Old 20th February 2019, 16:08   #54901  |  Link
Originally Posted by tp4tissue View Post
So is DX11, the Go-To under all circumstances outside of Interlaced.
there are so many circumstances no.
the saves is DXVA copyback for madVR it doesn't internally harm quality and is fast enough for most PCs.
Old 20th February 2019, 16:26   #54902  |  Link
tp4tissue
tp4tissue's Avatar
Should we create a diagram for which one to pick ?
Also highlighting the advantages of each ?
What are the advantages for DXVA 2 vs DX11 ?
Is there a difference between ATI/ Nvidia implementation ?
Ghetto | 2500k 5Ghz
Old 20th February 2019, 16:34   #54903  |  Link
this is the madVR thread not a hardware decoder thread.
Old 20th February 2019, 18:01   #54904  |  Link
el Filou
el Filou's Avatar
It can have an impact on madVR quality/performance though.
Basically (as of current madVR version; 'DXVA' here means either DXVA2 or D3D11):
- as per nevcairiel's advice, Intel QuickSync and NVIDIA CUVID are obsolete compared to DXVA copy-back and are not recommended
- native variants of DXVA prevent use of madVR's IVTC and black bar detection. They also consume a bit more VRAM (few hundreds MBs) which can be an issue if you have a discrete card with very small VRAM and you want a big decoder queue.
- copy-back variants of DXVA are not recommended for iGPUs for performance reasons. They can also have performance problems with discrete GPUs in rare situations like UHD on much older systems.
- DXVA2 native can have chroma quality issues on some GPUs
- D3D11 native prevents using hardware deinterlacing
- D3D11 copy-back is slower than DXVA2 copy-back and has no quality advantages, so you have no reason to use it really
- D3D11 native is slightly faster than DXVA2 native, and doesn't have the chroma quality issue, so is interesting if you're not using any of: IVTC, black bar detection, hardware deinterlacing.
- as always, your mileage will vary for compatibility/performance issue with some combinations of software/hardware.
HTPC: Windows 10 1909, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 20th February 2019, 18:07   #54905  |  Link
iSeries
For me the only drawback for D3D11 native is no hardware deinterlacing (and even then it's only a minor drawback). What would be useful is if in LAV you could set a fallback decoder for interlaced content, but that's not really anything to do with madVR.
iSeries is offline   Reply With Quote
Old 20th February 2019, 18:07   #54906  |  Link
Grimsdyke
Hi Guys, I am slowly entering the 4k/UHD world and I have noticed something strange - but maybe it is a known problem and the reason why I am the only one here on Intel
Here is the problem:
When I play a 4k-file that has no black bars and change something in MadVR like target nits, etc. I see an immediate effect !!
But on files with black bars nothing changes - no matter what setting I test !! The only setting that has an effect is (de-)activating "output video in HDR format".
If this not known yet could someone please alert madshi over at AVS because I don't have an account there. Thanks !!
Grimsdyke is offline   Reply With Quote
Old 20th February 2019, 19:21   #54907  |  Link
alexnt
As promised and sideways...
https://www.dropbox.com/s/khfijawkkh...04624.mp4?dl=0
alexnt is offline   Reply With Quote
Old 20th February 2019, 19:34   #54908  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by alexnt View Post
Check your setting under Windows Power OPtions.
You might've set it to High performance
Try setting it to Balanced and see if the CPU will down clock. < in advanced setting make sure minimum cpu speed is set to 5% >
But in either case, even if it downclocks, it's using the same quantity of resources.
Ghetto | 2500k 5Ghz
Old 20th February 2019, 19:41   #54909  |  Link
alexnt
No no I m ok now. That was a video proof that there was an issue and now problem is solved. It was a reg key that was left even I uninstalled madvr.
Old 20th February 2019, 19:43   #54910  |  Link
el Filou
el Filou's Avatar
But on files with black bars nothing changes !!
Yes, I can't find the exact post quickly but it's been reported to madshi by one of the testers that black bars were confusing the dynamic HDR algorithm. It should be fixed in the next release (or you can download the latest test build from the AVS thread, search for 'madVRhdrMeasure' starting from the last page).
Old 20th February 2019, 20:19   #54911  |  Link
tp4tissue
tp4tissue's Avatar
Could you post location of reg key
Ghetto | 2500k 5Ghz
Old 20th February 2019, 20:25   #54912  |  Link
madjock
HKEY_CURRENT_USER\Software\madshi\madVR
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Yamaha RX-V377 | Philips 65PUS6703 - 65"
Old 20th February 2019, 20:25   #54913  |  Link
tp4tissue
tp4tissue's Avatar
Does the size of the black bar change the quantity of confusion ?
For example, if it was a just a little bit of black bar in a near 16:9 movie, vs a 2:1 movie with big bars.
Ghetto | 2500k 5Ghz
Old 20th February 2019, 20:27   #54914  |  Link
tp4tissue
tp4tissue's Avatar
Thxx
Ghetto | 2500k 5Ghz
Old 20th February 2019, 21:47   #54915  |  Link
Grimsdyke
Just tested the latest test build (54) and the problem is unfortunately still there !! So I would be very thankful if anyone could inform Madshi about that because watching John Carpenter's original HALLOWEEN is really not 'fun' right now.
Old 20th February 2019, 22:13   #54916  |  Link
tp4tissue
tp4tissue's Avatar
What's happening, is it too dark or too bright ?
I just tried my copy of halloween 1978, changing the nit does make the screen brighter and darker.
I am using dxva2 copyback lav, on madv 92.17
Ghetto | 2500k 5Ghz
Old 20th February 2019, 22:53   #54917  |  Link
Alexkral
I uninstalled both mpc hc & be last night and madvr, too.
I also deleted madvr's folder, rebooted and then I run a registry cleaning. I also deleted mpc's folder left in program files.
I reinstalled mpc and downloaded another(older version 91.4) of madvr and extracted the folder in another drive(c: - had it on d: ).
When I started playing a movie and opened madvr settings I noticed that my settings where there(all of them, even the hd profiles in scaling) but madvr folder didn't have "settings.bin" when I extected it. As I understand it retrieves previous settings and maybe that is the problem. Is there in other location that madvr creates folders and profiles, so if I clean them will solve the problem.
I don't believe what is happening is normal. I said before that there is not such issue with my brothers rig with 4670k and 660ti.
Gpu does all the rendering and so cpu drops clocks.
I have a 4690k and r9 290 and I know(because I have seen it) that madvr did't behave with the same way in the past.
I'd say that means you have another madVR installation, maybe for another player like JRiver like me.
Alexkral is offline   Reply With Quote
Old 20th February 2019, 23:25   #54918  |  Link
Grimsdyke
It's way too dark !! For example, the 'Rabbit in Red' matchbook at around 9:12 is almost completely in the dark.
Unfortunately I can't use 'copyback' because my gpu is not fast enough. So I hope that Madshi might fix this soon !! Thx
Old 20th February 2019, 23:35   #54919  |  Link
clsid
No, it is completely normal that Madvr stores its settings in the Registry. The settings.bin file is just a secondary storage method for the settings. See it as a backup.
Old 21st February 2019, 00:08   #54920  |  Link
tp4tissue
tp4tissue's Avatar
measure nits only work with Cpu decode, or Copyback dxva2 or dx11.
It does not work with native dxva or native dx11, because it can not measure the frame nits.
There's no way around this. if you want to use dynamic hdr + highlight recovery, you'll have to upgrade your GPU.
Which gpu do u have.
Ghetto | 2500k 5Ghz
