution repository.
Clare is offline   Reply With Quote
Old 22nd August 2017, 22:02   #37  |  Link
Balthazar2k4
Here you go:
| Ryzen Threadripper 1950X 16-Core Processor | 37.59 | 6.50 | 136 | 4.65 | 2.02 | 2.00 | 2.95 | 3.10 | 3.89 | 4.10 | 4.26 | N/A |
Edit: x264 does NOT utilize all 32 threads. During that portion of the test I was seeing ~80% utilization.
Balthazar2k4 is offline   Reply With Quote
Old 24th August 2017, 21:01   #38  |  Link
kolak
Far beyond reasonable scaling. Such a waste of processing power This is only good for running many encodes at the same time or splitting long encodes into chunks.
Can you test it with 1 core, so we can see how all this cores are wasted
Old 24th August 2017, 21:05   #39  |  Link
kolak
Just shows how good clock makes things fast.
Old 27th August 2017, 20:06   #40  |  Link
bladerunner1982
| Pentium G4560 | 5.02 | 0.77 | 37 | 0.66 | 0.25 | 0.25 | 0.40 | 0.44 | 0.67 | N/A | N/A | N/A |
bladerunner1982 is offline   Reply With Quote
